Philips 25tr15 will not cut on it just clicks. it has 160v on the main filter cap and 130v on the collector of the h.o.t.. i know i have b+ but i just hear one click from the relay and there is no raster of any kind. i am going to check the voltage regulator next, but give me some more clues to solve this problem.
  • 1 more comment
  • vernon johnson
    vernon johnson Apr 28, 2010
    i have recently gotten a blue ring tester i was wondering do you have a website that can explain how i can test the yoke and the fly back with it
  • vernon johnson
    vernon johnson May 03, 2010
    it reads hi on my esr and on my ohmeter. i replaced it but it still does not come on.
  • vernon johnson
    vernon johnson May 04, 2010
    thank you silver dragon for your comments but i would like to pinpoint this problem with a little help. you made a lot of interesting points but i am looking for someone to help me to get closer to my problem.
  • 566 Answers
Hi vljenterp
You seem to have some knowledge in tv repair so that will make it easier.
If you have 130 volts on the collector of the h.o.t it means that you B+ is correct, which also means that your regulator is o.k .
You did`nt say if there was high voltage but i`d like you to check capacitor C506 near the h.o.t it is a 680pf at 2kv, it will be written 681 2kv on it, and it is a ceramic disc capacitor.
It might be shorted or leaky so you`ll be able to measure it in ohms.
let me know how it goes
Posted on Apr 28, 2010
  • 666 Answers
Is it giving any error messages in the form of a blinking power light?
Posted on May 04, 2010
  • 12,061 Answers
Hi, well I applaud you for wanting to have a go, but you must make sure that you are starting in the right place, And it appears you have, That is The Power Supply, as, if, that isn't right nothing else can be. But you simply cannot do anything without a Service Manual. In this it has everything one needs to repair the set. OK if it is shutting down, after that amount of time, of working and then faulting, then it is most definitely a "Thermal" problem, the way we "Find" problems such as this is "Freeze Spray" you use this on each component that is suspected of being the "Culprit" and you will soon,find that errant component. Now also not every fault is a Capacitor, I see many, many people that think, that Capacitors are always the "Culprit" now while that may be true in a few cases, a faulty Electrolytic Cap, or ordinary, Cap goes faulty, this is only a SYMPTOM, something has damaged those caps causing them to "Fail". One MUST always find the root "Cause", otherwise if you just treat, the SYMPTOM, the "Cause" will just make the "Symptom" come back, in short order, as the prime cause still, hasn't been fixed., Now Capacitors hate AC ripple, or Over Voltage. Thats it. Oh.. and Heat, if these Capacitors, are too close to a Heat Source, then thats a prime cause of failure. Resistors, hardly ever go faulty,and if they do, it is generally obvious. However it doesn't hurt to check values with our Multimeter. Remember though resistors are made, with up to 20% tolerance from stated value, as such, are not too critical, unless in Timing circuits etc. Always check, the Values, of resistors, as with any other component, with the power OFF. Now Diodes especially "Zener Diode", are another thing to check, those and ordinary "Signal Diode" should always be suspect. next we have Transistors and IC's. The Transistors MUST ALL be checked to see if they have a good, "Junction" this is done, with our meter set to "Diode Test" and usually are about 0.6 to 0.7. With IC's you must check, voltage levels, or Logic Levels, going in and out, have a look at the circuit diagram, and it will tell you what they should be. It is a good idea to always measure the Power Supply voltages, see if a "Rail" is Low, that will be because some component has gone somewhat or all short circuit, to Earth, now, if the "Rail" is Higher, suspect an "Open Circuit" component, like a Diode, or Transistor. The voltages expressed in the manual are spot on, ANY variation MUST be investigated. I have been doing all this for over 30 years now, and I do indeed wish, we could have a set of "Symptoms" and be ables to say.. "Oh that;s the so-in-so and replace this" however unfortunately this although does happen, most "Symptoms" can have literally tens, of "Causes" all often "Interlinked" One simply has to do a methodical troubleshooting procedure, and always think, "are my Voltages Correct" as this is how, you Fix the problem, by making them so. Keep up the good work. If that link above doesn't furnish a Service manual, it is imperative you get one, even if you must pay for it. It will pay for itself in about 2 mins. The Tools you will need are A SERVICE MANUAL a Good Multimeter, a Signal generator, a Signal Tracer, pref an Oscilloscope, Soldering Iron, De-soldering iron, Probably, too, A SMT Hot Air desolderer (for the Surface Mount IC's) Air, An Anti-Static Wrist Strap, (MOST IMPORTANT, to prevent ESD), Cutters, Screwdrivers, sometimes, Torx, drivers too. Tweezers, are real handy, magnifying glass or eyepiece, a good strong Light. OH and you MUST have the original remote control too, as one needs this to "Program" the Computer in the TV, after, and during servicing, and to be able to put the TV, into "Service Mode" too.
OK, here is a servicing manual, below, these should help you.
www.scribd.com/.../Philips-Training-Manual-TV-Plasma-Display-Panel-Chasis-FTV1-9 -
http://www.electro-tech-online.com/attachments/repairing-consumer-electronics/29958d1244193349-phillips-lcd-training-manual-pvd1075_lcdtv_training_handouts_244.pdf
http://www.scribd.com/doc/22235836/LG-Training-Manual-LCD-TV-42LG70
Posted on May 03, 2010
    President:
  • 1,768 Answers
Check the rectifiier diodes or diode pack.
you probably have an open in the primary side of the start up circuit.
Also check the yoke or transformer ( open windings) needs to be ohmed out.
