Question about Acer Aspire One Netbook 8.9" Notebook
When I turn the machine on, the power LEDs comes on, but the screen is totally blacked out. Please help
    Scholar:
  • 151 Answers
This sounds like the common BIOS flash fix.
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS.
Posted on Apr 28, 2010
  • 185 Answers
Screen not working
are you able to hear the windows log in?
if you do but no image, most likelly your video card is ruined. overheated or dropped maybe? don't worry is bad but not that bad, there is a way to fix that by a professional.
take it to a computer repair shop and have them check the video card ask if they have a rework station or someone who may they have to unsolder about 50 pins at the same time get a new card and solder it again.
sometimes they apply heat to it and it will work again but for just a few days maybe weeks but it goes bad again. so replacement is the best option.
I used to charge about 200 bucks but you may be able to ask for a rebate.
do not take it to a major computer store they would tell you there is no repair so you can go in and get a new computer.
if it works for you leave a comment and rate me
thx
LG tv black screen with sound
Hi Tommy,
This is a common problem with LG LEDs. It is a backlight failure. Either the backlights are not receiving the power to drive them or some of the LEDs in the backlight array have failed.
I hope it helps.
Good Luck.
May 25, 2016 | LG Televison & Video
Hp pavilion black video
This is a RAM problem. It can happen when you open your computer and tamper with it or just mishandling such as dropping laptop
May 26, 2012 | HP Pavilion Computers & Internet
My laptop screen is black and caps lock and scroll key are flashing
That is a security configuration on HP Laptops, depending on the way they blink is the problem your machine has.
Here is the web page where this info is posted, in case you need more info, hope this helps you to determain.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=uk&lang=en&rule=26781&product=3816592
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008. On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes. The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved. Battery power LED blinks The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition. Battery Power LED Component Tested Error Condition Battery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer. LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
Dec 01, 2011 | HP Computers & Internet
Acer ZG5 Notebook, my screen is blacked out.
There could be the resolution problem .. if you can only enter to safe mode you can restore it ... and if not there is a hardware problem which means that it can only be none when cheching it out...
Jun 10, 2009 | Acer Aspire One Netbook 8.9" Notebook
Motherboard issues
If you have an external monitor available, connect your laptop to it and start the machine. It would not start and shutoff if the motherboard was failing. It would not power at all or would turn on a display an error, with some beeps. By plugging into the ext monitor, you can amke sure this is not a video problem and watch it boot, until it gets to the error, which is probably a Windows Blue Screen.
Sep 26, 2008 | Computers & Internet
Janome 90000 just quit no light or enything help me please thanks Kathy
Did you check the dial inside the thread area, I was wiping some dust off mine and some how changed mine and when I turned the machine on my screen was totally black, But the know is black and only partially sticking out.
Aug 27, 2008 | Janome Memory Craft 9000 Computerized...
Monitor is busted!
If your pc works on another monitor. I would recommend you buy a new LCD monitor or a used CRT.
The best solution if your computer works is to buy a LCD screen, I've thrown out my 17" crt screens they aren't worth anything these days. You can get a used crt from ebay
Over here where I live I bought a used crt for 25usd thats was over a year ago.
Theres really no point in trying to repair the screen if its broken, buy a working one or a brand new lcd.
Good luck.
May 21, 2008 | Gateway FPD2275W LCD Monitor
Casio Exilim EX-S500 screen is black when turned on
you camera shutter is stuck at close position, you will need to open
the thing up to repair.
As for the totally dark screen, either your LCD or driver board is bad. You will need to open and replace the broken part.
Nov 15, 2007 | Casio Exilim EX-S500 Digital Camera
My Screen Is Black When I turn the Laptop On
When you say ?it turns on fine? I?m assuming that the power and hard drive LEDs turn on. If that is the case it could be your LCD backlight giving you problems. With the computer on and the monitor power LED green shine a flashlight in the lower left hand corner of your screen. Look for the ?Start? button, if your backlight is not working you?ll see a faint ?start? button if you look closely. This is usually an economically repairable problem but not for the typical home user. Let us know if you have any other questions and please don?t forget to rate this posting.
Jul 30, 2007 | IBM ThinkPad T23 Notebook
No pic .. leds blinks in sequence
Intermittent won't start, power supply LED's may be intermittent Cause: Power supply regulator I901 P/N CZ00868 is leaky, may verify the problem by freezing I901.
Jul 27, 2007 | Hitachi 60V500 60" Rear Projection...
Acer Aspire One Netbook 8.9" Notebook Logo
129 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
