Question about Samsung LE32R72BX 32 in. HD-Ready LCD TV
I have vertical shadow lines behind the main picture. Have tried resetting and retuning with no luck. Any ideas please. regards Keith
Bkmnb
Posted on Jun 01, 2010
LG MODEL 55LM4600 THAT HAS A VERTICAL SHADOW ON THE RIGHT SIDE OF SCREEN ABOUT 3 OR 4 INCHES WIDE. hAVE YOU HAD THIS BEFORE?
Line fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jun 03, 2015 | LG Televison & Video
Vertical Black Line
try wash out feture on samsung for 30 sec white out see what happends also upgrade your firmware for these via thumb drive ok
Feb 02, 2008 | JVC GD-V4211PCE 42 in. Plasma Television
Tv has white line in the middle of the screen.The line is about 10mil wide but you can still see the picture behind.This happens on all inputs.model number :krl-37v
Hi, thats is your vertical deflection circuit ;replace the ic and all capacitor ,and
if not able to do it, whit a good technician it is an hour job about not verry more
. hope its gives you an idea ,and that will help...
Regards Alan
Feb 08, 2011 | Pioneer SD-P5795W 57" Rear Projection...
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    A line, red, vertical line extends from the top to the bottom
    you must reset the system of you TV.Open the back cover of your TV reach for the main board.there is a small button on the main board just press it and the error of your TV will be ok...
    please rate me..
    Jun 06, 2010 | Olevia LT37HV 37 in. HD-Ready LCD...
    Ultravision Digital TV has shadows and vertical
    I believe it is either interference or a convergence issue. To fix an issue with convergence try to find a convergence setting in the menu. If thatr doesn't work try to clean your projection lenses with a q-tip and alcohol.
    Good Luck.
    Mar 14, 2010 | Televison & Video
    Mitsubishi rear projection tv
    replace vertical IC and shadows/ghosting the problem is either electrolytic capcitor or video IC or convergence adjustment
    Aug 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
    Shadow on screen
    your vertical ciruit is malfunctioning
    May 26, 2008 | Protron PLTV-32 Television
    Samsung Plasma lines
    Panel could be bad or possibly a cold solder joint on driver ic. Or board that ic is on is bad. Good luck. Jay
    Mar 21, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
    No Picture
    are you getting one bright horizontal line with sound.
    if it is a case
    then your problem is in vertical section
    but remember to minimize brightness to avoid screen burn.
    check
    • supply to vertical section
    • loose contact or print break in vertical output section.
    • any capacitor or low value resistor failure in vertical output section.
    • connector loose which is going to deflection coil.
    • vertical ic might be faulty.
    • hope this will help.
    • good luck
    Oct 14, 2007 | Televison & Video
    Samsung LE32R72BX 32 in. HD-Ready LCD TV Logo
    491 people viewed this question
    Henry  Thomas
    Henry Thomas
    Jerry Greenberg
    Jerry Greenberg
