Question about Kyocera FS-4000DN Laser Printer
My printer skews the image slightly only when duplexing
  • 25 Answers
If u have the warranty send it back its the pulley belt that needs to be fixed if its new it could be from fake retailers" str8rppn96 "
Posted on Apr 28, 2010
Hi there. Our Canon ImageRUNNER 3235i has been skewing papers about for months. Service techs can't seem to find the problem as it is sporadic. Any suggestions?
These can be a quite pain, this copier when it works it works it fine, but when it doesn't works it doesn't work with style.
Please give me more info, where the paper is skewing? in duplex assy or before or after the fixing unit or while going out of paper drawer...?
I had a problem that paper was skewing in duplex and I've chaneged the duplex vertical roller axis.
Sep 20, 2011 | Canon ImageRUNNER 3235i Black and White...
Photocopier producing skewed finished copies. What can be the problem?
If the image is skewed on your paper, you have a registration bushing broken.
If the image is OK on the paper, look for a piece of paper or a little thing in the way of copy
Jun 27, 2011 | Ricoh Aficio MP 1600L Black and White...
A document was skewed. Please remove the document and scan it again(-4710)
There are sensors at various locations inside the scanner. If a document is skewed slightly, the scanning software can deskew the image. If skewed too much the scanner would ask you to rescan. The scanner senses the document thro a set of sensors. Ensure that the scanner is clean and that no bits of shredded paper is blocking the sensors.
S. Mohan, India
May 17, 2011 | Canon DR-9080C Path-Through Scanner
Toshiba e studio 250 close duplex unit message
Dear, open the duplex cover, at right corner inner side of duplex cover,there is a micro switch which is not getting pressed,see weather duplex cover is completely closing,If copying is going on see the duplex cover is slightly getting open,if so press the duplex cover while copying is don, for confirmation that switch is not activated.
Regards
Mahaboob Basha.T
Bellary
Karnataka
India
Mar 27, 2011 | Toshiba E-Studio167 Copier
When the first side prints on douplexing the paper pulls correctly. When the second side feeds it does not pull straight
check to see if the duplex is locked in correctly, also, there is a grey button that you will be able to open the duplexor itself, check in there to see if some paper or debris is lodged in there, causing the paper to skew.
Sep 23, 2010 | HP Officejet Pro L7680 All-In-One Printer
When I print the image is printed at an angle tipped slightly to the right. It happened after putting in a new ink cartidge and I scanned in the test page. Scews everything printed. HP photosmart C4480
Remove and replace the cartridge again, I wonder if somehow you haven't canted them over somehow? Also check the paper is feeding OK, clean the Rollers, If one roller was just ever so slightly Ahead, from the other one, just a tiny bit, it would ever so slightly "Skew" the page? so check all that out.
Apr 18, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
MP830, how to retrieve faxes in memory to my PC
- A margin appears
on printouts.
2 B Paper feed
Improper paper
feeding:
- Multi-feeding
- Skewed paper
feeding
- Paper jam
- Paper feeding from the
ASF
- Plain paper
- Highest print speed
(Custom setting to 5)
- In the high temperature
and high humidity
environment
- In the low temperature
and low humidity
environment
- With the maximum
amount of paper set (13
mm)
and high humidity
environment, paper
becomes wavy; in the
low temperature and
low humidity
environment, paper
curls significantly.
When the maximum
amount of paper is set
in the ASF, and if the
paper-return tab fits in a
wave or curl of the
paper, the tab slips and
does not catch paper
properly, causing paper
feed problems.
- Reduce the amount of
paper set in the ASF to
half (approx. 5 mm
high).
- Multiple sheets of
paper feed at the
same time.
- Paper feeds at an
angle.
- A paper jam
occurs.
3 C Print results
Skewed paper
feeding (at the
level of +/- 1%)
ASF
- Credit Card size
Since coaxial tolerance
between the pinch roller
and the LF roller, which
determines the paper
feed alignment, is
0.2mm, skewed paper
feeding can occur.
