Question about Canon PIXMA iP1800 InkJet Photo Printer
My canon MX700 printer will not print from Black cartridge, although the other colors do all right. Do I need to replace entire printhead, or is there another fix that is faster and cheaper?
  • 4,041 Answers
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 28, 2010
CANON PIXMA COLORS ARE LIGHT
I would manually clean out the printhead, I believe for your model it is a separate unit form the ink cartridge. Please follow these steps bellow.
First you will need to remove the cartridges, then remove the printhead assembly then mix some water and isopropyl alcohol in a 50/50 mixture. You can either use a cotton swab to rub the water and alcohol on the printhead or you can soak the inkjet printhead for around 2 to 5 minutes. This should loosen the dried ink. It may take a few attempts and requires patience. Dry it on a folded paper towel and reinstall it. Print a test page to check quality. If the documents are still printing with poor quality, repeat and soak the printheads for longer.
Let me know if that helped. I had the same issue and this resolved it for me.
Thanks
Bloomfield Connecticut Computers (BCC)
Jan 13, 2014 | Canon PIXMA MX700 All-In-One InkJet...
Canon mx700 not recognizing cartridges
I suspect that your have a damaged refilled cartridge. Also, you may have a clogged nozzle. Canon printers are sensitive to the quality of the ink used in the cartridges and refill ink sometimes does not meet the manufacturer's specifications. You can check this by inserting a new OEM cartridge, running the deep cleaning utillity three times and a aligning the printhead. The other problem may be that the electronic chip on the refilled cartridge may either be damaged or blocked by dried ink. In any case, you need to discard the failing cartridge and replace it.
Let me know if this solves the problem. Thanks.
Feb 22, 2010 | Canon MX700 Office All-In-One InkJet...
I use my MX700 only for black & white matters. It sometimes refuses to operate, informing me that my color cartridges have run dry. How do I overcome this?
Unless you have chosen to print in "true black" where only the black ink cartridge is used, your printer automatically will use some inks from the color cartridge to make black. (The reason given is so that your color cartridge will not dry out and cease to function when you do need it for color).
You did not provide your operating system. If you can find your printer name listed in "Control Panel" (usually in "Printers and Faxes"), right click the name and choose "Properties". See if you can find an option to print only using the black ink cartridge.
I hope this helps!
Dec 22, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Black ink does not print. Color works fine.
The print head is probably blocked then. You may be able to get a cleaning cartrige if you look online. Failing that, it will probably need a service.
Dec 13, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Can I use only black ink cartridge with the MX700? All other colors removed?
Canon printers won't let you do that, all colors have to be installed and not empty, for it to do anything. If you ran with colors removed the printhead would dry and plug and require replacement.
Nov 20, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Wont print black
Change the black ink cartridge.
Jun 08, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Canon pixma mx700 print default
In your print dialogue box should be a setting to tell printer to print black only
Apr 23, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Canon PIXMA MX700 printhead immediately coated with ink, smudges
It's likely that the foam pads that the print head rests on when the printer is not in use are saturated with ink. They're to the right as you look into the printer: a rectangular one for black ink and a square one for the colored ink. If you power the printer off and back on, with the cover open, you'll see where the printhead goes to rest.
The pads aren't easy to get at, but you can blot them with a paper towel. Gummy, half-dried ink dissolves in rubbing alcohol, and you can soak a paper towel or a cotton ball with alcohol and wipe down the area. I've had good luck soaking the pads with alcohol, then blotting them dry with a rag.
Feb 18, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Canon IP90 portable . No ink printing.
Have you performed a nozzle test? If one or more of the colors is missing when you do the nozzle test, the printhead itself is likely in need of replacement.
Before considering replacment, perform a clean on the printer. Due to variations between mac and pc, please see your documentation / support files on how to perform the clean on your printer.
After performing the clean, again perform the nozzle check to see if the problem is resolved.
If still not resolved, remove and re-install any cartridges you recently replaced to make certain they are installed correctly.
May 01, 2008 | Canon PIXMA iP90 Mobile Printer
Cannot print Black on anything...
Your printer works with the PGI-5BK cartridge, that are in fact just ink-tanks, the printhead being apart of the tanks, so if the cartridges are not empty, it cannot be because of them. It doesnt matter if you replace the cartridge, the problem is in the printhead.
If the problem occured just a while ago, you should consider that NOT PRINTING a long time (30 days) with a printer can lead to ink drying out in the printhead, clogging the nozzles. OK, now it comes: If you have some tehnical skills, you can remove the cartridge and desassembly the printhead (where the cartridge are in) and do the following:
Put a paper-tissue on a small plate (like a coffee-cup plate), then put some boiling water on it, just 2~3mm of water over the tissue.
Put the printhead with the nozzles part downside on the tissue, in the hot water.
Let it stay there in the water 30 min.
Put the cartridges back on the printhead (without installing it in the printer), rap it in an other clean tissue, than shake it strongy as if you want to force ink to get out trough the nozzles. Then clean gentle the nozzle part of the printhead on some sheets of tissue.
Get the cartridges again out of the printhead, install it in the printer, then install the cartridges again and run a few cleaning processes from the printers maintenance software.
It should work. If you dont have the tehnicall skills needed, Canon gotcha, or you can visit a local specialist to make all this for you, they usualy have better equipmens, as ultrasonic cleaners and special solvents that makes all this easyer.
Rate the solution if it helped you!
Thx.
Feb 03, 2008 | Canon MX700 Office All-In-One InkJet...
Canon PIXMA  iP1800 InkJet Photo Printer Logo
191 people viewed this question
old marine
old marine
