Question about Health-O-Meter Health o Meter BFM681DQ-63 Body Fat Scale, Clear with Silver Accents
How to recallibrate digital Health O Meter scale
My Health O Meter BFM582KD-63 scale to measure fat/water/weight is weighing incorrectly. It is more than 50 lbs off. everything else is working fine. How do I recallibrate it?
SOURCE: Tanita 2204 Scale weight reading problems
Try the following steps:
1) press both the "set" and the triangle button
2) press the triangle button until you get the desired unit of measurement: a) Kilogram, b) stone lbs or c) lbs; and
3) press the "set" button.
Posted on Nov 20, 2008
r321567499
  • 74 Answers
SOURCE: Can I reset the scale?
This link allows you to ask questions and request a users manual....I hope this helps. http://www.conair-store.com/cc_contactus.asp
Posted on Jan 07, 2009
SOURCE: Err message
The "Err" problem is a very common one but no one so far could predict the reason causing this.It means that there has been an
error in the scale measurement.The only solution mentioned everywhere is to Step off the scale until its LCD screen blanks and Step back on the scale.
Posted on Jan 20, 2009
SOURCE: Scales show weight in kg. How to get them to show lbs.
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Posted on Mar 14, 2009
SOURCE: resetting the scale
You do not reset the scale. It only saves the last recorded weight of the user. So, if you weighed yesterday, it will put your recorded weight in memory. The next time you select your user number and step on the scale, it will compute the difference from your previous record and save your current weight.
Posted on Mar 25, 2009
I can't set the body fat on my Health o meter and it gives me an E every time I try to weigh myself.
The Error message may be indicative of a defect in the scale but could appear because the parameters you enter cannot be processed. Try again to get a manual by Googling (Health o meter)(BFM688D-60)(manual) without parens.
Jan 18, 2017 | The Health & Beauty
Eat Smart scale showing body fat as much too low
Probably there's a build-up of skin oil from your feet that is preventing it from reading properly. Clean off the top of the scale with a cloth dampened in soapy water, then rinse wipe it with a cloth dampened in plain water, and dry it. Be careful not to dribble liquid into the scale.
Note: fat measurement by this method is difficult to do accurately and consistently, For best results, make sure you're properly hydrated at least ten minutes before measuring, and wash and dry the soles of your feet first.
Aug 05, 2017 | Eatsmart Products Precision GoFit Digital...
Health O Meter digital scale, model HDR743DQ1-41, reads "EE". What should I do?
The more recent models don't have to be tapped before getting on,if its an older one, the message might mean you took too long or weigh more than the capacity,usually 300,or 330lbs for a digital scale although some go to 400lbs or more. Try switching the battery for a new alkaline or lithium one;digital scales often need more power than a common cell can provide.
Jun 28, 2013 | Health & Beauty
UP TO HOW MANY POUNDS CAN BE MEASURE IN THIS SCALE
I don't know specifically for this model, but for most like this, 300 or 330lbs is typical. To test a working scale for its max capacity, let a heavier friend try it or carefully hold a weight in each hand and stand very still when its a digital scale. A gallon plastic milk container weighs about 9lbs, so one in each hand,even if filled with water will give you an extra 18 lbs of testing room. You can also let the heavier friend or other person hold the weights to help you test the upper limits.
Jun 07, 2013 | Health-O-Meter Health o Meter BFM681DQ-63...
I changed the new batteries but still digital display is not shown
if the batteries are new and the battery terminals are clean and not corroded or broken, and the battery polarity is correct when they were installed. There must be a fault in the internal circuits of the scale, and a technician with the right tools, training, and experience will be needed to repair it.
Maybe time for a new scale.
Oct 05, 2017 | Health-O-Meter Health o Meter BFM681DQ-63...
How can i make sure my health o meter scale gives accurate weight measurement
Call Health o meter Professional's customer service department at 800-815-6615
Sep 13, 2011 | Health-O-Meter Health o meter 400EXP...
Change scale from kg to lbs
Ok i Just figured it out my self with no manual. When you put new batteries in your scales the unit will be shut off. Press and hold the select button for 5 seconds and then it will show LBS or KG and you will be able to change your weight at that time. Hope this helps.
Apr 23, 2011 | Health-O-Meter Health o Meter BFM681DQ-63...
Scale is stuck on setting for weighing in kgs and cm's
There is no black button on the bottom or anywhere on the model mbf681dq-63
Apr 04, 2010 | Health-O-Meter Health o Meter BFM681DQ-63...
Scale is not weighing correctly. Weighs correct
The scale must be on a hard, level surface. Make sure there is absolutely no dirt on any of the pivot points. Calibrate it with a KNOWN 25 pound weight.
Jan 04, 2010 | Health-O-Meter Health o meter 402KLWH...
Health-O-Meter Health o Meter BFM681DQ-63 Body Fat Scale, Clear with Silver Accents  Logo
466 people viewed this question
Top Health-O-Meter Health & Beauty Experts
creative_lac
Level 1 Expert
His Example
Level 1 Expert
TheHCGInstitute
TheHCGInstitute
Are you a Health-O-Meter Health and Beauty Expert? Answer questions, earn points and help others
