Question about Neff S5946 Built-In Dishwasher
Spray arms not rotating
Poor washing performance and it seems like the arms are not rotating - plenty of water in the machine though. Makes a knocking sound when starting the wash programme.
  • 901 Answers
Check pump in the dish washer. Clean and check!
Posted on Apr 29, 2010
I have a Whirlpool dishwasher Type 583-1 Model WDT720PADM2. It is suddenly not washing or drying well. Leaving bits of food and layer of film on dishes/glasses. Soap is sometimes not dissolved.Help!
Assuming the machine fills and drains water ok, and is heating the water too, and you can hear the circulation pump running during the wash, the most likely problem is blocked jets in the spray arms. You have to remember that a dishwasher is NOT a garbage disposal unit, and plates must be scraped clean before they are put into the machine for a wash. Bits of uneaten food in the machine will clog the filters, coat the walls of the machine and work their way into the spray arm jets especially at the very ends. These end jets are the only reason the jets rotate, and if blocked the arm just sits still and poor washing results. Remove and / or examine the ends of the spray arms carefully - often fruit pips or pasta can be seen blocking the jets. Remove this with a pin and running water. Also then run a dishwasher cleaner through the machine, with No load in - do this regularly to reduce blockages and smells.
spray arms can be taken to pieces in most cases to clear blockages. Always use a top quality detergent in the wash for best results.
Feb 03, 2018 | Whirlpool Dishwashers
Why is the top spray arm not turning
All of the water coming to the upper spray arm comes through the feed tube. If the feed tube is blocked or the probe flapper is hung open, water will not flow properly to the upper spray arm. Be sure that when you push in the upper rack the manifold probe is in position in the feed tube. Try adding more water in the tub to see if the upper spray arm starts rotating. Other possibilities; low water charge, cracked spray arm & poor wash pump performance.
Jul 28, 2016 | Dishwashers
My Indesit dishwashers lower spray arm comes off resulting in flooding do I need new arm support
Yes. The water pressure in the hydraulic system is very important.
If more water flows through the hydraulic circuit of the lower nozzle, then probably that the upper nozzle will not rotate which will cause poor wash results.
Dado
Oct 25, 2015 | Indesit Dishwashers
Why are the items on bottom rack not being cleaned properly
If is clean dishes in the upper basket, I conclude that the pump produces enough pressure what means that the lower spray arm for some reason does not rotate and because that washing result is bad. Before washing I would check the lower spray arm rotates freely and after that open the door during washing and check if the lower spray arm rotates. Sometimes, the holes in the spray arm clog and disable turning which leads to poor washing results in the lower basket.
Dado
Aug 17, 2014 | Indesit Dishwashers
Frigidaire FFBD2403LW normal cycle hum
Hello ddux97 - Often this occurs because either not enough water is being pumped to the spray arm or in other words the full flow of water is not making it to the upper spray arm. Will the spray arm rotate freely? If it does not, then you might have to remove or replace the spray arm assemblies since it is possibly damaged. Confirm that the drain hose is strapped up properly under the sink to prevent the water from siphoning out during the cycle. If issue persists, I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully.
Jun 20, 2013 | Frigidaire Dishwashers
Both spray arms of my DU943PWKQ0 do not turn or spray. The motor is moving and the it drains without problem. During the wash and rinse cycle I can hear the sound of water, however it doesn't clean at...
Try rotating the spray arms by hand. It should rotate freely. If possible clean the arm rotating place by removing them.
Arms rotate by by pump pressure only. finally check the water pump also.
May 18, 2010 | Whirlpool DU943PWK - Multiple Color...
Lower dishwasher arm not rotating
Probably blocked spray arms is the cause of the unit not cleaning properly or rotating. Remove each spray arm (there are 3 in total) and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results.
Jan 25, 2010 | GE Dishwashers
Dirty dishes
if water comes into machine then valve is ok.
open machine when in cycle and look to see if spray arms are rotating
if not, then take out and clean.
spray arms only rotate with water jetting out of angled nozzles at end and if these are blocked then no rotation and poor wash
Sep 07, 2008 | Dishwashers
Poor wash performance - spray action not energetic enough
Same problem here! There's no obvious way to dissassemble, and on my model, MDB7100, I don't even have ability to clean the screens better than simply wiping them with my finger.
Am now considering strong cleansers, acids, and failing that, dynamite...
Aug 03, 2008 | Maytag MDB7100AWB Dishwasher
My Bosch dishwasher model #SHU43C05UC/14 drains well and has enough water(I replaced the inlet water valve already),but not washing the dishes clean especially the top rack.What could be wrong?
open machine when running and check both spray arms rotating - you will get a bit of water out. if spray arms not rotating, usual cause is debris in the arms. the spray arms only rotate by water jetting from angled jets at the end of the arms. take them out and make sure all debris removed
Jul 14, 2008 | Dishwashers
Dishwashers Logo
157 people viewed this question
Top Neff Dishwashers Experts
Cesar Quant
Cesar Quant
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
