Question about RCA 36V550T 36" TV
I hooked up my computer to the tv and the desktop is bigger than the tv screen can't see the icon or tool bars? res. is set on the max tv menu doesn't have alot of picture settings
  • 417 Answers
Try going into your display properties, and adjusting from there. Right click anywhere on your start screen, and select properties. Then select display properties. Hope this is helpful
Posted on Apr 28, 2010
New Acer 5532 laptop; v.wide screen but not v.deep. Currently, large toolbar icons take up some 25% of the screen unecessarily - how to reduce their size down ?
Depends on which Windows version you have, unstated.
Right click on screen anywhere except other icons, go to "properties" and adjust screen res to max and also check under appearance that icons are "normal"
Mar 30, 2010 | Computers & Internet
When I hook my tv up to my desktop computer the screen looks like it is going to work (it says dell then the loading bar fills up) as a monitor until it is time for my log in screen to come up. The screen...
hi,
This is normally due to a frequency or resolution incompatibility. Turn on your desktop computer, then change the screen resolution to 800x600 or 1024x768. Save the settings. Reboot to check that it is indeed saved.
Once you boot up on your TV, it should display fine. Gradually increase the resolution and colors to the max your TV can handle.
Feb 28, 2010 | Element Electronics FLX-3211B 32 in. LCD...
I have a samsung syncmaster 915a which resets to max resolution. Can I change their Motherboard equivelint??
Resolution is determined by the display settings, up to the limits of the hardware. In windows, if you right-click on your desktop and select settings, click the "display settings" tab on the resulting window, you can select lower resolutions (icons etc. get bigger, less stuff fits on screen) if you desire. Be sure to click "apply"
Nov 15, 2009 | Computers & Internet
No icons or tool bar on desktop at startup
In your desktop, Right click your mouse and properties will show and look for show desktop option. And then move your mouse to the bottom of your computer screen, if toolbar will show, then your toolbar is set to automatic hide. Change the settings in your Taskbar and Start Menu Properties and change there the settings, uncheck the auto hide task bar.
Nov 10, 2009 | Acer LX.W530X.012 Gateway M7325u 15.4in...
My computer won't stay connected to the TV... I hook everything up properly....plug in the VGA cable, turn the TV on then the computer then I switch the TV to VGA mode. The computer will be on the TV...
Connect your computer to a normal monitor. Try adjusting the screen resolution setting to a lower setting.
to adjust the monitors resolution. Right click on the desktop in an open area not on a icon.> select properties or personalize. depending on the operating system> then click on the settings tab on top> under the screen resolution you will find a slider bar. > try sliding it over to the left a couple notches. This should resolve the issue!
Sep 19, 2009 | Insignia LCDTV26 26 in. Television
Vostro 1510 vga to tv vga desktop picture no icons on tv
It's likely that your OS, whatever that is, wrongly identified the display size of your TV and it set the screen resolution too high, and you may even have what is known as a "virtual" desktop that is bigger than the physical screen size.
To ensure this is the case, move the mouse pointer towards the edges of the TV screen and see if your desktop scrolls along, and your icons and other stuff shows up. If this is the case, then adjust your resolution to a smaller size, say, from 1920 x 1200 to 1024 x 768, click Apply and then Ok.
That should fix the problem temporarily, but there's no guarantee that it will not do the same thing next time you connect your pc to your TV set. I have experienced the same thing with my laptop and HDTV, and I have had to repeat the process again.
Aug 17, 2009 | Dell Vostro 1510 Motherboard System Board...
Computer To Tv Problem ''Over Sized''
the tv's setiings need to be set to auto or correct resolution
for the image you display , try going down in res until it looks right then find other ways to make it fill the screen IE stretch etc..
hope this helps
Dec 30, 2008 | Nvidia GeForce 9800 GTX,, PCI Express...
Having prob connecting my laptop to a TV via hdmi
try playing around a bit with the display settings, there are not many laptops that are setup to automatically adjust to the dual screen setup with an lcd tv. Also, iv found that Not using the lcd as a duplicate of the main screen is a good idea, set it up as a separate screen...if you know what i mean, if you do it right you will see only yourbackground on the tv and no start menu bar or icons.... In this configuration you can set the resolution to the max for the best quality possible for your television.
Nov 25, 2008 | Computers & Internet
The software is too big for my screen, I cannot see any menu or tool bars so cannot use
Press "Windows logo" key from your keyboard to see task bar and menu.
Or
Press "Windows logo" key + D to see desktop, task bar and menu.
or
Change your screen resolution to bigger size but remember selecet resolution according to the monitor maximum resolution.
Nov 24, 2008 | Computers & Internet
No task bar or icons appearing on screen
the easiest option will be to do a system restore to before the outage; Start/All programmes>accessories>System Tools>System Restore. Then choose restore my computer to previous settings, then choose a date that is not greyed out. Hope this sorts it Please rate solution
Nov 20, 2006 | Gateway 510H Pentium 2.4 GHz, 256MB RAM,...
RCA 36V550T 36" TV Logo
65 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
