Question about Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac
Gas-oil mix? gas-oil mix, what are the proportions?
    Sniper:
  • 52 Answers
Usually if you use the brand the 2 cycle recommends (their brand of oil) it's 4 oz. to one gallon of gas. If you use a generic brand they say mix it 6 oz to one gallon. Most will run fine on the 6 to 1.
Posted on Apr 28, 2010
Need to know two stroke mix
usually indicated on the bottle of two stroke oil what proportions you need to mix, or on your saw's user and care guide
Oct 10, 2014 | Saws
What is the fuel mix required?
Pirelli an amazing walk on Christ The Redeemer
HB 180v home light mix at 32 to1
read it on the oil can, bottle, put 1 gal gas in first a marked clean gas can, and ad oil last watch the gas pump not the can, and stop at what amount of gas you need get 100 percent gas in all your trimmers ,blowers! // if the can you are going to use only has a small amount pour it out it might have water in it and that's another story. Rideau Canal Oil Gas Fuel Mix Tables and watch this neat video Christ The Redeemer!
Aug 21, 2014 | Garden
3650 generator won't start!!
I assume that the spark plug are good and the gas line is clear. Try to adjust the gas line supply and default engine startup revolution settings try it full half and minimum back and forth it works. Other gen sets requires a mix of oil with its gas, please do it when it is required with exact proportion. Hope this helps. Goodluck.
Mar 18, 2014 | Husky 3650 Watt Generator with Subaru...
Husqvarna trimmer 125ld trouble shooting
Carburetor adjustments are needed for idle mixture and high speed. The piston rings may be excessively worn from the abuse by the previous owner.
Oct 19, 2017 | Garden
Do I mix the oil and gas together and pour it in the gas tank or do I pour the gas in the tank and the waverunner mix's the oil and gas together?
Mix the oil and gas together first.
Or you can add some gas into tank, then add some oil, then add more gas, then bit more oil ... so oil-gas mixture is uniform.
Jun 24, 2012 | Boating
Won at my kids kempo class gio ya49 model what do i need to do to start it not sure if straight gas or mix also do i add oil anywhere thanx
You are going to need more information before you start this up.
You need to know whether it is 2-stroke or 4-stroke.
You need to know the manufacturer, I see some use 25 parts gasoline to 1 part 2-stroke oil. Other machines use a different proportion.
If it is this manufacturer, mix say 25 ounces of gas with 1 ounce of 2-stroke oil in a separate container and pour into gas tank.
If it is 4-stroke, you will need oil in the crankcase, not in the fuel tank.
Try to find the name of the bike/quad somewhere.
Dec 21, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
WHAT TYPE OF FUEL, STRAIGHT OR OIL/FUEL MIX & WHAT PROPORTIONS ?
Determine if your engine is a two-stroke or a four-stroke. Check the gas tank on your lawnmower or the owner's manual to determine what type of engine you have.
Read the label of your two-stroke oil. Follow the directions on the package to ensure the right mix.
Measure and pour the gasoline in to the empty gas can.
Add four ounces of two-stroke oil per each gallon of gas.
Replace the cap on the gas can and shake the oil and gas to mix. Add fuel to your engine.
Take care.
Jun 01, 2010 | Garden
What oil do you use in the four cycle motor/ 29cc
Generally speaking, if there is a place on a gas-powered device that is labeled "gas" & a separate location labeled "oil" than you will need to use a 4-cycle oil for that machine. If there is just a place to put gas, you would use a 2-cycle oil; however, you would need to read the directions/manual to find out the correct proportion of oil to use, because you will have to MIX the appropriate amount of oil with the correct amount of gas, making a oil/gas solution that you would use for that specific device.
May 31, 2010 | Craftsman 29cc 4Cycle Straight Shaft...
Ryobi PSC 3046y3e 30 cc petrol strimmer ratios of petrol to oil
WELL IF THERE IS NO 2 STROKE OIL TANK THEN YOU MIX IT WITH THE GAS. THIS IS HOW THE ENGINE GETRS ITS LUBRICATION AND WILL BLOW UP AND SEIAZE WITHOUT IT.MOST OF THESE SMALL ENGINS RUN AR 20 TO 1. OUTBAURDS RUN AT 50 TO 1. IF YOU PUT TO LITTLE ITS NO GOOD AS MENTIONED ABOVE. IF YOU [PUT TOO MUCH IT IS NT AS BAD AS IT WILL SMOKE A BIT AND POSSIBLE FOUL THE PLUG AFTER A WHILE. I WOULD GO WITH 230 TO ONE THAT WOULD BE 20 PARTS GAS TO 1 PART OIL 20GAL GAS TO 1 GAL OIL IS THE SAME AS 5 GAL OF GAS TO 1 QUART OIL OR 2 1/2 GAL GAS TO A PINT OIL OR 1 1/4 GAL GAS TO 1/2 PINT OILM GET THE PICTURE NOW. ITS DIVISION. AFTER A WHILE OF RUNNING IF IT SMKES AND THE PLUG FOULS JUST ADD A BIT MORE GAS TO YOUR MIX AND CLEAN THE PLUS WITH AN OLD TOOTH BRUSH AND I ALWAYS MARK MY GAS CAN WITH BLACK MARKER OIL/GAS MIX 20:1 OR WHATEVER.
REGARDS, PAUL
Jun 20, 2009 | Ryobi Cultivator
Well since it's a 4 stroke I can't mix it with the gas. I drained out all the old oil and I just need to know the correct porportion of oil to re add to my bike
The proportion is 100% oil, don't mix it with anything. Put in two quarts, stand the bike straight up and check the oil. Add one half quart at a time until it registers full on the stick or in the sight glass.
Mar 09, 2009 | 1991 Yamaha XT 600 E
Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac Logo
254 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