However, according to
the field data of current
models, the skewness
level caused by the
coaxial tolerance of
0.2mm is within the
criteria of +/- 1%, thus
the phenomenon is left
as is.
- Align the paper guide to
the paper edge tighter
than usual.
- Paper feeds at an
angle.
- A margin appears
on printouts.
4 A Print results
Soiling on the
back side of paper
(lines or streaks
parallel to the
paper feed
direction)
- After continuous
borderless printing of
small sized paper (such
as 4 x 6), when a larger
sized paper (such as A4)
is printed.
- With Photo Paper Plus
Double Sided or
postcards, the
phenomenon is likely to
be noticeable and to be
complained of by users,
as printing is performed
on both sides of such
paper.
In borderless printing,
printing is performed to
the size slightly larger
than the paper size, and
ink off the paper is
absorbed by the platen's
ink absorber. Absorbed
ink may attach to the
platen rib(s) after
several dozen sheets are
printed, causing soiling
at the leading edge of
paper or on the back
side of paper.
1. Perform Bottom plate
cleaning (from the
MP driver or via the
operation panel) up to
3 times*1.
2. If soiling on the paper
still remains after 3
times of Bottom plate
cleaning, wipe the
platen rib(s) and their
surroundings with a
cotton swab.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
Soiling on paper in
automatic duplex
printing (lines or
streaks
perpendicular to
the paper feed
direction)
- Automatic duplex
printing (Photo Paper
Plus Double Sided,
postcards, plain paper)
On the rib(s) inside the
sheet feed unit used for
duplex printing, ink
mist may accumulate,
smearing paper.
Temporary operational
solution:
Cancel automatic duplex
printing, and manually
print each side of paper.
Cleaning by user:
cleaning (from the
3 times*1.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
- Even after Bottom
plate cleaning
was performed,
and the platen
ribs were cleaned
with cotton swab,
paper gets
smeared.
2-10
Oct 12, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Prints a skewed image
Your paying good money for that service contract. I'd have them send a tech and have him stay there until it's fixed or find a new service provider. Questions like this drive me nuts. Were not talking rocket science here, these devices are not that complicated. Hold contract providers feet to the fire until this is solved. I'm really sorry.
Sep 26, 2008 | Sharp AR-BC320 All-In-One Led Printer
No power
Hi Bret! Since this is a brand new printer, I would advise calling Lexmark. I'm afraid that you may void your warranty if you do much more at this point except for going back through the steps to make sure the duplexer was installed correctly.
1. Power off the printer and unplug the power cord from the wall outlet
2. Push the release button, and gently lower the front door.
3. Release the green tabs and lift up the image transfer belt.
4. Remove the cover over the duplex connector.
5, Remove the duplex option from the packaging. Carefully install the option into the printer, under the image transfer unit. NOTE: Make sure to line up the arrows on the duplex option with the arrows on the printer. Make sure the duplex option locks into position.
6. Lower the image transfer belt back into position. Make sure the belt locks into position.
7. Close the front cover.
8. Plug the printer back in, then power the printer on.
9. Try printing a few pages to confirm that the duplex option is securely installed. Then select the duplex option in the software and print a few double-sided pages to confirm that the duplex option is working.
The following link will take you to the instructions for enabling the duplex option in the software.
If the above does't work, I would strongly suggest contacting Lexmark for further help.
May 13, 2008 | Lexmark T630 Laser Printer
5652 and Vista - duplex print not working
In Vista the default s the duplexer is "not installed". Go to Start, Settings, Control Panel, Printers, double-click on the Deskjet, Printers, Properties, Device Settings and set the duplexer to "Installed".
If the duplexer prints the back side upside down in Vista once it is enabled you can get a patch as described here.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Feb 19, 2008 | HP DeskJet 5652 InkJet Printer
Kyocera FS-4000DN Laser Printer Logo
73 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
