Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
Yellow circle I have a zenith e44w46lcd & the bulb indicator is on, also TV has a huge yellow circle in the center. If I replace the bulb will problem be fixed or do I need a bulb and a light engine??
  • 2 more comments
  • BBuzzBB Dec 03, 2008
    i have a greenish yellow circle in the middle of my zenith 44 in lcd. you can still see through this circle and see whats on tv, but i need to know what i have to do to fix this. could it be the bulb?
  • Anonymous Dec 26, 2008
    how do you replace/check this filter? Where is it located? Where can I get a replacement part?
  • timtepe Dec 30, 2008
    i also have a yellow circle in the center of the screen, how do you fix?
  • Anonymous Mar 25, 2014
    bulb was recently replaced but still having problems
  • 59 Answers
The huge yellow circle is either your blue filter is burnt out (very common in Zenith DLP) or you LCD cube is bad. I would bet it is the blue filter. Zeniths DLPs have 3 color filters one blue (a pinkish color), one green (a grayish brown)and one red (it is red). For the bulb indicator I would check and make sure your lamp is seated to the ballast correctly. Just take it out and put it back in.
Posted on Mar 24, 2008
SOURCE:
Should I replace the bare lamp or the complete housing for the bulb in my Zenith E44W46LCD TV?
Replace it with the complete housing with a bulb inside.The easiest and the safest way to do a replacement of a tv projection lamp.
Sep 04, 2011 | Zenith E44W46LCD 44" Rear Projection...
Light Blue Haze close to the center of the screen
The Optical Engine needs to be replaced. You would need to contact LG / Zenith to get a Service Facility out to confirm the problem and see if they would be willing to help you with the cost. If they do not help with the cost, it will probably not be worth investing the money into it.
I hope this helps,
Skyassoc
Sep 17, 2009 | Zenith E44W46LCD 44" Rear Projection...
Zenith E44W46LCD bulb replacement
yes , panel is on the right side if your looking at the tv,
Dec 31, 2008 | Zenith E44W46LCD 44" Rear Projection...
Faint Yellow and/or Blue Tint on the Ice during hockey games ( or similar color situations)
No the bulb indicator is on a timer just meaning that is is reaching its "expected" life. The lamp will cause a dim picture or no picture it will not cause color deformities sorry. The light engine to fix that set is also priced higher than the set is worth.
-Josh
Oct 08, 2008 | Zenith E44W46LCD 44" Rear Projection...
Zenith replacement bulb
I would suggest to remove the lamp from your TV and check it. You can also just buy the lamp without the other hardware.
This site seems to have good prices.
Let me know if you need any more assistance.
Mar 26, 2008 | Zenith E44W46LCD 44" Rear Projection...
Color Fading on Zenith E44W46LCD
you neeed to change the lamp. the access is located on the right side of the television. you can buy the lamp for about $125 from discount-merchant.com
Mar 10, 2008 | Zenith E44W46LCD 44" Rear Projection...
Zenith E44W46LCD tv
TAKE THE FRONT COVER OFF THE PANEL AND REMOVE THE BULB USEING A PHILLIP SCREW DRIVER AND JUST PULL USING THE HANDLE ON THE OUTER COVER OF THE BULB.
Feb 24, 2008 | Zenith E44W46LCD 44" Rear Projection...
Zenith color problem
We have seen this several times and the yellow spot is due to a problem in the light engine. Major repair and very expensive. The amber lite is simply the lamp replace indicator. After the lamp is replaced a programmer remote is required to get into the service menu an reset the timer.
Jan 20, 2008 | Zenith E44W46LCD 44" Rear Projection...
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
375 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
