Question about Plumbing
I have a toe tap drain that will not close. I'm not able to fill the tub for bathtime for my kids...help
    Problem Solver:
  • 7 Answers
Replace rubber grommet on the toe tap or get new spring in housing
Posted on Apr 29, 2010
After washing a load, the next day I find water in bottom of tub in front load.
If it is clean water main couase is a leeky fill valve (not closing) after machine power off. Repalce or turn tap off. If it is hot & cold fill then turn one tap off after a wash and see if the water still comes in. Repeat with the other tap after the next wash.
If it is dirty water then it is filling back up from your drain system this would need to be inspectected for blockage etc.
Oct 01, 2014 | Washing Machines
Toe tap drain leaks down the drain
sounds like the rubber seal is leaking replace the rubber washer
Dec 28, 2013 | Delta Rp31558pb Classic Toe Operated Tub...
I have a Kokler tub which has a toe tap drain that is clogged. I turned the metal portion of the actual toe tap counter clockwise and removed the top portion and the rubber piece directly under it. Now I...
Someone overtightened the plastic part during installation. There is a threaded portion at the bottom of the plastic cylinder that screws into the actual drain. I have never had to resort to pliers for removal but that approach may be your only hope for removal.
May 11, 2017 | Delta Home
Washing machine fills with water while sitting idle.
Another problem could be the inlet solenoid is failing to close properly, this could be caused by either an obstruction in the sealing part of the solenoid valve, a damaged or worn out seal or if the water pressure is too low. (some solenoids require water pressure to close off properly). To test this idea turn off the taps when not in use. If the water is still filling the tub, the back flow / syphoning idea may be valid. Also just to rule the idea out, turn off the tap to the machine and remove the inlet hose, if the tap "drips" this "trickle" of water maybe the culprit. If turning off the inlet tap fixes the problem you may need to replace the inlet solenoid.
Jan 08, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Removing bath drain
There are two types of tub drain stoppers for the delta brand - lift & turn and toe tap.
Lift and Turn:
The lift & turn stopper for the bathtub unscrews counterclockwise while in the full up position.
Toe Tap:
The toe tap stopper does also but if the cap may unscrew from it before the entire stopper comes out. In that case, there is a nut that is now exposed and can be accessed to unscrew the assembly.
If either of these is "spinning" without unscrewing, the threads are stripped and you would need to exert upward pressure while unscrewing in hopes of uncoupling this from the bath waste. If that doesn't work you would have to unscrew the bath waste flange from the drain pipe.
This will require access under the tub. I hope this answer the question for you. Thank you for using FIXYA. Jeff
Apr 09, 2010 | Delta Home
I have a Delta push down bathtub drain stop, but it is worn and does not stop the water. It does not unscrew as far as I can see how do I get it apart without removing the tube which I can not do?
Lift and Turn:
Toe Tap:
Apr 06, 2010 | Delta T13420 Chrome Classic Single Handle...
Slow tub drain
I am not completly sure about the kohler,but i think that you have a toe tap drajn.You should be able to un-screw it counter clockwise.IF you can get it un-screwed look at the bottom of the toe tap.There will be a screw or a plastic nut.I beleave that you loosen it to raise the drain I hope my information is correct,I will certanly do some research on your drain.
Dec 11, 2009 | Kohler Archer Bath Drain, Vibrant Brushed...
Delta tub tap only cold water no hot water or pressure for shower.
take handle off and adjust the nylon set ring it is to prevent kids from getting burned and is probably set wrong youll see teeth and a pointer just pull it out a little and turn it in the oppisite direction then push back in
May 09, 2009 | Delta Faucet Company Classic Collection...
E10 error with NEW front loader fridgidaire
Are you sure that water fills the tub ? Close the hot water tap and check if cold water fills in, then close the cold water tap and open the hot water one and check whether hot water fills in. Let me knw with your test results.
Aug 12, 2007 | Frigidaire ATF6000ES Front Load Washer
Plumbing Logo
472 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
