Question about Jura Capresso Impressa S90 Espresso Machine
My Jura S90 has stopped giving me the awesome froth it is capable of. The steam comes in spurts and stops drawing the milk up from the container. I have run the de-scale operation - it made no difference at all - do I need a new pump or something ?
See no steam solutions under Jura S9
Posted on May 13, 2010
Jura impressa x7 does not rinse and coffee does not come out. I do get steam for froth etc
Jura x7 coffee machines are older models in the coffee machine range. It may simply require a full system clean, using jura cleaning tablets, or more likely a service. Bean to cup machines should really be serviced every year to 18 months depending on usage.
We can put you in touch with a Jura engineer if you need one, contact me here Denby Dale Coffee
Oct 19, 2012 | Jura Capresso Impressa S90 Espresso...
Steam wand not working
The steam wand ejects steam in order to froth the milk. The steam wand should be cleaned after it is inserted into milk and at the end of each day. Do not allow the steam wands to soak in water overnight since some of the dirty water can be sucked into the boiling tank inside the machine this may cause the steam not to come out
Unplug the machine, take the case off, disconnect the switch wires and test it with a continuity meter. If you don't get any continuity, or if it is constantly closed and never open, the switch is bad.
this could have been prevented by regular maintenance and proper use. The usual suspect is a gummed up wand or brew line or user error. Here’s what to look for and how to avoid it.
First, notice what kind of wand you have. Most semi-automatic and porta-filter espresso units will have wands that resemble those on bottom or right, although the tips may be different. Some tips do not slide up and down to alter the aeration, as the one on the bottom does. If your wand is from an older (1990s) unit, it could have a more bulbous tip and a smaller hole in the tip. wandte1.jpg wandte2.jpgSome of the new wands give you a manual/automatic control.
wandte3.jpg Many of the new super automatics come with an automatic frothing unit, like this one from Jura-Capresso. The nice thing about the frothing wands on Jura-Capresso's new units is that they allow for even more control.
The "Dual Frother Plus" (top) works like the traditional frothing wand. The metal sleeve goes up for steam, down for foam.
The "Froth Xpress Plus" is a very handy device which can be used with the included sleek milk container or a distinct milk container, like a 1/2 gallon jug. The Froth Xpress has a tube (hard for using the included container, flexible for using a different container) that fits into the frothing tube behind the dial shown in the picture above. After selecting froth or steam, the milk is siphoned into a cup below the steam wand. We recommend steaming the milk first, then adding the espresso.
Whatever sort of wand you have, it is essential to keep it clear of solidified milk which can gum up the tip and even the wand shaft. Here are some symptoms of a clogged wand:
  • Little or no steam comes out of the wand
  • Hot water drips from the tip of the wand
  • A squeal or whistle comes out of the wand when the steam function is selected
  • A deep humming is heard when the steam function is selected*
*This is also a symptom of another more serious problem, particularly if you have a pump espresso machine; so if unclogging the wand does not solve it, you should contact a technician.
A good preventative measure against the clogging of a steam wand is regular rinsing in warm, soapy water of the tip and any other removable frothing part. This should be done after each steam wand use. If your machine has a Froth Xpress, it is important to clean all of the hoses, valve, and connectors (be very careful with the plug, however, because it is delicate). All wands should also have steam jetted through them after a frothing cycle is run.
Another preventative measure is to run a steam cycle for about twenty seconds before each new use. This will eject stray particles before they can build up and cause serious damage. There is also a cappuccino cleaner available which can be used in the automatic frothing devices. The solution is placed in a reservoir, and a full cycle is run until the reservoir is emptied. This can be done every few weeks or every few months, depending upon use.
Aside from prevention, there are treatments for a clogged wand. First, remove the tip, if the tip is removable. Usually they are, as in the case of the plastic tips above. The holes are usually big enough to run a pin or even a small paperclip through (emphasize small) to remove the gunk. If these items are too large, do not attempt to use them; instead try using a thin gauge wire from an electrical wire strand. Next, the metal wand itself can have a pipe cleaner run up into it. Start out by putting just about a half inch of the pipe cleaner up the wand, rubbing it around, then pulling it out. Gradually work more of the pipe cleaner up the wand, but never let the length of pipe cleaner in the wand exceed the wand length. We recommend the pipe cleaners with the stiff barbs attached, as opposed to the mostly soft ones. Do the same for all of the hard hoses and connectors. With respect to rubber or soft plastic parts, rinse them in soapy hot water. If flexible hoses form holes, replacements are available (give us a call) or we've even had some luck at aquarium supply stores.
PLEASE NOTE: if you own the Jura X7 or the Froth Xpress Plus, the diameter of the tiny holes is very important. We recommend trying not to put pins into these holes. However, if they must be cleaned and soaking won't work, a smaller gauge wire, a single strand, should do the trick. Always use a strand that is smaller than the diameter of the hole.
Frothing wand technology is advancing at a breakneck speed, but along with these advances come serious precautionary measures for dealing with these very delicate mechanisms. Follow the steps above, and your machine should be producing full-fledged froth for its entire life.
