The door will not close---ModeSC-HT440 - Televison & Video
  • 99 Answers
Make sure nothing is stuck in drive.
Here is a link for the owners manual:
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=de268bca2a444e529e4b891b92fc9d64&q=Panasonic+SC-HT440
Also the phone number to get service:
1-800-211-PANA (7262)
Hope this helps.
Posted on Mar 24, 2008
    Genius:
  • 3,587 Answers
Comes from having the dvd or cd not laying flat in the tray..
or the mechanism is broken..
one or the other..
does the button work when it's empty?
How can i check battery life on magellan 2250
From the main screen touch the MENU button in the lower right corner of your screen.
When you get to the next screen choose the Application Menu labelled with a 10 on this image.
25889643-onzbdthlkhwu0gpquek0abow-4-2.jpg The battery status will show along the bottom of the next screen you see. Labelled 5 on the next screen you see.
25889643-onzbdthlkhwu0gpquek0abow-4-5.jpg For the full owner's manual click here:
http://dl.pdf-instructions.com/new/external_light.php?id=1297415&RDM=38705&brand=MAGELLAN&ref=ROADMATE+2250&real_ref=ROADMATE+2250&real_ref_top=ROADMATE+2250&langueM=&key=9d7ce6065b7f9ccc1cd0b2afdeec46cc&security=2a28698fc803ab00bd1d337a3a3391a3&host=pdfretriever.com&errorURL=http%3A%2F%2Fpdfretriever.com%2Fframe_tempo_pdf.php%3FID%3D1297415%26lg%3DE%26src%3D15&n1=2772&n2=1793&res=5844&modeSC=M&direct=1
Oct 02, 2015 | Magellan RoadMate 2250 Portable GPS...
What do I need to do in order to get the back door on the passenger side to close? A tech from AAA said I needed a spring for the door latch?
if it won`t close look at the door latch mechanism. there should be two u shaped claws that close around the door striker plate pin, sometimes these get closed before the door is closed causing the door not to close and stay closed. if they are closed(claws) pull the door handle to open the door and take something and push the claws out(open) then close the door.
Jul 08, 2014 | 2000 Plymouth Neon
Turn on dvd panasonic sc-ht440 the display see me f61
Hi, F61 is and amp error code. probably needs an output ic. could be a shorted speaker or bad cooling fan. Disconnect all speakers and turn it on. if the fans run and it still displays f61 then odds are very good an amp ic is bad.'''Hope it helped.
Have a nice day..
Feb 24, 2011 | Panasonic SC-HT440 System
Want to cancell progressive scan settings
Restore Pioneer DV575K :I solved the problem myself thanks, googled for info and all it took was to press the standby/power key on the main unit (unit in stanby) while pressing the rewind button...zammo its fixed.
Many thanks
Dec 29, 2008 | Televison & Video
Panasonic sc-ht440
Always be for ICs audio amplifiers damaged.
Apr 13, 2008 | Audio Players & Recorders
Hello fiddlehead,
Well, here is the procedure to reset the SC-HT440 . While unit is powered and stopped, select “DVD/CD” as the source. Press and hold [■] (Stop) button on the main unit and [≥10] key on the remote control until “Initialized” disappears from the television. Turn the unit off and on again. All settings will return to the default values.
Since you mention that you can not see the menu on your TV's screen, then you won't be able to see the "initialized" disappear, so, give it a second try if the first fails or press and hold the keys for a little longer.
Let me know how this works for you.
cancerags
Jan 02, 2008 | Panasonic SC-HT440 System
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
