Question about Garden
Kohler Courage 27 engine Surges under no load
Kohler Courage 27 engine (Cub Cadet Mower) Engine surges under no load, And have to pull choke out quarter of an inch to run. Turn on blades runs ok Pulled float bowl off looks clean blowed out with air comp. Thanks Doug
How do I remove the starter from a Kohler Courage 20hp vertical engine?
go to Partstree.com and look up the engine model.
You will get a nice breakdown.
I believe it is held on by 2 screws towards the top.
You should not have to remove the engine, just the upper housing.
Oct 07, 2014 | Garden
What is the accurater?
I think your refering the the cam levers picture below highlighred red
Sep 29, 2014 | Cub Cadet 42 in. 19 HP Kohler Courage...
What would cause 19 horse kohler in cub cadet to belch white smoke
answered already look at charles beach answers mower belched white smoke
Sep 02, 2014 | Cub Cadet 42 in. 19 HP Kohler Courage...
Kohler courge sv720-0010 on cub cadet
SOUNDS LIKE IT HAS SOME BAD GAS YOU MAY NEED TO CLEAN THE CARB AND IT MAY NEED A KIT
Oct 10, 2009 | Garden
DGS 6500 w/26hp Kohler Courage surging
i HAD SIMILAR ISSUES WITH MY 2500 SERIES CUB CADET....IT WAS THE CARB.....REPLACED, AND ALL HAS BEEN WELL...THINK IT WAS APROX 200.00
Jul 03, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Cub Cadet 2165 engine surges and eventually stalls
Replace the fuel cap!!! The problem is that hte fuel cap vents from it's underside. In so doing it sucks up all of the grass debris and dust that hte mower deck kicks up and the vents get clogged up. As the engine uses the gas, it builds up a vacuum in the tank and the gas can no longer flow from the tank to the engine.
Jun 15, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet dead as a door nail
I have the same mower. The wires do need to be connected. It is a safety feature on the cubs. The engine will not start if the electric PTO is engaged. I just went into the garage, pulled the pto lever out to engage, pushed down brake, tried to start and it would not start. I suggest reattatching the wires and trying it. Hope this helps.
Apr 24, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
451 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
