Question about Dewalt D55250 Factory Recondition Heavy - Duty 4 Hp 4 Gallon Gas Hand Carry Compressor with Control Panel
Emglo compressor: How to remove compressor from engine
DeWalt Emglo compressor. I can't figure out how to remove the blown-up "Emglo" compressor from the 4 hp Honda engine so as to salvage the engine. (The compressor itself threw its connecting rod through the engine case after about 180 hours of use.) No service manual or exploded diagram seems to be available to determine how to get the compressor crank off the end of the engine output shaft or the destroyed remnants of the compressor case off from the side of the engine.
3 Suggested Answers
  • 1383 Answers
SOURCE: It is an electric motor Dewalt Emglo Compressor
Dewalt recommends using synthetic pump oil, however if you only use the machine occasionally and not in a commercial setting, standard compressor oil will work great and save you money. Synthetic oil will last longer and can take much higher temperatures without breaking down. Lowes sell the kobalt brand of compressor oil and sells for about $3 for standard and $7 for synthetic. Home depot sells campbell hausfeld brand but equally as good. Auto parts stores also sell a line of compressor /pump oil just watch pricing for your needs. If you can't find compressor oil, non-detergent motor oil works just fine. Good holidays
Posted on Dec 15, 2010
nampaboat
  • 150 Answers
SOURCE: dewalt emglo d55155 air compressor-what
Need to use air compressor oil it is available at you local hardware store in the tools department.
Posted on Feb 06, 2011
Looking For A Parts Diagram For A Emglo LAG8HGA-8P--Trying To Find The Regulator--Not Like The Ones I See On Emglo's Parts List. This Is A All In One Unit The With The Air Gauges On Each Side Of The...
All you need is a 3/8" NPT regulator. DeWalt bought Emglo years back. DeWalt part number A18682is what you are referring to. Rol-Air would be part number REG0375. Here is a diagram of the newer DeWalt version. Reference part #32 is what you want.
http://servicenet.dewalt.com/Products/Detail?isId=true&productNumber=D55271&selectedType=16219
Jul 16, 2011 | Air Tools & Compressors
Hey there. I am having problems with my Emglo Dewalt d55151 compressor. I have taken it apart and and cleaned everything up. The reason I did all this was..because the cold start valve stays open and its...
The cold start valve will close when volume of air from compressor is sufficient to overcome spring under pin (allows the motor to come up to speed). Evidently your compressor is producing very little air. Usually the problem is leaking or broken reed valves or gaskets. Remove the head and look for torn/ leaking gaskets and replace as needed. Examing the reed valves and seats and look for broken cracked reeds or worn seats. Some of the valve plates used in Dewalt compressors are made of aluminum and would fail. Parts are available at www.toolpartsdirect.com or local dewalt service center. Good luck with your repair.
Apr 25, 2011 | Dewalt d55151 factory reconditioned emglo...
I have a dewalt emglo electric compressor around 6 months old with only 5hrs of use. i find as soon as the temp drops a few degrees like early morning summer weather it will not start it will turn over...
I have a gas engine powered DeWalt compressor. I don't know about yours, but is there an unloader that you have to switch when you are starting?
Next, did you inform DeWalt, this unit is almost new(ly rebuilt) and they should take some responsibility for it.
You know, it could be that the motor has a starting problem, (bad capacitor, bad start winding system).
Gary
Feb 11, 2011 | Dewalt d55151 factory reconditioned emglo...
Dewalt emglo d55155 air compressor-what type of oil? this machine is electric
Feb 05, 2011 | Dewalt d55151 factory reconditioned emglo...
It is an electric motor Dewalt Emglo Compressor model#D55151. What type of oil should I use in it?
Dec 15, 2010 | Dewalt d55151 factory reconditioned emglo...
Dewalt/Emglo D55155 compressor screeching and breaker blown
Sounds like it isn't getting oil on the bearings. Take it apart yourself,after you get a diagram of it and find a parts source.
Mar 22, 2010 | Black & Decker Dewalt #D55155 2HP 4GAL...
Hi I have a Dewalt d55141 emglo contiues to run
Open the shut off switch box and adjust the cut out pressure.
Nov 17, 2009 | Dewalt & 2HP Hand Carry Heavy Duty...
Manual for Emglo Air Mate Compressor
Manual for the similar dewalt model is at www.dewalt.com, click on parts & service icon, then enter D55151. Or try clicking here: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/5135175-01,D55152,Elec.pdf This Dewalt compressor is one of many versions of the Old Emglo AM78 compressor. There are several other brands built with the exact same design such as the Senco line. For parts list of actual Am78hc4v go to mastertoolrepair.com. If you have questions or problems with this compressor please email, Good luck
Jan 28, 2009 | Dewalt d55151 factory reconditioned emglo...
Dewalt D55250 Factory Recondition Heavy - Duty 4 Hp 4 Gallon Gas Hand Carry Compressor with Control Panel Logo
61 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
