Question about OKI MICROLINE 390 Turbo Matrix Printer
Paper needs to be a little lower when it prints, it;s printing too high
  • 251 Answers
Hi,press the offline button , manually turn the paper feed knob back a few clicks then press the set button and remember to switch the printer mode to online
hope this helps
Posted on Apr 28, 2010
Why do the prints have horizontal lines of no ink or very little ink?
Bad or clogged printheads or you need to align the print heads. This will also happen if you try to print high quality pictures on cheap paper. Full color prints require either a photo paper or at least a colorlok paper to produce good results.
Sep 06, 2014 | HP Photosmart 7520
Print Job Keeps Cancelling
your computer may not be able to provide that high of a resolution to the printer. It would be like trying to take a color picture with black and white film.
Apr 17, 2014 | Epson WorkForce WF-3540 All-in-One Printer...
Error light blinking Citizen -S300 printer
  • High-speed (200 mm/s) printing
  • Longer cutter life (2 million cuts) delivers lower maintenance costs
  • Greater reliability delivers longer life & lower maintenance costs
  • Wider paper width allows printing of additional information & larger fonts
  • Interchangeable interfaces
  • 2D barcode (QR-code and PDF417) support allows wider applications
  • Built in buzzer provides audible alert without adding extra cost devices
  • Built in power supply eliminates unsightly "brick" and frees up space
  • Cash drawer kick-out external device port supports 2 cash drawers
  • 2-color printing supported (when specified paper uused)
Aug 16, 2011 | Citizen CT-S300 Printer
Trying to print - got Warning message THe paper cassette is no set correctly. Check for any objects in the cassett of block the cassett path and insert correctly
This can also be caused when the upper cassette tray (for small paper stock / photo paper) becomes detached from the lower tray. There is a gear attached to the lower paper tray which handles movement of the upper paper tray. Make sure that moving this gear causes the upper paper tray to move. If it doesn't, then you need to snap the upper paper try on a little better.
Jun 26, 2011 | Epson Stylus Photo 810 InkJet Printer
Ever since I replaced the toner, I've been getting echoes of whatever I'm printing, appearing about four inches lower on the page. For example, "Dear Tom" would show at the top of the letter as...
(1) Check the paper used meets the recommended paper specifications.
Damp paper, thick media or rough surfaced paper can cause the problem.
(2) Check the machine's environment. High temperature and high humidity
conditions can cause the problem.
(3) Check that the appropriate media type is selected in the printer driver.
(4) Try installing a new drum unit.
Apr 07, 2011 | Brother MFC-8460N All-In-One Printer
My HP LaserJet P4015n is making a high pitched noise when I print. It is also printing very slowly.
Same thing happened to mine at work. All because the paper tray indicator was not exactly on 'letter' size.
Remove the lower tray and remove all of the paper. Insure that the 2 paper size selectors are exactly on the marks for the size of paper you are using.
My HP4015N is now running at full speed with NO ANNOYING HUM!!
Nov 10, 2010 | HP LaserJet P4015N Printer
Paper from Tray doesn't load.
put paper in the upper slot (known as the MP), pull all paper from lower tray, send document to print and see if it prints ok - if it does, the problem may be with the lower print drawer - there is a spring under metal pad that lifts paper so it's grabbed by the printer paper transport. the spring may have broken or become dislodged so separation pad (the metal plate holding paper up) remains down - the transport "thinks" there is no paper
Jul 08, 2010 | Brother MFC-8460N Laser Printer
MY PRINT OUTS HAS LINES
your printer has either:
1.low ink
2.the movement of the in slider is to slow
3.the paper is going too fast when it is printed
i sugesset you either take it back (if its new) ,or get a new printer
Dec 31, 2008 | Fargo Persona C11 Thermal Printer
Photos print wet and smudged
all the dx /cx range do this when printed on the high quality settings you just have to let ink dry about half hour or use a lower seting when you print on gloss paper hope this helps
Dec 07, 2008 | Epson CX8400 All-In-One InkJet Printer
Pictures printing with stripes of color in some programs but not all programs.
Try new injet cartidges. If your printer has separate head and ink combo, replace the jets. The high quality mode operates the piezo jets at full power and lower setting can cause jets not to open as far. On some preinters, your particalar problem can be the result of too thin paper and the economy setting being used. Use 18lb or 20lb paper and see if it still does it on normal print mode.
Apr 27, 2007 | Canon MultiPASS MP730 All-In-One InkJet...
OKI MICROLINE 390 Turbo Matrix Printer Logo
159 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
