Voids on copy. What do I clean and how do I do it?
    Champion:
  • 224 Answers
Voids on copies can be two things, 1st it can be caused by moisture in the paper, try fresh paper out a sealed packet. two- the developer is at fault and may need to be topped up or replaced
Posted on May 11, 2010
Dirty copy result even if i replace a new drum
There are small wires that charge the drum to transfer image. Not sure if they are in drum unit or not on this machine. If the transfer chargers are dirty they will cause a dirty or voided copy. Make sure document glass is clean. Unplug machine check for these small wires if dirty gently clean with cotton swab or soft towel. Hope this helps
Mar 02, 2014 | Kyocera FS-1135MFP Copier require feeder
A voided line prints vertically on all copies
Are the lines only showing up when you are using the doc feeder? If so, you may want to clean the white - out off the adf slip glass.... If that is not the problem, it may be the drum unit or the developer unit. Also, it could be in the optic's of the scanner. Good Luck
Mar 22, 2011 | Canon imageRUNNER 2270 Copier
Lines in copies
What kind of lines? If they are white & void areas > you need new corona wires. If they are black lines > you may need a new drum cleaning blade or a upper fusing roller or you need all of the above.
Sep 07, 2010 | Canon NP 6050 Copier
Voids when copying
voids or arears of no print could be two things. moisture in paper. try fresh paper out a sealed packet. two- the developer is at fault on needs to be topped up or replaced
May 05, 2010 | Office Equipment & Supplies
MY COPIER WONT COPY THE ENTIRE IMAGE, MISSING ABOUT 3/4" OF TEXT ON RIGHT HAND OF PAGES
Ensure that you do not have image shift or border erase activated.
Also many copiers will not copy 'edge to edge' as they require a void lead edge to ensure that the copy does not jam in the fuser unit and a void tail egde to ensure that the same is true when duplexing.This adjustment should be done by a qualified technician.Also make sure that your original is not larger than your copy paper as you will have to reduce the image.
Oct 10, 2009 | Sharp AL-1655CS Copier
The image is smudged only on black. We have cleaned it as best we can using the manual instructions but we still have smudgey copies.
Sounds like you need a new black drum. If the smudge looks the same each time, you may have something on the drum that can be cleaned off, such as adhesive from a label. If that's the case, you can sometimes get away with cleaning the drum with a soft cloth and rubbing alcohol if necessary. Alcohol will leave a void spot for few copies, but will eventually go away unless the drum is really old, then it may not.
Oct 08, 2009 | Konica Minolta bizhub C250 All-In-One...
COPY QUALITY
Voids are most often caused by lack of sufficient developer, which needs to be changed by a technician. developer has metal beads in it to draw the toner and make a full (dense) copy or print. these beads wear out or "dump" which initially cause gritty prints, then washed out prints. hope this helps.
Jul 09, 2009 | Toshiba e-Studio 45 Black and White Copier
My copies have a thin line from top to bottom that is very light to no print at all. The thin line is at the same place every time but the rest of the copy looks great. I have replaced the drum and toner...
You probably have some thing in the developer unit, if you take out the developer and check the bag roller and brush, if you slowly turn the dev unit you might see a void area that is being passed onto the drum.
If the developer has a large numbers of copies on it then dump the developer and replace the starter.
Make sure the developer get thoroughly cleaned especially behind the blade.
If the developer is not all that old, then lift the blade off and clean the backside of the blade, and the area or areas of the brush that have the void.
Hope this is of some help.
Ed
May 09, 2009 | Xerox 5100 Copier
Paper jam at fixing unit when copying page with black border and complete tx fax function the tx report will comes out
Does the black go all the way to the very edge.ALL copiers have a void area around the edges of the copy....to prevent the copy from sticking to the fuser roller, which operates at nearly 400 degrees while copying.The void area can be as much as 6 mm all the way around, that is to say, all 4 edges.without the void area, the copy will always jam at the fuser or fixing unit.Good Luck
Mar 26, 2009 | Canon imageRUNNER 400S Copier
Copies have a void area the length of the copy approx 1 inch wide
pull out your toner unit and look at the front to see if there is a missing spot on the roller where there is no toner. if not you probly need a new drum.
Nov 12, 2008 | Sharp AL 1631 Copier
37 people viewed this question
jasbo
jasbo
