Question about Flip Video Camcorder
On the view screen and play back the picture is warped with many rainbow colors.
  • 3,083 Answers
This is hopefully just a ribbon cable that has come ajar a bit. You will have to disassemble the camcorder to reseat it. I've never worked on this kind of a camcorder, but just go slow, and take pictures as you disassemble it as you go (with another camera, if possible). The ribbon connectors have a thin, rectangular plastic tab on top. You can gently lift them with a very small screwdriver blade or fingernail, then reseat the connector end, and gently push it back down to lock it. If you're not sure what to do, there are youtube videos that show how. If you reseat all the connectors and still have the same problem, some other electronic component is bad, and the unit will more than likely not be worth repairing, since the cost is usually high. Get an estimate before having it repaired, often replacement is a better option (except for the very high end camcorders). Good luck, hope this helps.
Posted on Apr 28, 2010
Vizio 46lfhdtv20a verticle rainbow line down the screen. picture start playing and after a while the color line cover the screen
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 29, 2016 | Vizio VO47L 47 in. LCD TV
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
Tv fell off stand. tv has vertical rainbow lines on right side of screen. how do I get rid of the lines?
Color patches due to strong shock or vibration cannot be eliminated by anyway, to CRT type TVs. Gopakumar Gopalan Google
May 10, 2014 | Proscan Televison & Video
The picture can be seen, but it seems to have a rainbow aura and looks concaved...although the screen is not warped in any way...it was working perfectly last night...turned it on this morning, and we were...
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2011 | Sony KP-65WS500 65" Rear Projection...
Double screen and rainbow like colors
my media player does not play occur eror in error show capture video failed, show no sound device or show input is failed
Feb 27, 2010 | RCA Televison & Video
Sharp 46" 6 months old see rainbow colors from left to right
Did he change the big video board?The main backlight video baord that the prob.
Oct 23, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Rainbow of colors on screen
I just had a rainbow of colors on my tv screen...i thought it was a problem with my TV...however the screen went the "sign off" screen (verticle lines-red/blue/green) Then all of a sudden the picture came back and all was back to normal again.
So I say it's nto your TV it is a station problem!
Aug 04, 2009 | Panasonic Televison & Video
52 inch tv has a warped picture with a rainbow type ark at top
This set needs a major repair. there are bad connections on the power board and a fuse is blown. You pretty much need a technician to fix this.
Mar 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Mitsubishi diamond hd1080
It sounds like you will have to replace the convergence IC's in this TV set. Not a really hard repair to do but you will need to know how to solder and work on solid state printed circuit boards. Good Luck
Jun 29, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Rainbow of color when viewing DVD
TRY TO MATCH THE SYSTEM OF THE TV AND DVD. IF ITS NTSC SET IT BOTH WAY OR IN OTHER SYSTEM
Jun 06, 2007 | JVC AV-32120 32" TV
Flip Video Camcorder Logo
Top Flip Video Video Cameras Experts
matt
matt
Are you a Flip Video Video Camera Expert? Answer questions, earn points and help others
