Question about Ovens
KENMORE OVEN C970-417757
My oven will not heat anymore. 4 yrs old. Won't work on bake or broil. My control panel has power, I've reset the breaker, I checked the heating elements and they are fine. I though maybe it was a swtich because when I set my oven on bake and there is no clicking sounds. usually there is! Do you have any suggestions of what could be the problem or where i could find the switch , is it behind the control panel... how do i test the switch?
  • Kreeft Mar 25, 2008
    Ok, I've checked the voltage from the wires ( no plug ) and i am getting 120V and 220V.
    I had called for parts and I asked about a new circuit board and a rebuilt one is $129.99 and a new one is $401.99. If you think it is a circuit board, is that something i could switch out myself.... of course being careful to label the wires when i disconnect them! Is a rebuilt one a good option?
    Another thing i noticed was that when I close the oven, the light will not work inside. If that gives you any more clues.
    Any of tips would be great ....
    Thanks
  • Anonymous Dec 12, 2008
    exact same oven range, exact same problem. Were you able to fix it?
    Problem Solver:
  • 7 Answers
Possible solution for above...this would apply to any electric oven.
First of all there are two elements.. one for baking (lower) and one for broiling. (upper) . I assume the lower is not working but is the upper.
Unplug the oven. Then remove the element and have a look at and the connections.
I found that on an lolder ovens where I thought the element had burned out that the electrical connections- ( screwed or spade connection) was so badly corroded that electrical contact was poor. I might add that this was also a fire hazzard.
Drudgedread..
Posted on May 10, 2009
  • 52 Answers
Check the power and make sure it's getting 220. Make sure the plug didn't come loose from the wall first. I have seen this happen before, where one of the legs on the plug wasn't plugged in completely. If the oven is only getting 110v, it will work otherwise, but you will get no heat. Check it and let me know if you need further help.
Posted on Mar 25, 2008
My Frigidaire convection oven will not heat up. What would be the cause?
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times:
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Jun 10, 2014 | Frigidaire 30" Built-In Single Electric...
Will the oven work without the broiler attached
You could use the oven without the broiler. It is customary that the oven will use the broil element to even out the heat in the oven for better baking but you could use if. it just may not bake evenly. There could be two things that is causing the broil element to stay energized. the control is not shutting down or there is a short to ground in the broil element. Have the broil element tested, it could just need replacing. If it is in the control that is a bigger problem.
Mar 19, 2014 | Ovens
Oven not working
5.
6.Even a bad relay door switch will hinder your oven from operating.
THINGS TO CHECK:
the broil element
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The bake element
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
Mar 10, 2014 | Belling XOU252 Electric Single Oven
Es330 gas range
THINGS TO CHECK:
the broil element
The bake element
Feb 11, 2014 | Frigidaire Ovens
Broiler element doesn't heat
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on-
Oven Won Turn on
the broil element
Feb 09, 2014 | Thermador SEC301 Electric Single Oven
Fan oven is not heating
5.
THINGS TO CHECK:
the broil element
The bake element
Jan 24, 2014 | De Dietrich Ovens
Oven not heating- both baking and broil elements
It may be possible that the electronic control is bad. On some models there are three relays one for the bake and one for the broil and one for the common. This one goes out and the bake and broil will not work. The control is fairly expensive you may want to have a tech check it out.
Nov 10, 2013 | GE JTP15 Electric Single Oven
Jenn-air expressions 27" convection wall oven model wm27460 won't heat
reset your breaker reprogram the clock try again what happend last time it was working self clean broiling etc
Dec 27, 2007 | Jenn-Air JJW8530C Expressions Collection...
Can't turn off my Kenmore 47833
check to see if the connections are good on the back of the control board and if they are good then you need to replace the control board (clock) assembly let me know how you make out
Sep 01, 2007 | Kenmore 47834 / 47832 / 47839 Electric...
Ovens Logo
2,039 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
