Question about Dell Inspiron 1525 Laptop
Dell inspiron 1525 does not power up. i powered
Dell inspiron 1525 does not power up. i powered down as normal. but screen light stayed on. i took batter off to turn light off. i tried to power back on, and it did not work. I then went to plug in and still nothing. what could be causing this?
  • 561 Answers
Hi
Thank you for yuor query
Please can you try the following
1) Remove battery
2) Remove wall charger
3) Press and hold the power button in for 30 seconds
4) Plug in wall charger only
5) Retry powering the laptop and if it switches on plug battery in after 5 minutes
Regards
Shauqat
Posted on Apr 28, 2010
INSPIRON 1525 NOT STARTING UP
Try taking the battery out then holding the power button down for 30 seconds (this clears the power in the machine), then power back on and hopefully should work.
Apr 15, 2013 | Dell Inspiron 1525 Notebook
Inspiron 1525 charging problem
Try the following steps to solve it:
it of googling on the web and finally found the solution here.1 Turn off laptop.2 Unplug AC power.3 Remove battery.4 Replace AC power.5 Turn on laptop, allow OS to boot.6 Once logged in to the machine, perform a normal shut down.7 Unplug AC power.8 Replace battery.9 Replace AC power.10 Turn on laptop, allow OS to boot. The battery should once again be charging as normal.If it can't still resolve this problem, try a new laptop charger or repair your laptop dc jack.
If you plan to be on a budget for your dell 1525, you may try the following third party charger:
Replacement Dell Inspiron 1525 AC Adapter 65Watt 19.5V 3.34A
Oct 20, 2012 | Dell Inspiron 1525 Laptop Midnight Blue
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Last night with I turned on my Dell inspiron 1525 notebook..the screen when white and shut down...I turned it back on and it kept going throught this routine over and over..I was able to keep it on long...
here are some troubleshooting steps: like before remove the battery and the AC adapter, then connect just the AC, see if the LED on the adapter goes out or stays on. If it goes out, see if another adapter (known good is available) or see if you can try one at Bestbuy or such. If the system powers on, then replace the AC adapter.
If no power with a known good AC adapter, then the failure is likely the motherboard or the power board. You can try the powerboard 1st
http://shop.ebay.com/?_from=R40&_trksid=p3907.m570.l1313&_nkw=inspiron+1525+charger+board&_sacat=See-All-Categories
motherboard 2nd
http://shop.ebay.com/i.html?_nkw=inspiron+1525+motherboard&_sacat=0&_odkw=inspiron+1525+charger+board&_osacat=0&_trksid=p3286.c0.m270.l1313
manual here
http://support.dell.com/support/edocs/systems/ins1525/en/SM/index.htm
Sep 10, 2010 | Dell Inspiron 1525 Notebook
When i start up my dell inspiron 1521 it goes into startup mode then screen goes black.took the power cord out n it will start up plug it back in the screen will go blank again.it will run on battery n the...
I have a Dell Inspiron 1525 and had the same exact problem. I finally called Dell and they sent a tech out. They replaced my power cord and all the software. The reason for this is because Dell Inspirons has a default in the AC cords. Sounds like the AC power cord is the problem. You could find someone who has this cord and test your Inspiron with it or try calling Dell! It worked for me.
Jan 28, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
Dell inspiron 1525 notebook will not start windows
Usually this happens when the vista boot loader fails. During boot up, keep tapping F8 and then select Disable Automatic Restart... and get the stop error code which usually starts with 0x
Jun 09, 2009 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 won't turn on
check the dc power jack connector, open the board. but if under warranty don't open it, bring to warranty..
Jun 05, 2009 | Dell Inspiron 1525 Laptop
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1525 Laptop Logo
184 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
