Question about Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer won't drain
  • Fisher and P... Master
  • 8,220 Answers
Could be something in the pump. The pump is on the bottom of the tub.
It has a locking tab which you release and then twist the pump a hair and it will fall out. Warning: Have rags ready! I have the original GWL service manual and the GWL 11 supplimental manual. Let me know if you want them.
Posted on Apr 28, 2010
SOURCE: Fisher & Paykel GWL11 Top-Load Washer troubleshooting
I've had my washer for about 8 years. I experienced the same problem - pump stopped draining the machine. I called F&P and "Patrick" told me that I need to 1) unplug the machine, 2) tilt up the front of the machine, 3) spin the pump (plastic blades) until they turn freely (usually counter clockwise) but I turn it both ways till it turns freely, 4) plug the machine back in and press the buttons to get it back where it was - this has worked every time to get the machine going again. I do a lot of "dog laundry" and I'm sure the rugs/dog hair cause the problem. Hope this helps!
Posted on Nov 16, 2008
gittos73
  • 244 Answers
SOURCE: Fisher & Paykel "clog Problem"
the water comes through 2 vavle 1 for washing and the other for rinsing more than likely that the rinse valve is down it will need replacing thats the more common fault for washers not rinsing
Posted on Aug 12, 2007
IFIXALL
  • 868 Answers
SOURCE: Fisher Paykel GWL11 Top Loader Washer
Please dont put any more money into this machine,if you wait long enough it will take alot more than a penny.
Posted on May 25, 2008
  • 1028 Answers
SOURCE: Fisher and Paykel GWL11 Question
no belts ..direct drive ..lean washer back pump is a twist lock no tools needed hose clamp can be removed with fingersremove pump and ck for lock impeller also ck the diverter valve just behind pump
Posted on Jul 17, 2008
  • 12 Answers
SOURCE: washer will not drain
90% chance that is the pump is pumping water at all, there is blockage between the tub and the drain pump. If there is no water coming out of the drain line. either extremely clogged(odd) or pump motor is bad, and windings are not allowing rotation.
Posted on May 14, 2009
Replaced water pump and control panel, have power, but just beeps.
Fisher and Paykel GWL11 Top Loading Washer
ths.gardenweb.com > Home Forums > Laundry Room
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... 4) (Rinse Phase) Drain the water, then lock the lid for spin. ..... I plug the power cord in and I have nothing on the control panel. ..... As the controller was only replaced early in January, I've flicked F&P NZ an email to see if it's still under ...
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesI removed the pump and control panel, found no blockage in the pump, so far ... Ihave just tried to fill my F/P machine but the water is just dripping in. ... I have aFisher Paykel washer have replaced the control module and now it .... washing machine MW612, stopped working and displayed beeping sound every second.
Jan 16, 2016 | Fisher and Paykel GWL11 Top Load Washer
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer starts but drum won't turn, it twitches and beeps then turns off with solid beeps
Hi ken
Can you turn the bowl & agitator by hand.
If it can't turn by hand, Your seal & bearings need replacing.
Feb 01, 2013 | Fisher and Paykel GWL11 Top Load Washer
GWL11 washer diplay won't light up or power on. drain pump leaked, replaced both, still nothing
your main board is out very come with a bad drain pump the new pumps and boards come with a fuse to stop this problem. water hit the pump and shorts out the board
Aug 13, 2012 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel Ecosmart WA37t26gw2 won't drain
Check your belts and replace if faulty
turn the pump by hand with belt off to see if pump is jammed
still no go, you may have a faulty electronics board.
Oct 30, 2011 | Fisher and Paykel GWL11 Top Load Washer
2nd 3rd and 5th lights on. washer stopped in the spin cycle and water won't drain. washer won.t come back on
Hi just read your posting.Do you still require help ?Please reply and I can help you rectify this fault.
Jul 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washer will not drain
May 13, 2009 | Fisher and Paykel GWL11 Top Load Washer
Jul 16, 2008 | Fisher and Paykel GWL11 Top Load Washer
May 11, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
758 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
