Question about Maytag Neptune MDE4000 Electric Dryer
How to remove top of Maytag dryer
Replace belt
    President:
  • 1,554 Answers
The top panel can be lifted only after the front panel is removed. Open the door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top panel is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top panel lip.
Open the door then lift the front of the top panel and tilt it toward the rear of the dryer.
Reinstall the top panel and the front panel by following the removal steps in reverse order.
Posted on Apr 28, 2010
  • 184 Answers
SOURCE: Replacing belt on dryer
FIRST, OPEN THE DOOR AND REMOVE TWO PHILLIPS HEAD SCREWS ON EACH SIDE OF THE OPENING. TWO GO THROUGH THE HINGES, AND TWO ON THE OPPOSITE SIDE OF THE OPENING. THEN, PULL THE OUTER PANEL FORWARD FROM THE SIDES NEAR THE TOP. IT IS HINGED AT THE BOTTOM. LIFT IT OFF THE HINGE WHEN YOU HAVE THE TOP EDGE PULLED FORWARD. YOU WILL HAVE ABOUT SIX OR EIGHT 5/16 HEX HEAD SCREWS TO REMOVE
AND THE FRONT BULKHEAD WILL THEN COME FORWARD TO REMOVE. AT THIS POINT, THE FRONT OF THE DRUM IS EXPOSED AND YOU CAN SLIP THE NEW BELT ON FROM THE FRONT. PAY CLOSE ATTENTION TO THE DIAGRAM ON THE BAG FOR PROPER ALIGNMENT AROUND THE IDLER AND MOTOR PULLEYS. IT WILL BE EASIER TO INSTALL THE BELT IF YOU LAY IT IN THE GROOVE NEAR THE REAR OF THE DRUM, BUT THAT IS NOT IT'S FINAL RESTING PLACE.
AFTER YOU HAVE THE BELT AROUND THE PULLEYS, REPLACE THE FRONT BULKHEAD WITH FOUR SCREWS, ONE FOR EACH CORNER. MAKE SURE YOU DON'T FOLD OVER THE FELT SEAL AROUND THE FAN HOUSING. SLIDE THE LINT DUCT PORT INSIDE THE FELT SEAL. ONCE THE BULKHEAD IS IN PLACE, PULL THE BELT OUT OF THE GROOVE AND SLIDE IT TOWARD YOU UNTIL IT LAYS ON TOP OF THE MARKS THAT THE OLD BELT LEFT BEHIND.
ROTATE THE DRUM MANUALLY COUNTER CLOCKWISE TO BE SURE THE BELT IS ALIGNED AROUND THE DRUM.
IF IT IS NOT, THE BELT WON'T STAY ON THE PULLEYS.
AFTER YOU ARE SURE IT IS O.K., REASSEMBLE THE REST OF THE DRYER IN REVERSE ORDER.
Posted on Apr 08, 2008
ngfam1
  • 639 Answers
SOURCE: Belt replacement for a Maytag dryer - Model No. DE410
Peace Friend,
ngfam1 At your service!
There are many variables!
Every year thousands of people die trying to repair electrical appliances them selves!
You are worth more than that!
Bless you!
Only a trained laundry tech can make the electronic diagnoses.
Below I referred you to a great service nation wide!
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505 near me they only charge $75 service call which is reasonable in today s market!
Unfortunely, another point to consider!!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm1
*****PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF*****
Posted on Sep 02, 2008
Nitrotrike
  • 589 Answers
SOURCE: Open Dryer to replace belt
Here's a pretty good tutorial on disassembly. Just scroll down to the Maytag section:
http://fixitnow.com/2003/11/appliance-tip-of-day-dryer-disassembly.htm
Posted on Jan 11, 2008
  • 7 Answers
SOURCE: Maytag electric dryer mod#DE612 series02
U might want to look on the back of the dryer to see if there is a panel to take off. If not the hole top will have to come off. Is the top made on the rest of the dryer or is there a split between it.
Posted on Nov 24, 2008
jsrock516
  • 5911 Answers
SOURCE: Need routing diagram of dryer belt on maytag dryer D7600
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the following page, locate the "Dryer Belt Diagrams" link under the "Special Features" section. Scroll down to Maytag. The dryer belt diagram for Maytag should be listed as diagram E. I hope this helps you.
Posted on Jan 28, 2009
WORN BELT ON MAYTAG ELECTRIC DRYER
Remove the two brackets on the back holding the top on. Then pry the front part of the top off with a flat screwdriver. Next remove the electrical connectors. The remove the front panel. Then pull the drum out. Install the belt and push the drum in place placing the belt correctly into the tensioner for the belt
May 10, 2010 | Maytag PYE2300AY Electric Dryer
How do i remove the drum on a maytag top-loading washer.MAV 7000aww
If you want to remove the drum of your maytag wahser follow this procedure:
  1. Disconnect the power supply to the Maytag dryer by unplugging it from the wall outlet.
  2. Use a screwdriver to remove the three screws located at the top of the control console.
  3. Pull the control console forward to release the tabs that hold it to the Maytag dryer top. Maneuver the control panel out of your way without disconnecting any wires.
