AOpen MX4GVR INTEL 845GV Motherboard Logo
Posted on Apr 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Memory ddr333 - AOpen MX4GVR INTEL 845GV Motherboard
Azrael SRL
Level 3:
  • Master 11,800 Answers
  • Posted on Apr 28, 2010
Azrael SRL
Master
Level 3:
Answers
11800
Questions
0
Helped
2565367
Points
35672
Yes, it can run DDR333 or 400.  Just that it will run them as DDR266 = slower than what they are capable.
RAM upgrade
(1) flip the Notebook/Laptop PC over - see Fig.1 below
(2) find the memory cover - it really easy to find in this photo.
Fig.1 Toshiba M35X bottom view - the memory cover is seen at center left and secured by a single screw.
(3) remove the (1) screw securing the memory cover.
Fig. 2 Toshiba M35X laptop shown with memory cover removed and HDD (Hard Disk Drive) removed, and with the HDD cover flipped up.
The RAM (SO-DIMM boards) are visible at center left.
The HDD cover is seen at the bottom of the photo.
(4) Using proper anti-static/static control techniques, clip alligator clip or your anti-static wrist strap to a frame ground of the laptop at an I/O connector or frame ground under the HDD cover.
(5) carefully remove (2) old 256 MB SO-DIMM DDR333 memory modules.
Store old memory boards in the anti-static plastic baggie in which the new memory boards were shipped.
(6) install (2) new 1GB SO-DIMM DDR333 boards, for total of 2GB of system RAM.
(7) reassemble system, and boot OS (operating system).
The laptop's ROM BIOS will auto-detect the new RAM and begin a standard POST (Power-On Self Test).
(8) If OS is MSWindows, it will also auto-detect the new memory, and allocate it to application software.
The technology of the Toshiba Satellite M35X-S349 memory module is called
DDR333, meaning DDR (Double Data Rate) SDRAM (Synchronous Dynamic RAM), at a memory bus speed of 333 MHz.
The Form Factor of the DDR memory card is SO-DIMM, which stands for Small Outline DIMM (Dual In-line Memory Module) (see photo).
Reference: http://en.wikipedia.org/wiki/DDR_SDRAM
Reference: http://en.wikipedia.org/wiki/SO-DIMM
Fig.3 Each 1GB SO-DIMM DDR333 memory module will look like this one.
The Toshiba Satellite M35X-S349 supports a maximum of two SO-DIMM memory modules.
Each memory module can hold (a) 256MB, (b) 512MB, or (c) 1GB,
in the SO-DIMM Form Factor compatible with the Toshiba M35X-S349 Notebook PC.
2answers
I want to know what type of RAM my RZ 81845gvm-rz supports is it DDR1 or DDR2
This page has the specs for the board. It has two slots for DDR266 or DDR333 RAM, up to 2GB.
2helpful
Fujitsu seimens scenic p300 no chipset drivers where can i get them from
Specification Processor:
Celeron
Intel P4
up to 2GHz
up to 2.66GHz
up to 2GHz
up to 2.66GHz
up to 2.4GHz
up to 3.0GHz
up to 2.6GHz
up to 3.2GHz Motherboard: D1451 D1521 D1561 D1761 Chipset i845GV i845GE i865G SiS661FX Video: On-board On-board + AGP slot On-board + AGP slot On-board + AGP Slot Max Memory 1GB DDR333* 2GB DDR333 2GB DDR** 2GB DDR Memory slots 2 2 4 2 Audio STAC9750 AD198x AD198x Realtek ALC655 On Board Lan AN983B 82562ET 82562EZ AN983N Hard Disk: Depends on choice at time of purchase - 20/40GB (5400rpm), 20/40/80GB (7200rpm silent). CD/DVD Drive: Depends on choice at time of purchase - Cdrom ,DVD or CDRW * 2GB (DDR333) with future memory modules
** 4GB (DDR333/400) with future memory modules
http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/professionalpc/Scenic/ScenicP/scenicP.htm
You know, if you can decipher your motherboard, You'll be able to find the intel chipset and do a download. Make sure you save/rename your old.
2helpful
2answers
ASUS P4S533-MX MOTHERBOARD FAILED TO RECOGNIZE DDR400/DDR333 RAM
In you case compatibility is your problem or your memory needs a clean up. First clean up the memory's pins. Use a pencil eraser. Then try only one by one so that you will know if there is a problem in each memory. Insert one of the memory then turn on your PC. If it boot up or it is okay try the other one. Then if it is also okay, try both of it inserted and turn on your PC. If it not okay there is a compatibility problem. Make sure the brands are the same so the compatibility are never be a problem.
3answers
Whether DDR is compatible for hp pavilion dv1000 or only sdram is compatible. With which ram can i upgrade.
According to the maintenance manual only 266Mhz Ram can be added to the notebook.
This would be SDRAM.
Hope this helps!!
Kind regards!!!
2helpful
3answers
Is their a special make of memory card, ie: ddr
According to: http://www.shopping.com/xPF-VIA-MB-FOXCONN-VIA-KM400A-400M01-G-6L-R
this motherboard has 2 slots for DDR (184pin) RAM,
and supports a maximum of 1GB of RAM per slot.
Note that DDR RAM comes in 3 speeds: DDR266 (slowest), DDR333, and DDR400 (fastest).
Buy the fastest RAM -- if the motherboard cannot run the RAM at "full" speed, the RAM will automatically slow itself down to a speed that the motherboard will support.
RAM memory: upgrade , Motherboard PCCHIPS M863 2 slot
Memory Support
• Two 184-pin, 2.5V DIMM sockets for DDR SDRAM memory modules
• Supports DDR333/266 memory bus
• Maximum installed memory is 2GB
This is what your looking for
2answers
Hello!
I think the best solution to your problem would be either to go to www.crucial.com or www.tigerdirect.com . They both have memory configurator tools that will make sure the memory that you are purchasing is compatable with your laptop. That is your safest way to know. I myself prefer tiger direct, they seem to have the lowest prices. the link below will take you right to the memory configurator. If the DDR333 is an option it will let you know. Hope this helps! :)
http://memoryselector.cnetchannel.com/tigerdirect/
Memory Card for MV42N Motherboard
The Shutle MV42N can take SDRam or DDR
Each memory slot can hold DDR PC2700,DDR PC3200,
up to 2 gig total. the pc 2700 is DDR333 and the PC3200 is DDR400. Why Stop at 256?
2answers
Recommended memory for p4i45gv R5.0
IF UR RAM IS SDRAM THEN U CANT UPGRADE TO DDR BUT IF ITS ON DDR RAM THE U SHOULD B ABLE 2 UP GRADE 2 1GIG OV DDR RAM RUNING AT 400MHZ
Top AOpen Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Alfredo Mtz
Alfredo Mtz
SmartAviator
SmartAviator
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
