Laserdisc / cd player loading tray failure
I have a Pioneer CLD J420 and after 11 years of service, the tray fails to extend when I push either the LD or the CD button. The display lights up when switched on and the the laser arm moves inside. The display changes to say No CD. Is this worth repairing? If so, please recommend somewhere in West London that can do this. If not, is there a compatable model, i.e. a newer version of the LD / CD player that I should look at.
This is all new to me so thanks for any advice...
[email protected]
SOURCE:
techman
  • 3130 Answers
SOURCE: CD Player Tray Spins Continuously With or Without Disk
Yuo didnt mention if it was used or new,. If it was new I wouldnt mess with the unit and take it in under warranty, as there is no quicky fix for this one. Its going to turn out to be a problem with the disc motor servo circuit or the microprocessor. Good Luck
Posted on Aug 06, 2006
SOURCE: DVD MALFUNCTION [MODEL PIONEER XV-DV131 (DVD/CD HOME THEATER]
I have the same problem with my XV-DV333. Search on inet and this came up: "... Pick Out One Of These! But I am unable to select any region using the remote control or the buttons on the player. What do I do? You need to get a Pioneer Service Remote. When you have it you should press: [ESC] [A.MON] [Numbers], where [Numbers] correspond to the region number you want to set. Be aware that you can only set this once, if you set the wrong region number for your area, there is no turning back. " WTF! Am I supposed to get a service remote to get this thing working again. I haven't done anything and it worked before:/
Posted on Sep 08, 2007
  • 38 Answers
SOURCE: Can not load or Eject DVD
Be sure NOT to load any CD+ -R,CD+-RW or DVD+-R,DVD+-RW to this unit.
Try to load up a standard CD see if there is audio first. If so,try a good(not scratches) dvd movie.If you have tried both and still not working.You need this unit to be repair or buy a new one!
Joe
Posted on Feb 04, 2008
  • 8 Answers
SOURCE: Red power light, but no display or lighs
A lot of "aged" problems relate to the power supply with this type of unit. If you are a handy chap and know what capacitors are you will find that finding and replacing the "dry" caps in the power supply will fix most problems including streaky pix and crackly audio.
Posted on Mar 10, 2008
yalmer
  • 552 Answers
SOURCE: KENWOOD LVD-K9100 CD, CDV, LD,
If the laser diode inside the optical pickup is dead or weak it will do exactly as you have described. It is a very common problem with cd and dvd players.
Things You’ll Need:
  • Lukwarm water
  • Soft, clean cloth
  • Karaoke machine cover
Maintain Your Karaoke Machine With Regular Cleaning Step 1:
Clean the exterior of your karaoke machine regularly. Use a soft clean cloth to wipe down the karaoke machine housing. You can use warm water to help clean the unit, but it should be applied to the cloth, not the machine casing.
Step 2:
Avoid using cleaning solvents to maintain the karaoke machine. These can tarnish the surface of the machine. Solvents can also affect how the machine functions if they get inside the housing or into the buttons.
Step 3:
Clean the CD laser lens occasionally. Use a CD lens cleaning disc for the best results. Place the disc into the karaoke machine and run it according to the enclosed instructions.
Step 4:
Try cleaning the CD laser lens manually. Open the CD player and locate the CD laser lens. Wipe it off gently with a clean cotton cloth. Do not use any solvents.
Properly Store Your Karaoke Machine Step 1:
Turn off the power to your karaoke machine after each use. This will help the machine from overheating.
Step 2:
Store your karaoke machine in a cool, dry place. Moist conditions can cause the machine's cabinet to warp and could cause rust on interior electrical components.
Step 3:
Keep your karaoke machine away from direct sunlight. Direct sunlight can warp plastic buttons and screens on your karaoke player.
Step 4:
Consider covering your karaoke machine while not in use. This will help prevent dust from accumulating inside the buttons.
Handle Your Karaoke CDs With Care Step 1:
Store your karaoke CDs in their original cases to reduce the risk of dirt accumulation. Dirty CDs can cause tracking problems when put in your karaoke player.
Step 2:
Keep your karaoke CDs away from direct sunlight. Even while in their cases, CDs can easily warp when exposed to direct sunlight. Warped CDs may get stuck inside the karaoke machine.
Step 3:
Pick up karaoke CDs only by the very edges of the disc. This will help keep the discs free of dirt and fingerprints.
Here are some generic things to try.
Posted on Mar 14, 2008
I have a Pioneer LaserDisc, model cld-v850, where the the ejection button would not close the disc inserter. It only closes half way. Any help is much appreciated, thank you!
Unplug pc, open cabinet and look for dust and debris , clean with compressed air.
If it's still dirty use 50/50 distilled water and alcohol with a swab. Allow 30 minutes before plugging back in.
Dec 10, 2014 | Pioneer Televison & Video
Pioneer CLD-95 only spins laserdiscs when it feels like it
It sounds like the read head assembly is not resetting back to the starting point so it can start off reading the "A" side of the next disc. Probably turning it off and then on resets it back to the start of the "A" side. You might try flipping the disc manually to the "B" side, let it go and then try another disc to see if it works.
Mar 30, 2010 | Televison & Video
My Pioneer CLD-990 only plays through one side of
One of the common causes is a small crack in the ribbon cable that connects the optics assembly to the PC board. This cable is moved all the time when the optics move and when the assembly turns over. This is not a repair I would recommend to a novice. The cable is still available last time I checked and is simple to replace for anyone that has worked on these before. The tray must be removed to do this and it is tricky to re-align properly. I think the cable runs between $20-$30.
Dan
Mar 18, 2009 | Televison & Video
No power available to Pioneer CLD-D505 laserdisc player
Check the power supply look for anything that might be burnt or damaged.
Feb 10, 2009 | Electronics - Others
Pioneer DV535 Player
That sounds like a problem that needs professional service. The door may have jumped a gear, or there could be a circuit malfunction. At any rate, it's probably cheaper to buy a new DVD player. CD and DVD technology are quite precarious still, and I wouldn't expect more than a couple years service from most DVD players.
Jan 02, 2009 | Pioneer Audio Players & Recorders
Disc Tray Won't Open
Sounds like a belt is slipping.
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Jan 25, 2008 | Pioneer DVL-909 DVD Player
190 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