Sony TV model # KV-J29 MF8 , sound ok in 1 min and led stdy.and no picture
check for bad voltage regulator ic. Check for 160v across your main cap and power supply. Use floating ground, to see if power supply is working. If you have 160v, check for 130v b+ to see if your horizontal circuit is working.
Nov 27, 2011 | Mitsubishi CS-40503 TV
Timmer keeps on blinking,cant turn on power
Check for 160v on your power supply to see if working. Can you hear high voltage? If not, check for 130v dc on your horizontal output transistor to determine if power supply or hv problems.
Nov 27, 2011 | Televison & Video
RED LED FLASHING WANT STOP/TV WANT COME ON
Check power supply to see if its working, check across main cap, Do not use chassis ground for 160v. If good, check for 130v on the collector of the horizontal output transistor, if missing voltage, check for either an open low value resistor in the power supply or an open pekoe fuse or a bad voltage reg ic.
Oct 31, 2011 | Toshiba 32A43 32" TV
Tv won't stay on it shuts off as soon as I turn it on and now there is a blinking light on the front and it's blinking 7 times
Most Sony's usually always have bad regulator ics. Depending on your model, could be a mcz3001 or str ic or mxoa ic. Check for 160v across the main capacitor for 160v to see if your power supply is working. Do not use chassis ground. Use the ground on the cap.
Oct 22, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Toshiba tv 32a43 power button flashes red and won't turn on
Check to see if horizontal output is shorted, But will have a damper diode, between the base and emmitter, will read 0 ohms. That's okay to check like that, Check for shorts between collector and emitter and collector and base. If ok, check for 130v dc on the collector of the horizontal output transistor.
Mar 26, 2011 | Toshiba 32A43 32" TV
If the voltage in h out is 200v is good or bad and the voltage regular is heat?
You mean the collector voltage on the Horz output transistor is 200 volts?
I would check this by removing the transistor and then measuring the voltage on the board (where the collector or center leg of the transistor is soldered to).
I don't know what kind of tv this is but you should see 130v or 135 volts.
RCA sets you should see 140v. If the voltage is too high replace the voltage regulator.
Mar 09, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Philips 20ps47s301 turns on then starts clicking and turns off
IT SOUNDS LIKE YOU HAVE A POWER SUPPLY PROBLEM OR RELAY PROBLEM. BEING A 20 INCH SET IT IS NOT WORTH REPIRING. PARTS AND LABOR WILL BE OVER $100.
Jan 16, 2009 | Philips 20PS40S 20" TV
Mitsubishi
Good Day, ya'll;
TRY THIS:
1. SHUTDOWN CAN BE CAUSED BY NO VERTICAL DEFLECTION. SINCE THE VERTICAL CIRCUIT IS POWERED BY THE SWITCHED POWER SUPPLY THE UNIT MUST BE TURNED ON TO TROUBLESHOOT THE CIRCUIT. THIS CAN BE ACCOMPLISHED BY TEMPORARILY DISCONNECTING THE VERTICAL INPUT TO THE X-PROTECT CIRCUIT. ** TO PREVENT DAMAGE TO THE CRT'S YOU MUST UNPLUG THE CRT PCB'S. ** TO DEFEAT THE X-PROTECT CIRCUIT, UNSOLDER D4A1 LOCATED OFF THE COLLECTOR OF Q4A1. IF THE UNIT POWERS ON AT THIS POINT, YOU HAVE CONFIRMED A VERTICAL FAILURE AS THE CAUSE FOR SHUTDOWN. ** D4A1 MUST BE REINSTALLED IN CIRCUIT TO PREVENT CRT DAMAGE. ** 2. WITH VERTICAL PROTECTION DEFEATED (D4A1 OUT OF CIRCUIT) WHEN THE UNIT POWERS R514 (PIN 11 OF THE FLYBACK) OPENS. CHECK PARALLEL CAP. C512 .33 UFD 400 V IF C512 IS GOOD REPLACE THE FLYBACK PART # 334P191020 ON THE MAIN PCB. 3. CHECK PIN 1 OF IC401 FOR 10.7VDC. IF LOW OR MISSING CHECK FOR SHORTED D4000 (PART #264P487030) LOCATED OFF PIN 1. (PCB-MAIN) 4. CHECK PIN 8 OF IC401 FOR 28.4VDC. IF MISSING CHECK FOR OPEN D520 AND R540 AT PIN 5 OF FLYBACK TRANSFORMER T503. (PCB-MAIN) D520 PART #264P102020 R540 (1.2 OHM 1/4 W) PART #103P398010 5. CHECK FOR DEFECTIVE IC401, PART #272P239040 ( PCB-MAIN) 6. CHECK R540 1.2 OHM 1/4 W OFF PIN 5 OF FLYBACK (PCB MAIN). 7. EXCESSIVE 130V SUPPLY. CHECK C911 47 UFD 100 V AND C914 47 UFD 50 V, IN THE IC900 CIRCUIT.
If you are not technical then you should call a factory authorized service dealer and an estimate, as you can see this can get complex.
Good Luck, big IRISH.
May 19, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Takes long time to "start" after power on
The problem in smps or in feed back, check electrolytic caps. in the smps. 100microfards/50volts ,47micr/50 volts 2 nos, then o/p of smps 100micr/160v, backside of EHT 10micro/50volts replace it.
Nov 18, 2007 | Philips 14PT1686 14" TV
Toshiba CF3566A
follow the diagram, the base of the hor out should go to the secondary of the hor drive transformer, and going to the primary circuitry you should find a transistor, a small transistor, look for its collector and you should find a filter capacitor, may not be the same value but it is the filter capacitor.
May 20, 2007 | Sony HMD A220 17" CRT Monitor
Televison & Video Logo
162 people viewed this question
Top Televison & Video Experts
Electro Med Services...
