Question about Canon MultiPASS F50 All-In-One InkJet Printer
Canon multipass 550 will only scan wont print or copy alarm light keeps blinking and screen says wrong cartridge i cleaned cartridge contacts but still same alarm code what should i do
  • 385 Answers
The printhead is faulty and needs to be replaced!Good Luck!
Posted on Apr 29, 2010
Alarm on: reads wrong cartridge in window
Problem may be due to your not printing for quite some time. The ink can start to dry and clog the print heads.
Use a Q-tip slightly moistened with water to clean cartridge ports and print head.
Jun 13, 2010 | Canon MultiPASS MP700 All-In-One InkJet...
Printer will not print
Hi, you can try to remove the cartridge and try cleaning the contact switch on both printer side and cartridge side.
Jan 26, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
I have a Canon MulitPass MP730. Wrong Cartridge message.
It's worth repairing, That error on a Canon is saying that the printhead is bad, not your cartridges. The part number for your printhead is stamped on the side of the printhead could be QY6-0049-000 but I'm not sure.
Jan 10, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
I have a canon multipass 730. It will not work and
Wrong cartridge means that the printhead is bad. Don't take it apart yet, you need a printhead.
QY6-0064-000 about $60.00
Sep 24, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Weong cartridge error on my LCD screen--I cleaned
Wrong cartridge error is a problem with the printhead, needs to be replaced. Qy6-0064-000, aprox. $40.00
Jun 22, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Alarm message wrong cartridege
You just need a new printhead, wrong cartridge on a Canon means the printhead is worn out.
Apr 29, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Horrible grinding noise
The problem sounds like a broken or stripped gear in the printer. If the unit is under warranty I would contact the authorized repair station for that printer in your local area.
Nov 10, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Ink cartridge
The real problem is that the waste ink tank is nearly full
Correct code procedure for resetting the Canon MP370
Reset Waste Ink
1) Enter SERVICE MODE.
By pressing the black button
with the star (in a
head ?) above it, followed by
scan, copy, scan
2) Select TEST MODE (press right
arrow button 13 times).
3) Select [8] PRINTER TEST
4) It'll now say "- 8-2 +" press
the right arrow key once
to get "- 8-3 +" Hit ok.
5) Select 0. [INK COUNT].
6) Press the ok key.
7) It should return to showing
the "8:
Printer Test - 8-3 +"
8) Press the [Stop/Reset]key -
black key with triangle and
circle on it –
(returning to the state of 3)),
and then press the [ON/OFF]
key.
Good Luck and don't blame me if it
goes wrong !!!!
Now you can print again, but it has not solved your full ink-tank, that has to be solved in future.
Theo
Jul 08, 2008 | Canon MultiPASS MP370 All-In-One InkJet...
Alarm/printing
Are the cartridges re-manufactored or original canon cartridge?
Most cartridges have chips or fuses that burn out when the cartridge has been used. Then when you get it re-filled the cartridge is already rendered useless.
If the cartridges are orignal canon then you may have another issue perhaps with the printer head, in a last resort you should try to clean this will alochol and a cotton bud "lightly"
Jan 26, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Canon MultiPASS F50 All-In-One InkJet Printer Logo
100 people viewed this question
old marine
old marine
