Question about GE JVM1450BA / WA / AA 950 Watts Microwave Oven
I have ge JVM 1450 MICROWAVE, WILL NOT HEAT AT ALL.
  • 96 Answers
SOURCE: ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
Posted on Jan 22, 2008
SOURCE: GE Microwave JVM 1640 BB - Spacemaker
ARE THE LIGHTS WORKING WHEN YOU OPEN THE DOOR?
DO THE CLOCK WORK? IF YES YOU MAY HAVE A BAD
TRANSFORMER,DO THE LIGHTS GO WAY DOWN WHEN YOU
HIT THE START BUTTON? YOU ALSO MAY HAVE A BAD CAP.
(DO NOT FOOL AROUND IN THIS PART OF THE OVEN)!!!!
BECAUSE MOST TRANSFORMERS PUT OUT ABOUT 2200VAC.
YOU CAN AND WILL BE KILLED IF YOU MAKE A MISTAKE HERE. IF YOU NO NOTHING ABOUT HV. STAY AWAY!!!!!!!!!
MicrowaveSvc
  • 9098 Answers
SOURCE: microwave runs but does not heat
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it's not shorted, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 17, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Microwave/Convection JVM 1090 oven won't reach temperature
You probably have a bad thermistor.
(At that site, that part is misspelled as "thermister" for your model).
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Accessing some components for testing will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Posted on Jan 03, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: GE microwave TURNTABLE slow-erratic and noisy JVM 1860 SD 002
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
Posted on Jan 04, 2009
MY MICROWAVE WANT HEAT. GE JVM 1660AB 001
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Oct 09, 2010 | GE JVM1660 Microwave Oven
Our GE JVM 1653 spacemaker microwave looks like it is working but the food doesn't heat up. It lights up and goes around but no heat? Whats up?
heatman101
ysss
Jul 06, 2010 | GE JVM1653 Microwave Oven
Need manual
Hi
Thanks for using FixYa. Please see the link to download the manual for GE Space Maker JVM 1640SJ Microwave Oven---
GE JVM 1640SJ Microwave Oven Manual
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven runs but does not heat food
heatman101
ftsd
Jun 22, 2010 | GE JVM3670 Microwave Oven
Oven runs does not heat GE EMO3000
the microwave runs does not heat the model is jvm 1660BB003 KW:1.58
Dec 05, 2009 | GE Microwave Ovens
My GE spacemaker JVM 1533BD microwave runs but will not heat
heatman101
stysty
Mar 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave GE SpacemakerXL JVM 1450
If you need to ask how to do this task, you may have no idea of the extremely high voltages that exist under the cover, even when unplugged. I would advise a competent person changes it for you.
Aug 26, 2017 | Microwave Ovens
Microwave part of my GE Sensor Convection Microwave doesn't work
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Dec 22, 2008 | GE Advantium 120 Convection/Microwave Oven
GE JVM1450BA / WA / AA 950 Watts Microwave Oven Logo
271 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
