Question about Dell Inspiron 6000 Notebook
WHEN MY LAPTOP HYBERNATES, IT WILL NOT COME BACK ON BY TOUCHING THE KEYPAD. I HAVE TO SHUT IT DOWN AND TURN IT BACK ON TO USE IT.
    Sergeant:
    Champion:
  • 305 Answers
Go into control then power options click on advanced then on the bottom 2 drop down arrows it will give you the options of how you wake comp from hybernation.
hope this helps
Posted on Apr 28, 2010
Onkyo ht r591 keep clicking on/off
Hi Markes,
It could be that there is a frayed speaker wire touching the back of the receiver and when playing at a low level the speakers do not require that much power, however when the level from the speakers increases more power is required and if there is a frayed speaker wire touching the back of the receiver there could be a short causing the receiver to shut down. A way to avoid the frayed wire is to use "Banana Connectors" that the speaker wires goes to and the connector will plug into the speaker posts. Please try the following to see where the issue is coming from. Have the receiver turned off, make sure all the speaker wires are labeled, and disconnect them from the speaker terminals. Turn the receiver on select a source that would give you sound if the speakers where still connected and turn the volume all the way up. If the receiver shuts down than it would need to go to a service center as it is an internal problem with it. If the receiver does not shut down, turn the volume down, shut the receiver off and connect one speaker and than turn the receiver on selecting the same source as before and raising the volume up. If the receiver shuts down, remove that speaker from the post and connect it to another speaker post to determine if it is the receiver or the speaker itself that is giving you the problem. If the receiver should shut down after moving that speaker you know it is a problem with the speaker or the wiring. If the receiver does not shut down, turn the volume down, shut the receiver off and connect another speaker followed by doing the previous test procedure. Keep adding speakers until you have them all reconnected to the receiver as long as it has not shut off while trying the test procedure. After determining whether it is the speakers or the receiver you would need to bring either to a service center to be repaired. To locate an authorized independent service center, check the dealer and service locator at our website: www.onkyousa.com or www.integrahometheater.com, Thanks, JT
Oct 11, 2015 | Onkyo Audio Players & Recorders
How to repair a onkyo A-812XG if a volume is higher the unit is shutdown
Hi Ryan, It could be that there is a frayed speaker wire touching the back of the receiver and when playing at a low level the speakers do not require that much power, however when the level from the speakers increases more power is required and if there is a frayed speaker wire touching the back of the receiver there could be a short causing the receiver to shut down. A way to avoid the frayed wire is to use "Banana Connectors" that the speaker wires goes to and the connector will plug into the speaker posts. Please try the following to see where the issue is coming from. Have the receiver turned off, make sure all the speaker wires are labeled, and disconnect them from the speaker terminals. Turn the receiver on select a source that would give you sound if the speakers where still connected and turn the volume all the way up. If the receiver shuts down than it would need to go to a service center as it is an internal problem with it. If the receiver does not shut down, turn the volume down, shut the receiver off and connect one speaker and than turn the receiver on selecting the same source as before and raising the volume up. If the receiver shuts down, remove that speaker from the post and connect it to another speaker post to determine if it is the receiver or the speaker itself that is giving you the problem. If the receiver should shut down after moving that speaker you know it is a problem with the speaker or the wiring. If the receiver does not shut down, turn the volume down, shut the receiver off and connect another speaker followed by doing the previous test procedure. Keep adding speakers until you have them all reconnected to the receiver as long as it has not shut off while trying the test procedure. After determining whether it is the speakers or the receiver you would need to bring either to a service center to be repaired. To locate an authorized independent service center, check the dealer and service locator at our website: www.onkyousa.com, Thanks, JT
Apr 26, 2015 | Onkyo Audio Players & Recorders
The protect mode is active - what are the fixes
http://www.onkyousa.com/Support/servicecenterLocator.php?source=globalnav
Apr 12, 2015 | Onkyo TX-DS787 Receiver
Samsung mobile keypad not working software
Have you tried to shut down the device and turn it back on?
Feb 03, 2014 | Computers & Internet
My laptop keeps restarting without me touching the same thing
Boot into safe mode, allow it to boot completely. Then shutdown/restart as normal.
It should be back. If not, allow it to reboot and choose the "Last Known..." option and boot from there.
Good luck
-Carlos:
Dec 17, 2009 | Toshiba Satellite A100-S8111TD Notebook
Laptop hybernates when i use the keyboard
make sure your ctrl or shift kays are not pressed
Jul 23, 2009 | Sony Computers & Internet
E-machine 210 shut down and wouldnt come back on
try a different power supply first if this does not work
post here meage will go through other possibilities
May 21, 2008 | E-Machines eMachines Desktop PC
Dell Inspiron 6000 Notebook Logo
71 people viewed this question
Alun Cox
