Question about Homelite Consumer Products 4.0 Amp, 13 In. Trimmer
Trimmer will only run in choke position
I have a homelite trimmer Model # UT20044b, serial # AH1644683 and the engine is 25cc 5HCPS. I changed the spark plug this morning and it is still very difficult to start. Once it is started I can only run the unit in "choke" (the unit has a 3 switch setting, I think choke is the middle position but I do not have the unit in front of me) I can give the unit gas in choke position and cut gas, but if I place the unit in the "run" position and give it gas the unit will immediately shut off. Even in the choke position the unit will cut off a couple of times before I finish cutting the grass. Any assistance is greatly appreciated.
    Problem Solver:
  • 11 Answers
You have a few possibilities. Make sure you have good fresh gas in the tank. You're not getting enough gas, so choking helps get more gas than air, making it run better. Could be the carb diaphram (not very expensive if you replace yourself), when they get old they don't perform like they should. Could be the filter in the gas tank is bad, plugged. Also might be just an easy adjustment on the carb Low, and High speed screws. The choke has three positions, full choke, partial choke, and no choke, which means run position.
Posted on May 05, 2010
Weed wackier gas trimmer
didnt specify the make and model so generic answer ---check fuel mixture is correct --check the filter in tank is not plugging up--look for damaged / crack in fuel feed lines-look at spark plug --carb may need cleaning --exhaust port may need cleaning
Jul 04, 2016 | Garden
I HAVE A HOMELITE TRIMMER WITH A 5HCPS.025 ENGINE, WHERE CAN I GET A CARBURATOR FOR IT
HOMELITE homelite was bought by rieobiy may get one from them.
May 18, 2015 | Homelite Garden
Trimmers: Homelite Easy Reach-25cc-Model # UT20044B& Homelite Mighty Lite- 26cc- Model # UT21546 Both trimmers will start but when throttling up they cut out. They will also cut out when the choke is...
sounds like an air/ fuel mixture/ratio problem.there should be two screws side by side near the carb. crank trimmer and slowly adjust screws, in or out, till engine runs smoothly..
Sep 08, 2010 | Homelite Mighty Lite Lawn Trimmer
My homelite string trimmmer will not run when choke is run position. it will run, but not at full throtle, when choke is set between full choke and half-choke.
you've got a fuel system issue , most likely carb problem, if this a newer trimmer it will likely need the carburetor replaced or adjusted, also check for cracking fuel lines or signs of old fuel varnish in the tank
May 31, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer Magneto Air Gap setting 25cc
Normall setting is 10 thou but if there is no play in the crank bearings you can set at 8 thou
Jun 23, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite 2-cycle gas line-trimmer - It starts okay but when you hit the throttle it dies.
The high speed jet is either out of adjustment or it is plugged. There should be a screws with H (high speed) and L (low speed, idle) You could try to open the high speed adjustment on the carb or run your machine on partial choke if you have to.
Apr 17, 2009 | Craftsman 25cc Gas Line Trimmer
Homelite Trimmer Pull Start Cord
The part no. for the Spring and container is A98773A. You can Google the PN and find many sources. Expect to pay between $10.00 to $15.00. I like m-and-d.com If they have it in stock you will normally get it in 3 to 4 days.
Mar 25, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Consumer Products 4.0 Amp, 13 In. Trimmer Logo
1,663 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
