Question about Dell 2130cn Laser Printer
Dell 2130cn Error 006-3170 Restart Printer
leroyal
  • 2120 Answers
SOURCE: Error #006-370 Restart Printer
call a Lexmark printer repair company
Posted on Jan 28, 2009
SOURCE: I have DELL color laser printer 2130cn error msg load SSF ??
Its not a printer problem more of the paper source of that document is selected as SSF. So in most programs go FILE>PAGE SETUP. Select the paper tab and make sure the correct tray settings is selected. I.E "Default tray" instead of "SSF". cLICK "Default" at the bottom to make this the standard document settings and the problem shouldn't crop up again.
Posted on Oct 20, 2009
SOURCE: Corrupt Dell 2130cn laser printer
Apparently the controller board needs to be replace.
Dell has agreed to do this, despite that the service period has expired.
Posted on Dec 08, 2009
SOURCE: Oki b6200 error code of 006 335
The laser went out. You have to have the ROS replacement kit. I priced it and it was $255 for it. They dont recommend doing it yourself. Its $75 an hr labor.
Posted on Sep 07, 2010
  • 46 Answers
SOURCE: My Dell 2130cn printer is
Replacing the toner will fix this problem.
Posted on Feb 28, 2011
What does the User Intervention on a Dell 2130CN printer mean?
Either the print was stopped from printing. check print queue.
Or the printer was turned off during print
Open the inspection doors
pull out ink cartridge, put back in
Check for paper stuck in printer
make sure you print Queue is empty
remove usb and turn off pc
restart and plug usb back
Mar 11, 2015 | Dell 2130cn Laser Printer
How to fix error 616-302
Automatic Solution for Novice PC Users (no manual option selections are required):
  1. Download the Dell 2130cn Printer Repair Tool
  2. Install the application after download completes
  3. Click the "Scan" button that appears on the first interface
  4. Click the "Fix Errors" icon that will appear once the automatic scan has finished
  5. Restart your system as usual
Jun 23, 2014 | Dell 2130cn Laser Printer
I have replace the fuser on my dell printer 2130cn. I'm getting an error code 010-421. I have rest the fuser but still getting error
If the NVRAM reset doesn't work contact dell support as they will likely replace the printer if it is still under warranty.
The recommended powersource for the printer is to be plugged in to an independent wall outlet. Thereasoning is that laser printers need a large surge of power to print and surgesuppressors are designed to not let any surges through. While the printer maywork for a while, over the long term it can damage the inner workings of theprinter. Plus, the way the High Voltage and Low Voltage power supplies arebuilt, together they work as a built in surge protector.
Sep 28, 2011 | Dell 2130cn Laser Printer
Where can i buy a print head device for a Dell 2130CN
At Dell.com - They call it a Drum Imaging Kit
Manufacturer Part# : Y459D ' Dell Part# : 330-1435
Dec 15, 2010 | Dell 2130cn Laser Printer
2130cn printer vertical light streak about 1/2 inch wide down the paper from top to the bottom of the page. using non-dell toner BD
Hello.
The most common reason is the toner. Replace the toner with another. Use a Dell toner, if possible.
Hope this helps.
Oct 19, 2010 | Dell 2130cn Laser Printer
How do you set the printer to print in black only after a color toner is gone. the printer is a dell 2130cn clolr laser
Try going in to your printer properties
Start - Printers and Faxes - RMB on default printer - properties (From drop down menu) - Advanced - Printing Defaults - Check the "Greyscale" box.
Now this the route using XP and a Canon printer, yours will be similar but also may differ slightly.
May 11, 2010 | Dell 2130cn Laser Printer
Dec 07, 2009 | Dell 2130cn Laser Printer
Dell 2130cn Laser Printer Logo
231 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
