How do you replace a rocker switch on a tevion lcd tv please?
5 Suggested Answers
  • 132 Answers
SOURCE: Where can I get a replacement remote control for
wal-mart or k mart has remotes that will work
Posted on Nov 13, 2009
  • 458 Answers
SOURCE: can i get my 47 inch lcd tevion screen replaced
Yes you could get the screen replaced, however the cost of this now-a-days is almost equal if not more expensive than purchasing a new TV. It is not always economical to have the screen replaced, it is maybe more worthwhile to think about buying a new one instead.
Posted on Mar 22, 2010
  • 8909 Answers
SOURCE: 40" tevion lcd tv. modek no lcd 4040.wont come out
It should be fixeable. Does it do anything now?
I would blanket change them all.
Posted on Feb 18, 2011
SD Tech
  • 14553 Answers
SOURCE: 47in tevion LCD wall mounted tv.i have to leave tv switched on .and kept on standby.???faulty main switch on tv ???solution
This sounds like a very common issue.
If set is hard to turn on (takes several tries)but will eventually turn on hereis what my guess would be.
Every set has a standby power supplythat is running 7/24 if the set is plugged in and it supplies voltage to theremote circuit that turn on the main power supply for the tv and hence turn theset on.
This is an area where companies cut corners by using lower rated voltage caps.By this I mean Standby usually provides under 10 volts to trigger the seton----what they do is use filter caps rated at say 10 volts max in a circuitwith 9 volts (example)=with the standby on all the time the filter caps(electrolytic caps) dry out and fail.
The problem usually begins where you have to turn set on or or two times andgradually gets worse--takes longer and more tries to get it to come up.
Once on it will stay on until turned off for a period of time.
The caps will begin to work better (regain some of thecapacitance) as they get hot--hence one it is on it will seem ok.
The beauty of this problem is most of themhappen when set is a year or two old (no warranty) and all you have to do islook at the top to locate bad ones.
They are generally black or blue and round and vary in --they have twoconnections each--a + for positive and a - for negative--not unlike a batterywhich in a way they are. The + and - are marked on top and bottom of most boards.
They are easy to replace and not expensive parts.
The tops are silverand metal looking with creases on top and if bad they will be puffed up ontop---tops must be perfectly flat with no brown material leaking top or bottom.
If this is your problem once you id them (make a drawing) you can begin.
Here is the critical part---on each cap is also marked the value like 220uf 10vdc---220 micro farad at 10 volts maximum.
If you find for example 6 puffed up and all are 10 vdc replace them with thesame value capacitance (like the 220 uf) but go up to at least in this case(from 10 volts) to a 16 or higher rated voltage cap.
The only issue is when you go up in voltage rated value the cap is larger sosometimes there is an issue of physical space for the replacement on the boardto fit them in.
The reason they cheapen these sets in this way is if 10 caps and you make25,000 sets there is a considerable savings in parts cost.
They do not care as long as it lasts past the usual one year parts warranty.
I have taken the time to be long winded because this really sounds like it maybe the problem you have.
See attached photo of a typical cap and if you have questions or need advicelet me know.4_16_2012_10_54_17_pm.jpg
At the very least look at power supply board to see if puffed up on top caps like these which are bad.
Posted on Apr 16, 2012
Where can I buy a remote control for my Tevion DVD recorder model DD1018 please?
GenuineCopies.tv - Replacement remote control for Tevion MD80857
www.genuinecopies.tv/remotes/brands/tevion/md80857.htm
Tevion MD80857. (Our category: DVD/Blu-ray Player Remote). Replacement Remote Control. No setup is required. All you need to do is to insert two batteries and it is ready to use. Long battery life; remote goes into very low power sleep mode when not in use. This remote works on the Tevion MD80857 only. You will be ... Missing: dd1018
televison & video can't find the component code for my tevion dvd ...
https://www.pete-maravich.com/q1029833_find_component_code_tevion_dvd_recor... Can't find the component code for my Tevion dvd recorder DD 1018. I want to replace the badly designed remote that came with this DVD recorder with the Sony universal remote RM-V210T but I can't find the component code anywhere. 4.0 stars ...
Remote Controls for Tevion
www.remote-controls-shop.com/catalogue/Tevion Remote Controls for Tevion. If you're looking for remote controls for Tevion, then you've come to the right place! We sell a wide range of remote controls for Tevion including both manufacturer's genuine original remotes and cost-effective replacements. Our database covers 253 models or parts for Tevion and our ...Missing: dd1018
Tevion DVD recorder DD1018 replacement remote Google Search
Mar 10, 2018 | Tevion Televison & Video
Hi I have teviono 42" lcd4203id model and tv is white picture nothing on there the TV powers up light comes on but it doesn't bring picture what the fault would be?thanks
TEVION 42" FLAT SCREEN LCD TV MODEL LCD4203ID
www.ebay.co.uk/.../TEVION-42...TV-MODEL-LCD4203ID-/1213...
eBayTEVION 42" FLAT SCREEN LCD TV MODEL LCD4203ID in Sound & Vision, Televisions ' eBay.Missing: white
main board for tevion lcd4203id 42" lcd tv mhdv4201 ... - eBay
www.ebay.co.uk > ... > Other TV & Home Audio Accs.
eBayMAIN BOARD FOR TEVION LCD4203ID 42" LCD TV MHDV4201-ZC01-01 (B) ... Mouse over image to zoom .... *Please open the back cover of TV then check the part number of screen, it would be on white label at back of screen ... of actual item in yourTV as well as check either if it is compatible with your TV model.
LCD TV Repair made easy # 1 - YouTube
? 7:38
https://www.youtube.com/watch?v=GryA_Zl4EBk
Aug 27, 2009 - Uploaded by Grants Pass TV Repair
I have a 2008 model Sanyo dp42848 42' lcd tv with ccfl lighting. .... bought a Seiki tv and within 1 month ...
LG 42LC2D 42 in. LCD HDTV Fusing unit - Que
Dec 29, 2015 | Televison & Video
Tv will not turn on
sounds like you have a fried main power board in your TV... Unfortunately technician replacement of this board will cost nearly as much as replacing your tv.
May 03, 2015 | Tevion Televison & Video
Where can I get a circuit diagram for POWER BOARD MLT666 (VERSION A & B) as used in my Tevion TV
You are not going to in most cases find a schematic as only boards are sold.
It could be a flat pack chip or if it reacts on the power board a filter cap--at least if the set is opened inspect all the filter caps for any even slightly puffed up or showing signs of leaking material top and bottom.
4_30_2012_3_49_28_pm.jpgThese are clearly bad caps.
Apr 26, 2012 | Televison & Video
Need a code for a tevion lcd 32081D to activate sky remote
Hello
Check these codes.
Tevion
TV66SIL
065
Tevion
1530, 3731VT, MD3731VT
696
Sky+ Remote Control Unit Programming Procedure Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
* If this works try the other TV functions.
* If these work then the correct code has been selected.
* It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button
OK.
Oct 16, 2011 | Televison & Video
Feb 18, 2011 | Televison & Video
Can i get my 47 inch lcd tevion screen replaced
Mar 22, 2010 | Televison & Video
I need a code for a tevion universal remote
Tevion is made by Medion..
The only code I find for them is 191
Good luck..
Dec 01, 2008 | Universal Remote Control 6-Device...
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
