Kenmore 31912 Progressive Direct Drive Bagged Upright Vacuum
Problem for Kenmore 31912 Progressive Direct Drive Bagged Upright...
Kenmore Progressive 100
By tex33 on Mar 24, 2008
My roller brush won't turn. I took off the top to check it out, I have a new belt, and when I manually pull the belt it does turn the brush, but otherwise it won't turn, seems very stiff. The machine has excellent suction.
Same Problem
Apr 22, 2009
-   I ran over a dog toy with the vacuum. The suction is good on it. I noticed the roller brush is not spinning anymore. What do I need to check to fix this problem?-   Guest
May 08, 2008
-   roller brush does not turn suction seems normal i thought it might be a belt problem but i didnt see a belt when i took top off i have model 31912100-   Guest
Best Solution
posted on Mar 25, 2008
Helpful)
reddevil6
Rank: Guru  Kenmore Expert
Rating: 88%, 1799 votes
Check the brush roll ends, make sure they turn freely, if not then replace it. The belt may look ok, but they stretch after a short time and should be replaced.
Was this helpful?
Yes
No
Popular Solutions for Kenmore 31912 Progressive
Questions and Unsolved Problems for Kenmore 31912 Progressive
Do you recommend Kenmore 31912 Progressive Direct Drive Bagged Upright Vacuum?
Answer
Answer
on my Kenmore Progressive Dircect Drive upright bagged vacuum, one day the motor was working hard,... (More)
Answer
I took my vacuum cleaner apart to clean it because it was clogged inside and now I am having trouble... (More)
Answer
I'm not sure if it is a worn belt or a worn agitator as mentioned in the instruction book but I'm... (More)
Answer
I don't know how to get the vacuum apart to get to the connection inside the vacuum.
Describe your Vacuums problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Vacuum Experts
Top Vacuum Repairmen
in , IL
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
