The photo copy machine is making a lot of noise and is not printing when is put on and later it will show error code 000020-0081
    Guru:
  • 415 Answers
Click HERE to review previous Questions and Answers related to your specific problem. These suggestions should help you correct your problem. :-)
Posted on Apr 28, 2010
Error 2,156,50 canon mg 2120
because I can not always quick scan shows me the error 2156.50
Jan 17, 2013 | Canon PIXMA MG2120 Photo All-in-One Inkjet...
Error Code P-04-513
P04-513 is an ink overflow error.
the easiest way to fix it is to run the drum dry.
here is how:
1. turn the machine off by the power swith.
2. hold the left and right print position buttons and turn on the machine.
3. when the machine starts it will show you some numbers.. perss either the clear or yellow reset button to show 0000
4. now enter 81 and press start and the machine will make a master.
5. once the machine is done press the clear or yellow clear button to return to 0000
6. next make suer you have plenty of paper and enter 888 and press start.. the machine will start making copies of the test pattern. (if it jams a lot you may want to use speed 1 or go to step 4 and use code 80 instead)
once the copies start coming out light you can press the stop button and when the machine stops turn it off and back on normally.
Dec 19, 2012 | Riso RZ390 Duplicator
Poor color on papper & photos brand new ink tried everything
Epson R360. Printer error. Please see your documentation?I have an Epson R360 and attempted to print a cd. As I put the tray in the printer didn't respond, when I looked at the screen the display was showing a message, " Printer Error. Please see your documentation" It advises to turn off and turn on again which I have done, several times. It was working directly before this as I had printed my daughters homework.
I uninstalled the drivers and reinstalled them to see if it would make any difference, but nothing. My printer just keeps telling me this message. When I power it up there is a lot of noise coming from inside the printer, the ink carriage is moving but not a great deal. Any help advice is appreciated.
Apr 26, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Machine error 7a on brother mfc8640d
For the error code "7a" to be fixed permanently, you need to ensure that the main PCB is fine and is working in good condition.
If the error code is caused due to malfunctioning of the main motor, then you need to check the whole setup by connecting it with another motor.
In this case, make sure that there is no mechanical load present on the main board.
While fixing this error code, you will notice that the motor runs slowly initially and then picks up the speed later.
For more information and help........
http://www.fixya.com/support/t5660619-7a_error
Apr 28, 2009 | Brother MFC-8640D Printer
Sharp copier AL1655CS will not let us copy until a new drum is installed. There is a code to get it going anyway. It limits you to a set number of copies even if it is working fine.
c photo c photo then prss 24 machine copy quantity key up and down arrow key then press print key press 7 press print key then solve your problem no show any code print fine thanks
Apr 13, 2009 | Sharp SHP AL1655CS Printer, Scanner,...
Mecha Error 0005
oooohhhh k
1) when you turn the printer on does the printer make a lot a noise and then display "ready"
-If not there may be mechanical issues with your printer
Nov 13, 2008 | Sony UP DR100 Thermal Photo Printer
Not printing
try to press and hold the copy and cancel button at the same time. It should take up a pice of paper and spit it out blank. then try to print again. if problems persist call the 1 800 235 6325 kodak support hotline
Jul 25, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
GRINDING NOISE or PAPER JAM
If you are not a technical person best thing to do is to show it to an expert. grinding noise means some part in the machine is running with the friction. and might brake something or scratch something. Find out persons who work on photocopiers in your area either samsung or Xerox. as this model comes with both the companies and Xerox people are generly better than samsung people.
Apr 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Error 5100
I Have the same problem. Greece.  This is the second services and I a lot overwrought with this instrument.
Him I was deprived 2 times and now one more time will again make installation of other instrument for the time of repair.
Rather I will reverse the sale in order to I finish with problems with canon.
actlaw@ath.forthnet.gr
Nov 17, 2007 | Canon SELPHY DS810 InkJet Photo Printer
19 people viewed this question
 Grubhead
Grubhead
