Question about Canon imageCLASS D780 All-In-One Laser Printer
Incorrect paper size
Our printer/ copier/ fax continually gets the INCORRECT PAPER SIZE alarm with every incoming fax. We never know aht will fix it. We try putting in letter size in the cassette and also the side feeder and sometimes that works but sometimes not. We use strictly legal size and have used this unit with ONLY legal size paper for 4-5 years now. We have always used legal and have never had any problems until 2 weeks ago or so. Cannon was of no use and said the unit is not designed to auto re-size incoming faxes to legal from letter size but does convert from legal to letter via the RX setting. I guess the magic spell then has worn off our unit that allowed it to do that. Any ideas?!
2 Suggested Answers
6ya staff
SOURCE:
muntejaya
Muntejaya Ginting
  • 10421 Answers
SOURCE: Canon ImageClass D680 "Incorrect Paper Size" error message
Hi, please get new driver here: www.driversdown.com/
www.nodevice.com/driver/company/Canon/Printer.html
www.usa.canon.com/cusa/office/products/.../hs_1200ts
Jay kbxlz
Posted on Feb 12, 2011
I have a Laser Class 710 and the error light keeps blinking. There is a message that says "incorrect paper size received in memory". How do I get rid of this?
Someone has probably sent you a fax on 8 1/2 x 14 inch (legal size) paper. Pull down the manual hand feed tray which is located above the regular paper cassettes and place some legal size paper in it. Hopefully the fax will be outputted and the message will go away. Good luck.
Jul 15, 2011 | Canon LaserCLASS Fax 710 Printer
I am feeding a portrait fax letter size and it is being received partially - one half is cut off. please explain
It sounds as if the document feeder is not recognizing the proper size of paper. Try making a copy, is the copy correct or is the copier indicating to load a certain size of paper. The paper width guides as well as the raised tabs on the document feeder tell the copier the proper paper size. Could the problem be on the other end? I know I have several customers that have the paper size dials or indicators incorrect for the paper in their cassettes. This would be if only a single reciever of your fax is complaining. You may want to see if rotating the fax in the LTR-R direction works.
Dec 03, 2010 | Canon imageRUNNER 4570 Copier
A fax was coming through and stopped. The fax
change the orientation of the paper supply and or size.. portrate or land scape.. check your printer settings in your display on the paper supply size and type
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
Mar 31, 2010 | Canon LaserCLASS 510 Printer
Incorrect paper size so fax was received in
That suggests a sensor is jammed or damaged... sorry I know no more.
Nov 04, 2017 | Canon FAXPHONE L170 Plain Paper Laser
Deleteing an incoming fax job that has stopped printer . The incoming job has the incorrect paper size.. and i cant choose that paper size. I can not delete the job as usual, the delete button does not...
On most Bizhub Copiers if you have something stuck in memory that is tying up the machine you can turn it off and unplug it from the wall for 10-15 seconds and then turn it back on. Doing this will erase the Random Access Memory and should clear all fax and print jobs from the machine.
Aug 12, 2009 | Minolta bizhub 200 All-In-One Printer
Machine refuses to print incoming fax. "Paper mismatch"
HP Printer 7210 or 7310 Gives Error receving faxes Load a new blank paper on paper tray.
Press * and # simultaneously, and then release both buttons.
Press 1 , 2 ,and then 3 . The Service menu appears.
Press the right arrow button (>) until the System Configuration menu appears then press OK.
Press > until Media Sense Calibration or Calibrate Spot Sensor appear and then press OK. The unit should pick the paper and eject it.
Press the Cancel button until date and hour appear on display
Mar 05, 2009 | HP Officejet 7210 All-In-One InkJet...
Size of received/sent fax
you must have the reduction mode on in the fax section. This allows incoming faxes that are larger than the size paper you have available to be printed. You may have you paper set in a direction or size paper that is not the same as the fax being sent.
Nov 17, 2008 | Panasonic Workio DP-1820E Copier
Incoming fax problem
DON'T KNOW IF THIS WILL HELP-BUT MY PROBLEM WAS SIMILAR--MINE WAS SAYING PAPER TOO NARROW WHEN I WAS TRYING TO PRINT AND COPY. I JUST KEPT MOVING THE FRONT SLIDER AND THE LEFT HAND SIDE SLIDERS BACK AND FORTH AND TOOK THE PAPER IN AND OUT --TRIED AGAIN AFTER EACH TIME--IT EVENTUALLY FIGURED OUT I DID HAVE THE RIGHT SIZE PAPER--
ALSO TRY---MENU--THEN--COPY SET-UP--THEN PAPER SIZE--SEE IF PAPER SIZE IS SET RIGHT.
Mar 01, 2008 | HP OfficeJet 6110 All-In-One InkJet...
You may have a fax in memory that requires a larger size. Try putting legal in the tray and see if it prints out anything. Also, look in the set up menu to see if there is an "auto reduction" mode. That will make any over sized incoming faxes automatically print out on the size paper you have in the tray.
Nov 17, 2007 | Canon FAX-L380 Plain Paper Laser
Canon imageCLASS D780 All-In-One Laser Printer Logo
89 people viewed this question
Clive
Clive
old marine
old marine
Ekse
