Question about Car Audio & Video
How to remove the dash board cluster on 2001 s500 mercedes
Dear Sir,
I have problem with my cluster recently, at the beginning the light on the cluster was flickering and few weeks later the whole cluster light went off.
At the same time, when the cluster went out, many of the electrical functions fail as well; such as the electric trunk, signal blinker etc.....
I found the cluster on line, rebuilt unit for $400.00. but I like to to know how to pull the unit out.
I am opened for any suggestion. Your help will be very much appreciated.
  • 113 Answers
What iss the make /model and year of the car?
Posted on Mar 25, 2008
How do I check the synthetic oil in the Mercedes s500
I think you need a factory dipstick or check oil using your instrument cluster in the dash.
Jul 16, 2014 | Vehicle Parts & Accessories
My Dash Isnt working, the gauges dont move or work how do i fix it
Instrument Cluster -it could be a loose connection at the harness. REMOVAL & INSTALLATION
  1. Disconnect the negative battery cable.
  2. Disable the SIR system. Refer to procedure outlined in this section.
  3. Remove the cluster trim plate, as follows. Fig. 1: View of the cluster trim plate (1), instrument panel (2), dimmer switch lead (3), fog lamp switch (4), and mounting screws (5) - Chevrolet Malibu shown 93206g21.gif
    Fig. 2: View of the cluster trim plate screws (1), cluster trim plate (2), and instrument panel assembly (3) - Oldsmobile Cutlass shown 93206g22.gif
    1. Remove the bezel from the ignition switch. Fig. 3: Remove the bezel from the ignition switch 93206p24.jpg
    2. Remove the screws fastening the cluster trim plate.
    3. Gently pry out the trim plate.
    4. Detach the hazard and instrument panel electrical connectors and remove the trim plate.
  4. Remove the four screws attaching the instrument cluster to the dash panel.
  5. Pull the cluster rearward and detach the electrical connections, then remove the cluster from the vehicle. Fig. 4: Exploded view of the instrument cluster assembly 93206g23.gif
    To install:
  6. Attach the cluster electrical connectors and position the cluster into the instrument panel recess.
  7. Install the screws into the instrument cluster and dash. Tighten the screws until fully driven, seated, not stripped.
  8. Install the cluster trim plate, using the reverse of the removal procedure.
  9. Enable the SIR system as outlined in this section.
  10. Connect the negative battery cable.
Nov 09, 2010 | 2001 Chevrolet Malibu
The panel light that show my mileage dont light up any more
I have found that this is a VERY common fault with the 1998-2003 Buick Century Instrument Cluster. The portion of the Cluster that shows the Gear selection PRD123 and Odometer (miles driven) is a non-serviceable part, requiring repair by shops that specialize in instrument repair, such as SpecMo in Madison Hts, MI, and a few other mail order shops on the West Coast (see EBay Motors). Price for repair and 1 year warranty ranges from $125 to $200. New part can be as much as $400. And that is if you can safely remove the Cluster from the Dash board, and deliver it for repair. And do this without triggering the Airbag (SIR), while you're tooling around in and under the dash. The procedure for getting the Cluster out, is contained in the Haynes Repair Manual, or get a copy at the Library. Pull the SIR fuse (right side, interior fuse box, end of dash panel), disconnect (and as far as I am concerned, pull the main Car Battery), and then disconnect the one or two YELLOW SIR- PAC connectors, under the dash next to steering wheel and above and behind the Glove Box. Even though the Battery is disconnected and/or removed, the SIR (Airbags) have their own on-board power supplies that could trigger the Airbag devices, if badly bumped or ****. To get to these connectors, before you can get to the Speedo/Cluster, will require that you carefully and completely remove each and every panel from the floor, all the way to the plastic dash. You're going to love taking that glove box out, with that retainer strap, wraped around the pinion. This is not for the faint of heart, or the unprepared, under-tooled weekend-warrior. Care must be taken to avoid triggering these SIR's, or serious bodily injury may occur. But if you get the book, read it twice, get a cup of coffee, and proceed carefully, it can be done. Aside from not knowing your speed, engine temperature, or fuel levels, the car can usually be driven short distances without the Instr Cluster. So fill-up first, and top off the coolant, oil, and other stuff. Repair is about 1-3 days. While the parts are off the dash, that will be a good time to wash and Armor-All everything, clean the Duct-work, change the Cabin AirFilter located at the Windshield, under the Hood/wiper arm panel, and use a good ventilation disinfectant system. You will never have a better opportunity solve those pesky odors, and rattles. Cheers!
Aug 23, 2010 | 2001 Buick Century
Dashboard lights flicker on and off, speedo only
behind your instrument cluster there a molly plug that plugs into the back of the dash unit! its probably lose or has a bad ground
Jan 13, 2010 | 2000 Mercedes-Benz S-Class
2001 Dodge Grand Caravan. Dash board stopped
sounds like an electrical nightmare! start by removing the cluster,now try signals are they working if yes then bad cluster, also i had a few caravans that just had bad connections i removed the plugs and reconnected them and it worked fine, also with the light coming on with your foot on the brake may be a bad or in correctly installed bulb, check all brakeand signal bulbs, try all of this , good luck,hope this is helpful.
Nov 26, 2009 | 2001 Dodge Grand Caravan
Need to replace burnt out dash board lights 2001 Toyota Corolla
Just remove the 4 screws and then slowly pull the cluster out and reach behind and disconnect the plugs on the back of the unit and then remove the cluster. The bulbs can be removed by turning them and pulling out.
Sep 24, 2009 | 2001 Toyota Corolla
Instrument cluster on my 2005 S500 back illumination went out, although all the gauges are still working inclusive of the on board computer
remove the cluster(should be able to insert Small flat head screwdrivers into slots on plastic trim of cluster. Lower your steering wheel down and remove key. wait approx 30 seconds until cluster is off( means that the interior c.a.n. has went to sleep) unplug cluster and see if the bulbs you wish to replace are accessible from the rear cover. if not remove retaining screws and un clip rear cover from housing. You should have access to the back lighting bulbs
May 31, 2009 | 2005 Mercedes-Benz CL65 AMG
I need a auto diagram for a 1993 400sel evaporator
hello,good day,slight instruction on removal of your dash,first, battery disconnected, first console box (remove wooden cover ,air con switch,radio) then your dash board ,cluster,globe box, left and right lower under dash,if you remove your dash,your evaporator coil housing is visual,before your dismantle the housing,remove your wiper linkage with motor,remove ex.valve and heater hose,ty
May 18, 2009 | 1993 Mercedes-Benz Mercedes Benz 400 Class
Replacing the battery in a 2001 mercedes benz
Battery base has a device that clamps the battery on a step/notch on the side. Use a ratchet with an extension to loosen. Once it is loose you can remove the battery.
Dec 18, 2008 | 2001 Mercedes-Benz S-Class
Car Audio & Video Logo
117 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
