Question about RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
The only light that is blinking is the internet light and the modem cannot be turned off with the off switch.
    Problem Solver:
  • 15 Answers
To my understanding to reset this particular modem is to either
A) unplug the power cord / unscrew coaxil (cable wire)
or
B) If there is a battery light you need to remove battery from battery compartment.for 30-60sec and put it back in....
C) small pin hole on back of modem use a paperclip or sharp point and hold down for 10sec.
Posted on Apr 29, 2010
N300 router has a steady orange blinking light
The blinking orange power light suggests that there is a problem with your modem. The modem should be plugged into the top ethernet port of your router. Try turning off your modem for 10 seconds and then turning it back on.
Dec 07, 2012 | Belkin Computers & Internet
Tip
Troubleshooting DSL Modems
Ever look at your DSL Modem and wonder what all those lights mean? Why do some flash, while others remain solid? What if your lights are different colors? How do you tell if your DSL Modem is working correctly?<br /> <br /> Each light on your DSL Modem represents a function. The light is an indication of whether that function is working properly. Sometimes the placement and title of each function can vary by modem manufacturer, but they are pretty standard in interpetation. If you look closely your modem, you might find that each function is labeled in small print to help identify them.<br /> <br /> A standard DSL Modem has a light for power, internet, ethernet, link and wireless connection. A healthy DSL Modem will have a steady green light that does not blink or flutter for all features other than internet, ethernet and wireless. A flashing or fluttering light indicates movement and useage. When you are connected to your DSL Modem wireless, the light for this feature will blink indicating a connection and/or active useage. If the internet connection is working properly the color of the light will be green. If the connection is working but experincing a problem the light can turn to yellow or orange. If the connection fails, the light on the DSL Modem can be red or absent depending on the problem causing the trouble. If your service is turned off by the provider, more than likely the light will be "off".<br /> <br /> If your lights turn a different color, are absent or your internet connection fails try power cycling your modem before reporting the trouble to your provider. Power cycling helps the DSL Modem to reset its connection and repair your internet services.<br /> <br /> If you are using a DSL Modem alone to connect to the internet (no additional router) you can power cycle it by first turning off your computer and then unplug the modem itself from the power source at the wall. Wait for 1 to 2 minutes and then plug it back into the power source and wait for the warm up to finish before rebooting the pc.<br /> <br /> The DSL Modem should go through the normal warm up procedures of blinking lights, making them all stable and solid green ect. You will know when its finished warming up when the features are set at solid green (other than eithernet, internet and wireless connection as explained above). When the modem finished the warm up, reboot your computer and check your internet connection.<br /> <br /> Power cycling your DSL Modem can help keep your connection healthy and running at optimal speeds.<br />
on Mar 30, 2011 | Computers & Internet
Blinking Internet light on frontpanel.
Try to pull the wires and restart your modem if there are no changes you should ask fof techy assistance
Jan 01, 2018 | TP-LINK TDW8961ND 4Port 300Mbps Wireless N...
Can't access to internet service
Turn off your internet modem or router for about 5 minutes. After 5 minutes turn on you internet modem or router and turn on your computer and when you are already on your desktop click start and click run then type cmd and press enter. On the command prompt type ipconfig/all and press enter and the ipaddress and gateway will appear on your screen but in case there is or no ipaddress and gateway type ipconfig/release then type ipconfig/renew this process will erase the IP settings and renew the IP and gateway. Also check your modem or router if the lights of the modem are blinking, usually three or four lights that are blinking. If the two lights blinking only call your Internet service provider and ask for assistance that you are having difficulties with internet connection. Have a nice day.
Mar 18, 2011 | Computers & Internet
The internet is down the dsl light on the modem is blinking red
I experienced the same problem yesterday with my modem,the internet is down as a result of the fact that the computer doesn't recognize the remote modem,hence the dsl light blinks red,when the internet is up the dsl lights should blink green,the problem is mostly from your internet provider,few times from your computer.
The solution is so simple;
1.Remove the modem from your computer.
2.Shut down your computer.
3.Turn on your computer again after at least 3mins.
4.Insert the modem in your computer and connect to the internet.
5.It might take up to a few attempts before it gets connected to the internet.
Problem solved.
Dec 02, 2010 | AT&T Computers & Internet
Online light blinkin in motorola sb4200
1- Disconnect the power at the back of the modem.
2- Disconnect the internet cable at the back of the modem (the cable from the wall to the modem).
3- Wait at least 2 minutes.
4- Connect the internet cable back.
5- Connect the power cable back.
6- The lights on the front of the modem should start turning on one at a time; the top one first, the second one next...
If the on-line light still blinks, you might want to repeat the steps above after shutting down your computer. Turn on your computer if the on line light is OK (not blinking).
If all fails, call your internet service provider (ISP) to see if the service itself is down for maintenance, or if there is a problem with high-speed internet in your area.
If you have a router, you might want to power it off before trying the steps above. Turn it back on when the on line light is OK.
Usually, I call my neighbor who has the same ISP to see if their internet is down, before I call the ISP company.
Hope that helps.
Aug 22, 2010 | Arris SURFboard SB4200 Modem
Westell 6100 is blinking Ethernet and Internet lights and Media player buffers and times out. Help
ethernet light should no blink
check the LAN drivers..if possible reinstall them..do a complete powercycle.of the system.
Switch of the pc-modem-router..wait for 1 minute then switch on the router/modem wait for all light to come back-switch on the pc..if intermet light is blinking there might be an issue at the ISP's end.
Http://www.ikarmatech.com
cheers.
Sep 11, 2009 | Westell Wirespeed LiteLine 6100...
The 3 lights blink on and then off and on and then off etc.
try and restore your computer by clicking on start all programs, accessories, system tools then system restore, restore it back for a few days or a week even try that
Jan 24, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
RCA DCM425 DIGITAL CABLE MODEM (RCADCM425) Logo
757 people viewed this question
Top RCA Computers & Internet Experts
Julie Endres
Jose Velazquez
Jose Velazquez
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
