Question about Nikon D200 Body Only Digital Camera
My pictures are all washed out. If I use the
My pictures are all washed out. If I use the flash they are to bright If I don't they are to dark.
    Master:
    Sergeant:
  • 411 Answers
Select auto,p or s or A INSTEAD OF MANUAL dial option.
Posted on Apr 28, 2010
The picture frame still scrolls pictures but the pictures are very dark and unable to be seen well. Is the frame ruined?
Hi, Don't put screen in direct sun light or bright light. Bright lights will destroy LCD screen. The LCD screen has some adjustments on back. You might be able to readjust picture brightness.
Good luck.
Jun 10, 2011 | SmartParts (1DPFSP01) Digital Picture...
Dukane 7100HC The picture is dark. In a completely dark room. I recently replaced the bulb, but the picture was dark before I replaced the bulb. I've adjusted the brightness, but it just washes out the...
Turn the brightness up slightly and turn the contrast on the highest setting. There may also be settings to control wether your projectin on a wall or on a screen. Make sure these settings are correct to your setup.
Jan 25, 2011 | Dukane ImagePro 7100HC Multimedia...
Picture too dark
Do not confuse dark pictures with black pictures.
1. Flash Range
2. Exposure Compensation
3. Monitor Calibration (low monitor brightness)
4. Obstructed or covered flash
5. Obstructed or covered light sensor (only on certain models)
6. Flash not firing
Visit www.kodak.com/go/stepbystep
NOTE:
A normal sunny outdoor scene is a good way to test the exposure metering of the camera.
Nov 16, 2009 | Kodak EasyShare C875 Digital Camera
Dark pictures
check out for the ISO settings !!! it wil help u out in taking bright pictures
Jul 16, 2009 | Canon PowerShot A630 Digital Camera
Sony dsc730 when i take a picture camera won't flash and picture
the camera doesn't stay on and it won't flash when picture is taken and when it does the picture is too dark
Dec 21, 2008 | Cameras
Indoor photos are too dark and skin tones orange-ish
I have the same problem at my church with the indoor lighting on my camera. I'm able to get it work by putting the whole thing on manual and adjusting the lighting settings that way.
Jun 13, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
LCD doesn't show image when I try to take a picture in dark area with flash. The picture are not bright and clear.
my LCD screen on my dxg-506v DV doesn't want to display anything all i see is nothing but a bright screen and absoultly no picture on the LCD screen the only way i can see a picture is through my tv screen. i tried and tried and tried using the pc disc that came with the camera and still nothing works the china people just don.t build solid enough technology. like may be get those people out of those sweat shops and start paying them some real money so that much better technology can be made in china
Dec 26, 2007 | DXG Technology DXG-506V DV Digital...
Flash makes my pictures too bright/too dark
u might want to try and put a coffee filter over your flash when you take pictures to make the flash less bright. it sounds really silly but it actually works.
Oct 29, 2007 | Samsung Digimax S500 Digital Camera
Camera Flash & Picture
I just got this camera for Christmas the only way that I know of how to fix it is to change the exposure manually. If the picture is to bright you need a negative exposure, if it is to dark you need a positive exposure. I have noticed that the auto exposure does not get the correct setting that you need for the lighting.
Oct 11, 2007 | Polaroid A500 Digital Camera
CANON Rebel RTI Outdoor pictures are dark
learning to use light metering correctly can have its challenge.
the manual will guide you on how to set up to read light from the subject. spot metering a dark area will cause general overexposure, or a washed out look. spot metering a bright area will cause a dark image. if you are on spot meter and shoot two people standing together against a bright lit background, your meter will see between them if they are centered, and read all that bright background, setting the camera to a less sensitive combination of aperture / shutter speed, resulting in a dark image. use field averaging meter setting and be sure you are metering the subject and not the background. try shooting a wall that is fairly clear of other colors and uniform it light hitting it, you should have a correctly exposed image. since it works in other modes (at least 1, anyway) then it is unlikely you have an exposure compensation issue. that is the only other non defect issue that would cause your problem.
once you confirm that you have these settings correct and still get a dark image, its time to have it serviced.
good luck
mark
Sep 01, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Nikon D200 Body Only Digital Camera Logo
82 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
