How old is model number HS29-024-2P? What size starter capacitor does it require?
5 Suggested Answers
chillmaster
  • 104 Answers
SOURCE: ruud heat pump capacitor size
A hard start or turbo 2000 will not work if the run capacitor is bad. You will need to contact a ruud supply house or dealer with model and serial to find out the exact match. I have checked my sources and came up empty handed. You could try getting a 35/5 MFD at 440V or a 45/5 MFD at 440V as these are the most common capacitors used in Rheem and Ruud equipment. The key is that you will need to check your amp draws on both motors against the nameplate rating to make sure that you are not over-amping the motor. Also check the nameplates on both of the motors. Most condenser fan motors and some compressors list the capacitor size they require in a somewhat less than conspicious location on the label.
Posted on Jun 27, 2008
t1m130
  • 86 Answers
SOURCE: How old is my Lennox air conditioner?
not positive but looks like 5-8-02
Posted on Jul 14, 2009
SOURCE: I have a Lennox, central air unit and I need to
Im 100 percent certain it is 2ton unit
-024= 24,000 btu
Posted on Jun 21, 2010
SOURCE: What size dual capacitor does a Lennox 3 ton heat
what is the ideal rating of capacitor for 3 tonner split type air conditioner, 220VAC?
Posted on Oct 27, 2010
I have an older model Rockwell 10 inch Radial arm saw. The motor part number is 438-02-314-0786. Would anyone know the actual number of the start capacitor that goes with this model?
highly unlikely that that information will be available
the capacitor will have the details stamped on it
or you can get the motor details from the attached plate ( watts /hp) cycles , phase, make rpms and take the details along with the old capacitor to a electric motor repair shop and they will have a capacitor that is a replacement unit
if you don't have the old capacitor , they will know the capacitor required from the details
Sep 06, 2016 | Saws
The size of the capacitor
The size of the capacitor is stamped on the side of the old capacitor. it's the number just in front of the letters uf. Example 100 uf, 40 uf etc.
Nov 23, 2015 | Heating & Cooling
I need to know what size run capacitor for compressor I need on a Weather King model 10AJB24A01?
You can see a pic at the web address provided. The number is located on the old capacitor and frequently a replacement will not have an exact fit that requires you to modify the space it rests in. The updated part number is
43-25135-16 it is a 3/30 Mfd capacitor. 30 3 Mfd 370V Oval Capacitor 43 25135 16
Sep 16, 2015 | Weather King Heating & Cooling
I HAVE 1.5 TON SPLIT A/C WHAT SIZE OF RUNNING CAPACITOR WILL WORK IN COMPRESSOR?
the capacitor that is required is the same size as what is fitted
it will read as voltage and uf number
best have a ac technician check it out as it may not be the capacitor but the power board
some ac units have a capacitor that is in effect two capacitors in one to run the compressor and the cooling fan as well
best get the technician in as it could save a lot of money in the long run
Aug 08, 2015 | Dayton Permanent Split Capacitor Motor Fan
What size capacitor does the out door fan motor require on a RUUD Model number UPMC-042JAZ
call your local ruud dealer and have him cross reference model number or look on fan motor itself, if original then cross reference ok, but if it has benn replaced look on the fan itself
Jun 19, 2014 | Ruud Heating & Cooling
I NEED TO KNOW WHAT SIZE CAPACITOR GOES IN MODEL NUMBER- CK49-1B
The old capacitor has it's rating on the side. If the old capacitor is missing the you will have to read the capacitor rating on the data plate for the compressor and the one for the condenser fan motor as well. Each of them will tell you what capacitor they require.The compressor will be something like 35µF.
Data plate for the compressor in located on the top of the compressor or on the side and will look similar to the one of the ones pictured below. The fan motor one will be on the side of the motor, you will have to remove the top of the condensing unit to see the fan label.
Jun 19, 2011 | Goodman Heating & Cooling
WHAT SIZE DUAL CAPACITOR DO I NEED FOR A RCA36A21
You need a 40 by 5 uF by 370 VAC capacitor ,also you can look at the old one or with the model number of the unit go to the a/c supplier and they 'll give you the rigth one.
Aug 16, 2009 | Amana Heating & Cooling
My unit keeps burning out the capacitor
Verify that the capacitor is a match for the motor that it is serving, you can do this with the model number of the fan or compressor, look the model number up on the mfg website and it will tell you what size cap. also verify that the terminals are making good connection, I usually cut out the old spade terminals and install new.
Jul 14, 2009 | Dometic Rooftop RV Air Conditioner
Ruud heat pump capacitor size
Jun 26, 2008 | Heating & Cooling
Compressor clicking on and off fridge now warm
looked up your model number and got a part number of 8201799. is that the number you got??? cause in the pic it looks like there are 3 terminals on the relay(brown piece) there should have also been instructions in the package no???
Mar 28, 2008 | Refrigerators
Heating & Cooling Logo
509 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