  4. Use a putty knife inserted between the top and front panel to disengage the retaining clips that secure the top panel of the Maytag dryer. Lift the top panel up, and remove it from the dryer.
  5. Use needle nose pliers to remove the wires from the door switch terminals. The door switch is located just inside the front right corner. Grasp the wire leads with the pliers and pull them off the terminals.
  6. Use a screwdriver to remove the retaining screws that hold the front and side panels together on the Maytag dryer. Lift the front panel up and out of the work area.
  7. Use a screwdriver to remove the Maytag dryer drum light lens screw. Press the locking tabs on the light socket, and remove it from the cavity of the drum.
  8. Use a socket wrench to remove the four retaining bolts that secure the drum bulkhead to the sides of the Maytag dryer.
  9. Reach your hand beside the drum and the motor, and push the idler pulley forward to release tension on the belt. Make notes of how the belt is routed on the pulleys, and then remove the belt from the motor pulley and idler pulley.
  10. Grab the belt with one hand, and the Maytag dryer drum with the other. Pull the drum out of the front of the dryer.
Jan 30, 2010 | Maytag Washing Machines
MDG4000 maytag neptune dryer.... When you push start, I see it has power by the light that flashes, but the dryer doesn't start. What is wrong? Thanks
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 13, 2009 | Maytag MDG4000 Dryer
Replacing the belt for Maytag Atlantis Dryer Model MDE7600AYW. What steps do I follow ??
Jun 10, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Belt replacement on an electrical maytag dryer
hi. thanks for the question. to replace belt . lift up top, remove front panel, slip belt over drum. reinstall front and top, and clean all lint . pull dryer from wall ,remove back panel . motor on right, idler pulley on left, pull belt through idler and to your motor.
May 13, 2009 | Maytag PYE2300AY Electric Dryer
How to change belt on maytag model MDE9206AYW dryer
Hi welcome to Fixya
You must pop off the top of the dryer then remove the front after the front is off you can remove drum .
The belt goes around the drum and the motor pully and under the tentioner wheel after you get belt on replace front and top.
PLEASE MAKE SURE TO UNPLUG FROM POWER THIS IS 220volts AND CAN HURT YOU BAD
Thank You For Useing Fixya
PLEASE RATE ME
May 02, 2009 | Maytag MDE9206 Dryer
Replace dryer belt
Pull the front panel off, remove the top screws and tilt top back. Rout the new belt around drum at the old wear spot with the grooved side against the drum. Next remove the back access door and rout the belt around the idler pulley and motor pulley. There is only one way to do this and get proper tension on the belt.
Also, when you order the belt, ask if it has a belt routing diagram on the belt package.
Apr 07, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Dryer Repair
Easy fix.
Open the top cover by insrting a putty knife in the top right and left sides where the top meets the bottom cabinet.
Lay the top to the back.
Remove 2 screws on the right and left front inside corners of the cabinet.
Remove the door.
Replace the belt around the drum and motor pulley.
Re-assemble the dryer.
Mar 10, 2009 | Maytag PYE2300AY Electric Dryer
Put dryer belt on maytag dryer
generic maytag dryer belt replacement
type 1:older models by Maytag with lintscreen under door
  • unplug dryer
  • remove 2 screws from under front panel
  • tilt front panel up from the bottom and unclip top
  • remove door switch wires
  • set front panel aside
  • remove front drum retainer 2 screws each side
type 2:newer models by whirlpool lint screen in top cover
  • unplug dryer
  • remove lint screen
  • remove 2 screws under lint screen
  • with putty knife or other blunt blade
    unclip spring clips at front corners of top panel
  • remove 1 screw each side of front panel 1/2 way from top
  • remopve door switch wires
  • tilt front panel down and unclip
all
  • withdraw drum forward
  • examine drum rollers for wear
    if worn or locked replace in pairs
  • examine felts and nylon glides(if fitted) for wear
    if worn replace
  • examin case floor for tensioner
    (sometimes broken belt ends pull the tensioner out of place its easy to see the slots on the case floor for the 2 feet and spring, looks like a power socket)
  • loop new belt around drum at wear mark of old belt
  • insert drum
  • loop belt around motor pulley
  • pull tensioner to end of travel against spring
  • loop belt around tensioner
  • relax tensioner
  • rotate drum by hand to make sure belt wont jump off
reassemble in reverse order
Oct 29, 2008 | Maytag Dryers
I believe the belt on my maytag electric dryer model LDE412 is going out. How to I get to the belt to remove it for replacement? Through the front of the dryer or the back?
Remove the front panel(s). and you will be able to remove the top panel, which will give you access to the top of the drum and be able to replace the belt. There should be a small pulley at the bottom of the dryer where the belt attaches to, as well as around the entire drum.
Jul 03, 2008 | Maytag Dryers
Maytag Neptune MDE4000 Electric Dryer Logo
1,832 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
