Question about Frigidaire FRS23H7C Side by Side Refrigerator
Jenn air model JRSD209T. Ice maker does not fill with water and consequetnly will not make ice.
3 Suggested Answers
SOURCE: jenn air model JRSD209T
The ice maker is not working its not filling with water,  there is water to the front water/ ice dispenser, is there a filter in the inlet? or something?
Posted on May 04, 2008
What is the energy rating on the JRSD209T refridgerator?
Leslie
Posted on Sep 07, 2008
Jenn-Air Side-by-side Refrigeration not making ice and leaks water underneath when ice maker arm is up
With the arm up in the ice tray, the water solenoid valve should be closed. When the arm drops, that tells the ice maker to open the water solenoid valve to fill the ice maker tray. It sound like the leak is at the inlet side of the water solenoid valve. On some models its not easy to get to, but follow the water line to it. Hope this is it for you. Good luck.
Dec 30, 2013 | Refrigerators
Reset ice maker
7c3b8cbb-076b-4151-8484-231367a81955.jpg0ef80fea-be03-46a2-9d13-079d4e206d2c.jpg20a0932e-3a69-4ce7-8bf3-ad10bc82a262.jpgDoes the ice maker have ice inside the slots but will not drop the ice? What is the correct model number of your refrigerator? If the slots are empty try filling with tap water and once the water freezes and drops the ice and then does not refill with water that will point to the water control valve. If the ice maker does nothing it will be the ice maker that will need to be replaced. For the model JCD2389G uses the=> D7824706Q Ice Maker Assembly and the water control valve is=> 12001892 Water Inlet Valve I am here if you have questions....Sea Breeze
Aug 29, 2013 | Jenn-Air JCD2389G Side by Side...
No ice coming out should wire be horizontal or vertical
The arm should be down for ice production. If you have ice cubes still in there slots that would indicate ice maker failure. If the slots ar empty fill them with tap water and allow them to freeze. If after the water freezes and the ice maker drops the ice into ice bin and then does not refill with water then that points to the dual water control valve.Jenn-Air uses the Whirlpool style modular icemaker=> 61005508 Ice Maker Assembly or D7824706Q Ice Maker Assembly they are both the same ice maker and the dual watercontrol valve is Click Here=> 67005154 Water Inlet Valve
or 67005154 Inlet Valve Below is a clip about Broke Ice Maker's and has some great tips and test but if you do not prefer working around electricity I ask that you not do the water fill test unless you are comfortable working aronud 120 VAC Click=> HERE I will be here should you have questions. If helpful please rat this solution. Thank You, Sea Breeze
Oct 12, 2011 | Jenn-Air JCD2295HES Side by Side...
Unit is a Jenn-air JRSD209T. Two problems. When water runs to fill the ice maker it runs down into the ice shoot leaving you with a cup of water with your ice. Second problem. Witnessed a red glow...
For your first problem i need a bit of a clarification. Is what your saying,when you dispense ice through the door some water also comes out of the dispenser??
For the glow that is perfectly normal,what your seeing is the glow of the defrost heater melting off the biult up frost. If it did not come on and melt the frost the refrig would not be cooling.The term"FROST FREE" is a bit misleading. Their is automatic defrost refrigerators such as the one you have, and the manul defrost that you need to defrost manually every month.
Gene
Aug 12, 2011 | Jenn-Air JSD2789GES Side by Side...
I have a Jenn-Air side by side refrigerator. JRSD209T. Water fills up the ice shute and runs into the floor. What stays in the freezer freezes in the chute. What do I need to change to fix this problem
From your description I'll gather you're not getting ice cubes either and need to replace the ice maker
Part # D7824706Q on the diagram labeled "Lights and Ice maker" it's item 1
This is from Sears so you can order and have it delivered to the house
http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Refrigerator-Parts/Model-JCD2295HES/1266/0165000?pathTaken=
Jan 01, 2011 | Jenn-Air JCD2295HES Side by Side...
Jen Aire Fridge ice maker fingers are below the
This one you have to take out the ice maker and run hot water from the kitchen sink into the tray to get the ice out. need model number if you want detail explaination how to. or just use a hair dryer that will work to!!! if fingers dont rotate after defrost ice then the gears are stripped, replace ice maker
Mar 27, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Ice maker problem on a Jenn-Air JRSD224W
check your water pressure if it is low then you are not going to get a good fill. you can adjust the fill on many icemakers look for an adjustment screw on the motor head
Apr 20, 2008 | Jenn-Air JCD2295HES Side by Side...
If you have a cold enough temp in the icemaker a heater should then kick in to warm the plate and a motor then turns and drives the ice out. The ice maker modules can be repaired, but the checks need to be carried out by fridge guys. Alternatively you can replace the whole module but this can vary in cost quite dramatically. Hope this has been of some help.
Sep 11, 2007 | Frigidaire FRS23H7C Side by Side...
Frigidaire FRS23H7C Side by Side Refrigerator Logo
159 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