May 26, 2008 | DeLonghi Esclusivo Magnifica ESAM3300...
Milk frothing problem on a Magnifica 3500
Had the same prolem replaced the coupling where the jug clips in. Item 111 - part number 5532123200 coupling. If your not technically experienced then you may need to take it to a service agent. Had to fairly well dismantle machine to complete repair.
Apr 07, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
Why won't my starbucks serina froth milk. Just stopped doing this all of a sudden. I descaled, the little hole in wand isn't blocked. The milk heats but no froth.
This problem developed on my Sirena machine about a week ago. Stopped frothing milk, but still produced lots of steam. In fact, it was splattering milk everywhere, just not producing foam. Cleaned the steam wand (including air intake) and descaled the machine (even though its only 3 months old) to no avail. Called Saeco customer support (1-800-933-7876) and the very helpful rep immediately identified the problem. Inside the Panarello steam wand is a removable plastic tube. The tip of this tube should protrude about 1/8" beyond the end of the steam wand. Mine was not. Using the eraser end of a pencil, I pushed the inner tube downward into position and, voila, I now have froth again.
Nov 23, 2009 | Saeco Starbucks Sirena Espresso Machine
Frother builds up too much pressure and explodes off the machine
I had the same problem. All you need to do is take the steam nozzle apart and clean it. I tip can be cleand with a neadle. Just make sure you unblock the little side holes and make sure to thoroughly clean the little hole in the front. Over time the milk builds up in the nozzle, clogging up the "steam holes", so the preassure gets too big and the rubber attachments can't hold it any longer. Hope that helps.
Jun 05, 2009 | Jura Capresso F8 Espresso Machine
I have a Delonghi Magnifica Rialto EAM4500 coffee maker. Recently it has stopped frothing milk. Per delonghi I have replaced all of the gaskets that connect between the milk container and the unit. When we...
I purchased a unit second hand for my wife's birthday today. It's only 4 months old, got it home, tested it, same problem... No froth!
I've read all the posts here and all were very helpful troubleshooting guides however they did not solve the issue.
Understanding how the frothing mechanism functions is half the battle in figuring out the solution. It's a simple vacuum type system. No doubt you've read about checking the orings. This is definately the first thing to check however if this is not the reason then consider the following.
The larger of the white tubes that has the red and black oring inserts deep into its port on the tap. Why? It pushes steam past the milk pipe directly into the chrome frothing tube which causes a vacuum essentially drawing milk up it's hose creating the froth. What you can't see without further investigation is that on the underside of the tube centered between the red and black orings is a small hole. This hole is responsible for drawing the milk upwards. If this is blocked, and it probably is then no milk and no froth. Use a really small screwdriver to carefully clean the white tube both from the front and the little hole underneath.
So in conclusion. Any air leak between the red and black orings will prevent the vacuum required to draw milk up the tube and alternatively any blockage of the milk channel will also obviously prevent the flow into the frothing mechanism. Hope this helps.
Apr 09, 2009 | DeLonghi Coffee Makers & Espresso Machines
How do I make cappuchino cofee?
If you are looking for a manual, you can contact Jura Capresso directly. If you are just looking for directions for making a cappuccino in general:
Brew the espresso.
Use the steam wand/frothing element and a pre-chilled frothing pitcher (the pre-chilling is optional, but it is considered good form) to steam about 1/4 to 1/2 cup of milk.
A true cappuccino does not involve pouring all of the milk directly into the espresso - you would use a spoon to take about two spoonfuls of the top of the steamed milk and place it on top of the espresso.
You can sprinkle cinnamon, use a cinammon stirring stick, or pour cinnamon cappuccino flavoring on top of the cappuccino for good form (but this part is optional).
Enjoy!
-Tha Mp3 Doctor
Mar 22, 2009 | Jura Capresso CapressoBAR 351 Coffee...
Steam does not come out of steam pipe
If you wait too long after making the coffee, you will not have enough water left to make steam. Try to steam the milk immediatels after the coffee loses pressure.
Jan 16, 2009 | Spidem Divina De Luxe Espresso & Coffee...
Steam and froth malfunction
The milk can not be room temperature.  It needs to be cool, does not have to be fridge temperature but can not be warmer than room temperature
Feb 18, 2008 | Jura Capresso Impressa Z5 Espresso/Coffee...
Frothe the milk?
he trick to this is making sure you have steam comming out of the wand and not water. To do this, make sure you get the steam started before you begin. To get a light foam that will not deflate, hold the wand just under the surface of the milk. You should hear a steady, high pitched noise and you should not hear the splatter of bubbles popping on the surface. Popping noises mean that the wand is too high in the milk and your froth will not hold up. A low pitched noise from the cup means that the wand is too far down in the milk. This will heat your milk (for hot chocolate), but will not give you a good foam. Good luck!
Dec 27, 2007 | Jura Capresso CapressoBAR 351 Coffee...
Jura Capresso Impressa S90 Espresso Machine Logo
684 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
