Question about NetGear WGR614 Router
My Roadrunner Modem works fine when connected to an individual computer. When connected through my netgear modem I cannot get an internet connection on any computer wired directly to the router
  • 59 Answers
Does the modem worked fine with ANY computer connected directly to it, or just ONE computer connected to it?
did you have to install a connection program on one of your computers when you first installed the modem?
do you have an account name and password from your internet service provider, which is required to connect?
Posted on Mar 28, 2008
How to connect to the internet
Connect the computer directly to the modem and make sure that Internet is working through the modem.
Connect the modem and computer to the router with the Ethernet cable.
Open the setup page of the router and change the settings manually. So that your computer can access Internet through the router.
You can this website to know how to connect to the Internet using NETGEAR router.
May 21, 2012 | NetGear WGR614 Wireless Router
Wireless modems
Connect your computer via ethernet cable directly to your modem then power off the modem for 30 seconds that way should be able to go online if the modem and internet is working fine from your ISP.
Hope that helps...........
Jul 28, 2008 | NetGear WGR614 Wireless Router
Router problem. unable to connect wirelessly
This is usually up address conflict. You will have to assign the wifi or lap top to different IP addresses. You have to refer to the modem manufacturers instructions or search on net / YouTube how to do this. It's too detailed to do it here I think.
Oct 17, 2017 | NetGear WGR614 Wireless Router
Followed all the set up steps but my DSL light would not stay on
  • 1 Plug the Ethernet cable into the Internet port on your wall. If you do not have Internet ports installed in your home, connect a phone line adapter to a phone line jack. The adapter makes the phone line wider so Ethernet cables can connect to it. This does not block your phone from use.
  • 2 Plug the other end of the Ethernet cable into the Internet port on the back side of the Netgear DSL modem.
  • 3 Connect the Netgear DSL modem to a local power source. The power plug inserts into the modem via a small port on the rear of the modem.
  • 4 Insert a second Ethernet cable into one of the numbered ports on the back of the modem. Run the cable to your computer and plug it into the Ethernet port on the computer.
  • 5 Look on the back end of the DSL modem for an HTTP: address. Type this into your Internet browser's search bar. The Netgear DSL modem menu appears on the screen.
  • 6 Select how many computers are to use the modem, if you are using it with other DSL modems and set up a password (the default username and password is "admin"). Click "OK" to initiate the changes you made to the menu. You can now use your Netgear DSL modem to connect to the Internet.
  • Read more: How to Install a Netgear DSL Modem '
    Sep 27, 2010 | NetGear DGN2000 Wireless Router
    I am trying to reinstall a netgear wgr614v9 router. when i hook it up to my modem the internet light stays yellow and i can't connect to the internet. i did change the DNS settings in the router a couple...
    Make sure that your computer is able to go online directly through the modem.
    If your computer is able to go online through the modem, that means the modem is working fine.
    You will need to connect the computer to the router and the modem to the router.
    open the set up page of the router and change the settings of the router according to the ISP.
    Click Here for more information about the routers and network
    Mar 13, 2010 | NetGear WGR614 Wireless Router
    PS3 and Netgear WGR614 V7 Router
    Basically the PS3 wireless settings needs to be configures with the Netgear wireless router settings.
    To test if the modem is connects to the Internet, connect a computer into the modem, if it works then the modem is configured correctly. If it doesn't work, then contact your ISP and get them to test your modem connection.
    For details on how to configure the PS3 click on the WEB link :-
    Dec 20, 2009 | NetGear WGR614 Wireless Router
    How to connect Netgear to Time Warner internet modem? I have Netgear installed on my computer, and I have the internet modem plugged in to my computer.
    Just disconnect the ethernet cable from the computer and put it into the slot called internet on the router then run ehernet cable from port 1 to computer.
    Dec 05, 2009 | NetGear WGR614 Router
    Could not make router to work, Netgear modem adding router.
    i suppose you have to connect modem to router's "source" socket and modem to socket "in wall" then reset and reconfig router and you should be ok
    Nov 10, 2009 | NetGear WGR614 Wireless Router
    Have a new Hughes net HN9000 satellite service and trying to get the Netgear wireless router to allow me to connect to the internet. Have two other computer set up for the home network and they can see the...
    Hey, Can you perform the task below and paste me the results from the modem:
    Connect the modem to the computer. Open command prompt and type ipconfig. Paste me the results for IP address, subnet mask and default gateway.
    Also, confirm, how you have connected the modem to the computer. IS it using a ethernet cable or USB?
    Once I have this information, I will be able to provide you with an accurate resoultion.
    Jun 30, 2009 | NetGear MR814 Wireless Router
    I loose internet everytime the phone rings
    Absolutely. Wireless LAN is on 2.4GHZ. You will want to get a phone at a different frequency.
    Apr 05, 2009 | Belkin Computers & Internet
    NetGear WGR614 Router Logo
    120 people viewed this question
    Top NetGear Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
