Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
How do you fix the color from rain bowing its like watching 3 d
  • Philips Master
  • 8,457 Answers
Ur tv have convergence problems,it dead.U must have tools relating to soldering and know soldering to fix this convergence problems.Must replaced 2 STK convergence ICS,and some or all it resistors.Tries Websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for the parts and labors.
Posted on Apr 28, 2010
Projection tv has 3 versions of what is on tv instead of one
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 26, 2010 | RCA D52W23 52" HDTV CRT TV
Picture bowed & Colors separted
Conversions are out....RCA>>>>>>>>>>>>>check
fuse by the flyback transformer
May 19, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture is bowed and colors are not aligned
This called Projection TV convergence. Take a look on this site for a tip on Projection TV convergence.
Apr 19, 2010 | Mitsubishi WS-55819 55" Rear Projection...
My sony KP-46WT510 the color in three corners is blured and the picture is bowed.
Hi,it seems you are experimenting a light engine problem.This is how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo So basically the 3 Lcd chips that create the colors and image is going bad and thats why you get that color discoloration.Contact Sony or look for your light engine online.God bless you and your house!
Nov 18, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
RCA REAR PROJ. SCREEN BOWS AT TOP AND COLORS DOUBLED
Hi, thank you for visit fix ya.
Resolder all connections around fly back ( check for open pico fuse).
if still problem, replace convergence board.
Thank you
Jul 27, 2009 | RCA HD52W58 52" TV
Picture is all distorted ,colors dont match up need 3d glasses to watch
HI, this is basic convergence failure. the convergence board controls the RGB stream and , if its malfunctioning or, the convergence chip set is damaged, it will distort the entire display and the colors will not be regulated correctly as you are experiencing at this time.
simply replacing the convergence board in this unit will fix your issue.
May 18, 2009 | RCA Televison & Video
Pt-47wx49e convergence problem
I just replaced the 2 convergance chips, but it did not seem to fix the problem. I then tested all the resistors that feed the convergence chips anf there was a 2.2 ohm fusable blown. IT was R7050 on mine. That seemed to fix it so that I could adjust all the colors through the convergence 2 screen. There seems to be a slight bow near the bottom when you look at the c2 screen, but not noticable when you are watching a picture. Since I got this broken, I am not sure how perfect it should be.
If anyone can send me the service manual, I would appretiate it. Thanks.
Oct 10, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Philips 46-inch Rear Projection with bowed image?? slight distortion
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jul 02, 2008 | Philips 46PP9302 46" Rear Projection...
Picture mess-up
This is a convergence problem that can be either bad connections on the convergence ICs or defetive ICs. If you can solder you should be able to fix this yourself. Look for large black ICs attached to a heat sink that will likely be marked STKxxx. Resolder the pins on these first. If that fails to resolve the problem, replace them. Expect to pay about $20-$35 for each one. There should be 2 of them.
Dan
Jun 02, 2008 | RCA HD52W58 52" TV
Trouble Aligning Colors
If the convergence is missing in the menu in screens,you have a bad reg ic on the convergence power supply the part number is 215530,the power supply is located on the black plastic above the right module with all the heat sinks
Nov 15, 2007 | RCA P56930BL 56" Rear Projection...
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
138 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
