Question about Air Tools & Compressors
My Delta 2 gallon ShopMaster air compressor will not start. Is there a fuse in these items?
  • Anonymous Mar 18, 2014
    Sounds bad
    Sounds like something is broken
    New Friend:
I have the same compare compressor I took off of 10 screws off there's a fuse inside. first time I replaced by 3 amp fuse but it's burn again.second time I use 7.5amp fuse. It's good for now.
Posted on Apr 15, 2017
    Problem Solver:
  • 12 Answers
There could be a on/ off switch on the side of the pressure switch if so turn it to on ,if there is not check for power at the pressure switch if there is not any then the cord could be bad.
Posted on Apr 29, 2010
Looking for manual for sanborn B51-A24-80V1 model
PDF]Sanborn Black Max 5hp Air Compressor Manual B51 A24 80 1
intrigante35hindu.strictlyyouth.org/rzsatzo_sanborn-black-max-5hp-air-...
Jul 16, 2015 - Sanborn Black Max 5hp Air Compressor Manual B51 A24 80 1 ... Black Max Portable Air Compressor - 5 gallon Item #: 81527 ' Model #: BS0880504 ...Compressor Manual: $4.95: Buy Now: B51-AT24-80V,B51-A24-80V1.
Aug 28, 2015 | Air Tools & Compressors
How do you remove the chuck from a Delta shopmaster 350 bench top drill press?
there is a "drift pin" that came with the tool, you would need to insert it into the slot and tap on it.
Sep 08, 2011 | Delta DP350 Shopmaster 1/3 Horsepower 12...
I need a manual for the shopmaster BS100. rachelsue@verizon.net
i need a manual for delta bs100 shopmaster 9 inch bench table band
Dec 17, 2010 | Delta BS100 Shopmaster 9 Inch Bench Top...
I need a manual for a Delta TP300 Planer
you might want to try Dewaltservicenet.com and you can type in your model number to see if they have manual available. If you still have problems let me know.
Jun 28, 2010 | Delta TP300 Shopmaster 12-Inch Portable...
I need an owners manual for delta gr450 8
Here's a link to download the pdf.
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Delta/A15786.pdf
If it doesn't work, start here:
http://www.deltaportercable.com
Mar 02, 2010 | Delta Shopmaster 8" Bench Grinder
My clarke compressor keeps blowing the fuse in the plug on start up. any ideas!!!! i`ve changed the lead and plug
if the compresor is tight it would blow fuses, or the starter capasitor is leaking,,, (below power)
but its more likley you are using the compresor on a long extension lead and the power drop in that lead is causing the problem,,,if this is so,, use a much thicker extension lead...2hp motor = 2600 wats? at start up,
Oct 28, 2009 | Clarke Power Products AC2002A 2 Hp Air...
Need an user/owner manual for a Delta Shopmaster 12'' Portable Planer Model #TP300
Heres your Manual:
http://powertool.manualsonline.com/manuals/mfg/delta/tp300.html
Oct 15, 2009 | Delta TP300 Shopmaster 12-Inch Portable...
Manual for Delta Shopmaster 6" Jointer
Go to Dewaltservicenet.com and in the middle of the page towards the bottom type in your model number. It will take you to another page and click on the first JT160 and when it changes screens click on the instruction manual, I had to click on it a couple times to open it but I did look at and it is about 48 pages long. Let me know if you have any problems and I will check further
Apr 04, 2009 | Delta JT160 Shopmaster 10 Amp 6 Inch...
Delta shopmaster bs 100 band saw
Hi, This Delta saw uses a 59 1/2 inch blade ( 1511mm).
Good Luck, this should Fixya!
Mar 06, 2009 | Delta BS100 Shopmaster 9 Inch Bench Top...
Air Tools & Compressors Logo
441 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
