Question about TitanNet TITANTANKLESS. COM PRESENTS THE TITAN SCR2 WHOLE HOUSE TANKLESS WATER HEATE
Scr2 titan water heater. No hot water. Both red
Scr2 titan water heater. No hot water. Both red lights on. How do I fix it? titanheater.com has replacement parts but I don't know which ones I need.
On the left side of the board there is a 10K 5Watt resistor that gets loose from the board because of overheat and it needs to core solder back with soldering iron.
Posted on Mar 28, 2012
  • Ivan
    Ivan Apr 12, 2014
    yes.. that was EXACTLY the problem - thank you so much.. easy fix
    New Friend:
Some times the water get hot some times not
Posted on Aug 02, 2013
    Problem Solver:
  • 7 Answers
Look in in user manual and the lights should be codes to whats wrong
Posted on Apr 29, 2010
The heater does not turn off automaticly, red light is always on
I do know these tankless heaters should be asid washed inside each year, this may help ...
Jul 11, 2011 | TitanNet TITANTANKLESS. COM PRESENTS THE...
We used to have hot extremely hot water in both bathrooms. One day, the water became warm and ultimately cold in one of the bathrooms. Now, the water is also freezing in the bathroom where the water used...
Your check-valve has most likely failed at the switch.
The flow check valve works by opening when you turn the water tap. When it opens it closes a switch which turns on your heating elements. When this switch fails you will still have water flow, but no heat. Titan has parts for this but you will need to call their service Dept.
or call
Toll free support pesonnel hours (EST): Monday-Friday: 9:00am - 5:00pm
They also have an online support operator during normal business hours here
http://www.titanheater.com/livehelp/livehelp.php?department=2
Mar 24, 2010 | TitanNet TITANTANKLESS. COM PRESENTS THE...
When turn on the hot water only the top red and green lights are on and the water is not hot
is it wired correctly..check all your wiring
if its a new install call the place of purchase or the manufacturer
Feb 05, 2010 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Titan SCR2 Stopped working.
I have the Titan SCR2 N-120. You may have a different model. On mine if you are looking at it just a inch below & 1 inch to the left of dead center will be a round black sticker(it has some white lines like at&t's logo). there's a pin hole in the middle of the sticker that you can poke to reset. Or turn the breaker off then take the 2 screws out of the top of the unit. It's just a thin metal cover that you can pull back & look inside. You'll see a red circular button thats the reset button. It's right behind where the hole I was talking about & what gets pushed in. you'll also be able to see if anything burned out & can get replacement parts at titanheater.com . One of my heater elements had burn/ melted & I've ordered a replacement. It was $17 + $11 s&h but still cheaper than $200 new unit from e b a y. Best of Luck
Sep 03, 2009 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Titan Tankless stopped working this morning.
I have the Titan SCR2 N-120. You may have a different model. On mine if you are looking at it just a inch below & 1 inch to the left of dead center will be a round black sticker(it has some white lines at&t's logo). there's a pin hole in the middle of the sticker that you can poke to reset. Or turn the breaker off then take the 2 screws out of the top of the unit. It's just a thin metal cover that you can pull back & look inside. You'll see a red circular button thats the reset button. It's right behind where the hole I was talking about & what gets pushed in. you'll also be able to see if anything burned out & can get replacement parts at titanheater.com . One of my heater elements had burn/ melted & I've ordered a replacement. It was $17 + $11 s&h but still cheaper than $200 new unit from e b a y. Best of Luck
Jul 27, 2009 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Hot water is running very slow
Definitely calcium is your problem. If you want to work on this your self turn off the power and drain the tank into a bucket, you will find lots of calcium in the tank. Rinse it out a couple times with fresh water, and vinegar.
May 07, 2009 | TitanNet TITANTANKLESS. COM PRESENTS THE...
TitanNet TITANTANKLESS. COM PRESENTS THE TITAN SCR2 WHOLE HOUSE TANKLESS WATER HEATE Logo
1,909 people viewed this question
Top TitanNet Water Heaters Experts
Gene Haynes
Henke44
Henke44
Level 1 Expert
Are you a TitanNet Water Heater Expert? Answer questions, earn points and help others
