Question about Fisher and Paykel Dryers
What is the easiest way to disassemble a DE08 dryer cabinet?
What is the easiest way to disassemble a DE08 dryer to access the bearing? How do I disassemble the cabinet?
  • Fisher and P... Master
  • 8,220 Answers
Weird dryers ain't they? I have a F&P dryer manual. DEGX1 model would you like to have that?
Posted on Apr 28, 2010
2 Suggested Answers
  • 552 Answers
SOURCE: What is the easiest way to disassemble a Fisher Paykel DE08 Dryer
The video below explains how to take apart a fisher paykel dryer, to do so is pretty simple the dryer repair video should aid you in your appliance repair troubles.
http://www.youtube.com/watch?v=g0Yf2tRE_dA
Posted on Mar 06, 2011
I have a Frigidaire front load dryer that is squeaking. How do I locate the rear bearing so I can grease it and what do I grease it with?
Thank you for your inquiry, Tiffany Garrison Gerling!
I understand you would like to access the rear bearing of your Frigidaire dryer in order to apply grease to it. The grease you would need to use is high temperature grease you would use it because it can withstand the temperature your dryer can get to. I would recommend seeking assistance from a professional technician for proper disassembly of your dryer. Incorrect disassembly could cause personal harm or future issues within the dryer. Best of luck! -OOS
Jan 05, 2015 | Frigidaire AEQ6700FE Affinity Electric...
Whirlpool dryer,model WED5300VW0 is snagging my clothes. How can this be fixed?
hello. You are going to need to inspect the bearing and front seal on the front of the drum, and also the bearing ring for front support. The rear of the drum is supported by two rollers underneath. First of all, here is a parts diagram for your dryer. On this first one, you can see the bearing ring for front support. Part number 36. It will need to be inspected for wear.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5513301&diagram_id=28263302#d28263302
The next thing that I would inspect is the front bearing and seal, which is part number 38 in this diagram. It will need to be inspected also.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5513301&diagram_id=28129401#d28129401
When these things are worn, it can cause the drum to drop slightly and snag your clothes. In order to take a look at these things, your going to have to know how to disassemble your dryer.
You do this as follows;
Pull your dryer out from the wall to avoid hitting the wall when you raise the cabinet top. Lift the lint screen access cover and remove the two screws inside. Do not remove the actual lint screen before you remove the screws. Removing the lint screen first could lead to accidentally dropping the screws down the lint screen shaft and into the blower wheel.
If your older Whirlpool clothes dryer model has a kickplate, remove it first. You can either pop it off, or pry the kickplate off the interior spring catches. Depending on your model, you may have to use a putty knife to push in on the spring catch at the center of the top of the kickplate. With the kickplate removed, proceed to lift the cabinet top.
Use a putty knife, or some other thin and flat object to wedge in under the cabinet top. Your goal is to push each of the two interior spring catches back out of the way, thereby releasing the cabinet top. The spring catches are located one on the left side under the cabinet top and one on the right side under the cabinet top.
Loosen the two bottom screws securing the front panel to the unit. Do not remove them just yet. Locate the two screws at the inside top of the cabinet. They also help to secure the front panel to the dryer unit. Remove these two screws. Balance the front panel as best you can as you remove the two bottom screws that you have just loosened. Disconnect the wire leads connected to the door switch. Hold the dryer drum in place and remove the front panel of your dryer. Some models may have extra screws holding the front panel in place. If you are having difficulty removing the front panel, do a check for more screws.
Reassembling the entire unit is basically the disassembly process in reverse. Reattach the front panel of the dryer in the same manner you took it off. Make sure you reattach the wire leads to the door switch, and replace all of the screws that were earlier removed.
http://www.repairclinic.com/PartDetail/Drum-Slide-or-Glide/3406129/2702?modelNumber=WED5300VW0#repairHelpVideoTabs You will want to watch this. It will tell you how to replace the seal on the door.
http://www.repairclinic.com/PartDetail/Drum-Support-Bearing/279441/2683?modelNumber=WED5300VW0 this will show you how to replace the ring seal on the drum.
These are so detailed, I think it's all that you'll need to complete job. These whirlpool dryers are not hard to work on once you know how to do it.
I really hope this helps you. I hope that everything you need is covered here.
Thanks,
Mike
Aug 06, 2011 | Dryers
MY FISHER & PAYKEL DE08 IS MAKING A LOUD BANGING, RATTLING NOISE. i TOOK IT APART AND I BELIEVE IT TO BE THE IDLER ARM OR THE SPINDLE BEARING. THE MAIN BEARING DOES NOT SEEM TO BE WORN. THE IDLER...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 23, 2011 | Dryers
I own a FP dryer model DE08-US1, and it is making a high-pitched squeking noise and smells like burning rubber--please help.
