Question about LG Microwave Ovens
How to remove cockroaches, from the inside door of Microwave Ove
How to remove cockroaches, which have gone inside the door of Microwave Oven, Model No. MH6347AR of LG make?Also please advise me about the process of cleaning the said machine, inside and outside of it.
MicrowaveSvc
  • 9047 Answers
SOURCE: Removing the microwave door
In many cases, microwave door panels are held together by hidden hooks or catches that ave to be separated by a thin, strong tool such as a putty knife. I've attached a photo that should serve as a good example.
Posted on Apr 17, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave door has burn spots on the glass of the door...
The brown spots are usually grease / smoke deposits. Usually there are indeed two sheets of glass in the door. If the grease is not arcing or smoking, and the metal screen / mesh (that blocks microwave leakage) is not damaged, then it's likely better left alone. It might be useful to boil a few cups of water with a little vinegar inside the microwave to help dissolve the deposits. In case you want to take it apart, I have attached a photo from a similar model that illustrates disassembly of the door. It is not necessary or advisable to remove the door or hinges when disassembling the door.
Posted on Jun 26, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: paint inside microwave oven, Can it be repainted ?
Yes. You need to clean it, sand it shiny, then clean it squeky again.
Then you can get high temperature appliance paint in spray on brush-on form from local appliance part store or places like Wal-Mart and Lowe's.
I would suggest you let it dry overnight with the door open before using the oven.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 17, 2008
i have the same problem, there is a brown spot about 3 inch
by 2 inch at the bottom of the glass, I cannot clean it, it looks
like its in between the glass.
Posted on Jul 30, 2008
rickzilla
  • 706 Answers
SOURCE: LG microwave oven
As long as the waveguide itself isn't damaged, you should be able to replace the shield without issue... That shield only prevents food from splashing onto the waveguide itself and is not part of the microwave RF protection... Check your local hardware store for touch up paint.. shouldn't matter what brand as long as it contains rust inhibitors.. Good luck...
Posted on Aug 23, 2008
Can you remove the microwave separately without removing the complete oven/microwave unit? KEMS307DWH4 KitchenAid Wall Oven/Microwave combo unit
Hello Richard;
My name is Peter. I am a retired field service technician.
Your microwave is in a separate housing than your oven. You need to remove the border stripping holding the micro wave in the wall, then lift up in the front and pull out.
Go into the following website, put in your model number which is on a label after you open the microwave door.
You did not tell me what the problem is. Please advise so I can help you further.
Mar 26, 2016 | Microwave Ovens
MY KITHCENAID MICROWAVE MODEL KHMS155L TURNS ON BY ITSELF,OCCASIONALLY WILL GO TO F2.
Possible fault with the customer touch pad or the controls. Sometimes this is caused by insect secretion - cockroaches- which can make the controller processor board act with such erractic behaviour.
Try to remove the power, remove cover and remove the main controller board and control pad to be washed, cleaned and reset. take care of the strip connection and wires.
Oct 19, 2011 | KitchenAid KHMS155L Microwave Oven
I have an Emerson MW89998B microwave. When trying to use it will spark and smoke. Any suggestions on what might be causing this. Have cleaning it and clean it weekly.
It is possible that your magnetron is heating up some soft spots inside the oven or there is a damage to the feed wires to the maggnetron or to the main capacitors. But before we start, I want you to be very careful. Remove the power and use a good flash light to look inside for the mountings near the magnetron-- a square/round fitting top right side of the oven when viewing from the front. If there is any possibility that your have not used food covers, some food could have splurted on to this and made it soft due to heating on the food. If so, you will have make a clean dry wipe, let it dry for some time before you test. If fault stays visualise the spot of smoke and invetigate . If you are powering the set with the cover removed please be very careful. replace the capacitor, wires or any insects/ cockroaches that have got entanged. hope you find this advise helpful Good day
Jul 22, 2010 | Emerson MW8107WA Microwave Oven
I have the part I need, but I need to disassemble the door to install it. I don't see a way to do that...Model LMVM1945SB
Remove the outer cover from the microwave oven to gain access to the door hinges. With the door off, and lying face down on the table, carefully pop-or-pry the plastic door seal off the inside. Presto, access.
Nov 12, 2009 | LG LMVM1945 Microwave Oven
My microwave is locked and i dont know how to unlock it
"Locke" meaning the door? or locked meaning the buttons don't work? If it is the buttons then you have the child lock on. Push and hold the "Start" button for 4 to 5 seconds, and it will unlock.
Mar 12, 2009 | LG LMV2083SW Microwave Oven
Door slammed and no microwave is dead
yep you got it in one, I must have advised about 10 people today about this. when the door is slammed the door protection circuit does not operate correctly and then takes out the mains fuse inside the unit. renove the case and locate the fuse, normally where the cable enters the unit. as long as the fuse is the correct amperage, lenght and diameter you have no problems. do not test the unit with the cover off and be careful as the capacitors can hold a lethal charge
Feb 19, 2009 | LG LMV2053 Microwave Oven
GE Eterna Microwave
Hopefully you didn't disturb the hinges to remove the door, since that will require alignment and testing to be sure it is not leaking.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 08, 2008 | GE JVM1650 1000 Watts Microwave Oven
Cleaning inside of microwave door
THE DOOR ON MY MAYTAG MICROWAVE OVEN HAS A SCREEN OVER IT. I HAVE SOME FOOD SPATTERS THAT PENETRATED THE SCREEN AND I CAN'T CLEAN THE GLASS THAT THE SCREEN PROTECTS. HOW CAN I REMOVE THIS SCREEN TO CLEAN THE GLASS?
Oct 01, 2008 | Maytag MMV1153A Microwave Oven
Door outer plastic plate slide down an inch from the top
You would probably need a service manual, for which you can contact LG at 1-800-243-0000 or http://us.lgservice.com
Or locate a local servicer:
http://us.lgservice.com/gcsc/b2c/hpi/main
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Nov 19, 2007 | LG LMV1645 Microwave Oven
Jun 25, 2007 | Goldstar MV-1501 Microwave Oven
Microwave Ovens Logo
1,011 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
Devabhakthuni...
Devabhakthuni...
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
