Question about Bissell 2050 QuickSteamer Upright Vacuum
Won't **** up the water
There is water thru the line, but when run the machine, it won't **** up the water. entzranch@gmail.com
  • Bissell Master
  • 43,501 Answers
Check for an obstruction in the hose...most likely you have something stuck in there causing the vacum not to work...
heatman101
Posted on Apr 30, 2010
I have a bissell pro heat 2x +and the water is not coming out of the hand tool or the carpet cleanerr
We are sorry about the issues you've run into.
This link gives detailed troubleshooting instructions for you: http://www.bissell.com/FAQDetail.aspx?id=1122&icid=ccrr
And this video shows easy maintenance items: http://www.bissell.com/how-to-videos/proheat-2x-machine/care/?icid=ccrr
If your machine continues to not spray, please take it to a BISSELL Authorized Service Center for warranty repairs. If you are experiencing difficulties other than no spray, the technician will let you know the cost for those repairs if your machine is outside of the one year warranty timeframe. You can locate a BISSELL Authorized Service Center at this link: http://www.bissell.com/service-centers/?zip=Enter%20your%20zip%20code&distance=50&icid=ccrr
One pointer that can help between uses is running water through the lines. First, put clean water in both tanks and set your unit to the heavy traffic setting for one pass. This will flush out any cleaning formula in the lines so your spray tips won't get build-up between uses, which can lead to a lack of dispensing the cleaning formula.
Jun 27, 2012 | Bissell 9500 ProHeat 2X CleanShot Upright...
No soap is coming out of the wand
Most likely it is clogged with old detergent residue. These get plugged when the old solution sets in the line and dries out and hardens. you will need to clean the lines out, you may have to disconnest them and run hot wather thru them to clean out. Always run pure water through the attatchments and clean after using cleaning solution to clean out the lines before storing.
May 11, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
My bissell steam cleaner will not spray any water or soap how do I correct this problem
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
kjgtllgj
Aug 23, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell ProHeat Rug and Floor cleaner. Won't
heatman101
sf
Oct 20, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Want to rmove sludge,organics from pod wihout rmoing the water
You may need to develop a centrifuge in line with your intake to throw off water, or a screened water take up which will drain back to your source, but it must be sealed while running.
Central vacs have an optional water pickup device that works in line for spills . I do not like these but the concept could help your scenario. The idea is that there is a short hose, then an inline pail with a drop bucket for the water and a flow thru intake and out port to the actual vac piping so the air can continue thru to the vac without carrying the water into the wall. Gravity makes the water drop and allows the air to continue down the vac line, but the sealed pail ensures you have continuous suction.
In your case you would have to rig a shutoff float as well. Look up a company called VACUMAX on the INTERNET. I think they might be of help as well if they are still in business,around Elmira Ontario, Canada
Sep 17, 2009 | Hoover U5507900 Elite Rewind Bagless...
My bissell pro heat 2X will not work, no water or solution comes out, what can I do?
I think the instructions should have the user rinse the solution passage with water. The soap probably clogged your spray nozzles. I had the same problem, I used a toothpick to poke to hole open again. The solution sprays only. I can't figure out why the water is not spraying out though.
Jan 24, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
No water or shampoo releasing
Take off the 2 spray nozzles and blow thru them, they may be clogged. You ay also try running a mix of water and vinegar thru it to help clean out the lines. May have a bad pump.
May 24, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Intermittent water spray or no spray at all with my Bissell proheat 9400
you may have a partial clog, try running a mix of water and vinegar thru it to see if it will clean out the lines and spray tips.
Apr 28, 2008 | Bissell 9400 ProHeat Upright Wet/Dry...
Brushes stop spinning after one minute
Check any filters that may be clogged, try running a mix of water and vinegar thru it, to clean out the lines and brush block. Brush block may be bad.
Apr 23, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
My shampool i
The heater may be plugged, Take out the 2 long screws and remove handle, there are 2 screws near the bottom just under the cord wrap, then the front of the handle asm. will come off. The heater is there, put off the hoses(don't mix up) and check the opening going into the heater. One or both is clogged up not allowing water to flow thru. Put it all back together and it should work, Running a mix of water and vinegar will rinse out the lines before putting the machine up after using it.
Dec 15, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell 2050 QuickSteamer Upright Vacuum Logo
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