I suspect your drive belt is slipping or a worn bearing, you need to have this checked by a Qualified serviceman. Get a firm "Quote" before proceeding.
Jan 31, 2010 | Dryers
Need to disassemble a kenmore elite oasis dryer
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 03, 2009 | Kenmore Elite Oasis ST 6806 Electric Dryer
I need to know how to take the back off to get at the belt and bearing
DHDSR46EGWW Dryer
Go to;
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5240324
Click on the diagrams in the left-hand side. This will show how the cabinet comes apart. You can print these out. The Cabinet diagram will show how to disassemble the cabinet and the Backsplash, blower & motor diagram will show the belt location.
Apr 17, 2009 | General Electric DHDSR46EGWW Dryer
Maytag pye2300ay dryer grinding noise from front
You generally have to open up the cabinet from the back by unscrewing the fasteners.
Feb 06, 2009 | Maytag PYE2300AY Electric Dryer
Kenmore dryer
It is very much easier to replace the belt from the front, than the back, the cabinet disassembles from the front, and the mechanism remians attached to the rear plate and cabinet floor.
  • pull lint filter out
  • remove 2 screws from under lint filter
  • with putty knife or other blunt blade, release clips at front corners of cabinet top
  • tilt up cabinet top
  • remove 1screw 1/3 way down each side of front of cabinet.
  • lift off cabinet front
  • drum, motor, tensioner, are all exposed
  • lift drum out forward
  • check rollers, drum felts, nylon glide bearings for wear
    (worn bearing surfaces are the most common cause of belt breakage and you dont want to do it again next month)
  • reinstall tensioner in slots in cabinet floor, reinstall tensioner spring between tensioner and cabinet floor
    (Once the cabinet is open the tensioner mounts are easily visible)
  • loop belt around drum at the wear marks of the prior belt
  • reinstall drum on unworn bearing rollers etc
  • loop belt around motor pulley
  • pull tensioner hard against spring to end of travel
  • loop belt around tensioner
  • relax tensioner
  • spin drum by hand to ensure belt isnt going to jump off
reinstall cabinet in reverse order
~15 MINUTES, but I do 3-4 per day
Oct 07, 2008 | Kenmore 62602 Electric Dryer
How to replace drum belt.
Opening the cabinet and removing the drum of GE dryer models
Note:
Disconnect the power source to your dryer before you begin to remove the drum. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Pull your dryer out from the wall. Behind it, on the bottom, you will find a lower panel that will give you access to the unit's belt tensioner (also known as an idler pulley arm). Remove the screws holding this panel in place, and then remove the panel itself. Reach inside and release the belt tension by removing the belt from the motor pinion.
Older GE dryer models have a small drum bearing inspection plate in the center of the back of the dryer. This drum bearing inspection plate provides access to the dryer's circlip (also known as an e-ring). This clip holds the rear drum shaft in place. Newer models do not have this circlip or the drum bearing inspection plate.
If yours is an older GE model with an inspection plate, remove the plate now. It will be held in place with a single screw. With the plate removed, you will be able to see the drum support shaft and the e-ring (circlip) holding the shaft in place. Use a small screwdriver to remove the e-ring. You may also want to use a magnet to keep the circlip from falling into the dryer. You will also find several metal and nylon shims between the bearing and the e-ring, inside the bearing, and between the bearing and the drum. Take careful note of how they come off so that you will be able to put them back on again in the right order.
Now remove the front panel of the dryer. There are a couple of different ways this is accomplished. Whichever method you use is dependent upon your model. Some older models have two spring catch clips under the cabinet top, one on the left side, and one on the right side of the front. Use a putty knife, or some other flat and thin object to wedge in under the cabinet top. Release both spring catches and lift the cabinet top off the dryer. In some newer models, there will be screws joining the cabinet front panel to the cabinet top. You will have to open the door in order to find these screws. Once they are found, remove them and then slide the cabinet top forward and lift it off the unit.
Next, there are two screws located in the bottom of the front panel, one in each corner. Loosen these, but do not remove them just yet. Locate and remove the two screws at the top inside of the dryer's front panel. Again, there is one screw in each corner. Proceed to remove the other two screws you have just loosened. Disconnect the door switch wires and then lift the front panel off your dryer. With the front panel removed, lift the drum and slide it out of the dryer.
NOTE: In some models, you will have to remove the dryer drum glides before you can remove the drum. Also, now that the interior of your dryer is completely exposed, it might be a good time to vacuum out all of the dust and lint that has built up in there.
Feb 05, 2008 | Dryers
Open Questions:
Dryers Logo
136 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
