Question about LG WM2016C
I have a WM2010 wash machine. The front of the drum has fallen down and the rubber gasket is all twisted up. I can't straighten up the gasket. What happened?
    Genius:
  • LG Master
  • 1,466 Answers
Sounds like drum suspension gone or top spring/ springs broken check this 1st refit if just fallen off, quite tight to do...heavy....
Posted on Apr 28, 2010
Clothes got twisted on front rubber piece put it back together and now the washer does not spin
Did the rubber tare when it got twisted? If not did you remove the rubber below and reinstall it. If not then it may of slipped and could be causing a bind in the drum.
Apr 11, 2014 | Whirlpool Duet 3.8 cu. ft. Front Load...
Replacing door gasket
Most door gaskets are available online, most recommended taking drum out to replace, but task can easily be done by removing rubber from hole in machine (end of a spoon helps) then push drum back through the hole and you will see a large clip on rubber to the drum, unscrew clip and pull out rubber, reverse to replace. Good luck.
Feb 19, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Gasket replacement problem, Hotpoint WMF540 washing machine
most I have ever seen have slots in the sheet metal that tabs fit into like slide loc tabs.. this requires sliding the face up or down on the sides.. that may help..these are locked by internal screws that you can take out from tne inside ..
Jan 12, 2014 | Washing Machines
The door gasket is twisted, how do I fix it?
There is a metal retainer with a spring on the outside of the door around the seal remove that and re-form the seal around to door panel and secure with retaining spring. If this doesn't help you will have to replace the seal.
Feb 12, 2012 | Miele Touchtronic W3033 Front Load Washer
GE Profile front loader washing machine is leaking front of door, believe the problem is the rubber washer ring, however can this be replaced?
Hello, this is usually the door seal, most machine incorporate a one piece combined door seal and outer drum seal(often just called a DOOR GASKET), the door seal are put in on the front panel first in the factory, then the drum assembly is put in and the seal pushed over the outer drum. This means a lot of stripping down has to be done just to replace the drum to the door seal.
Thanks
Jun 14, 2010 | GE WSXH208A Front Load Washer
F9 fault. looks like inside drum has fallen away
one of the springs has come off - also ck the lower shock - it may have come apart
Jan 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Rubber seal on Frigidaire twisted during wash.
The only way to realign this is toremove the sping under the lip at the door portion of the seal,this is a tough one youll need a third and forth hand.
Mar 15, 2009 | Washing Machines
Something in washer drum
The casing around your drum is locked in place.(got to take machine and casing to get to drum) if something is in there depending on the size it will make its way down the drain filter area.. to get to the filter.. you open the front bottom plate..(3 or 2 screws) you will need a few towels before you twist open the filter cap.. help that will work .. good luck . mike
Jan 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
LG WM2016C Logo
371 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
