Question about Casio Algebra FX 2.0 Calculator
How can i enter a polar form number with angle to convert into a rect form
How can i enter a polar form number with angle to convert into a complex numbe(a+bi)
Posted on Jan 14, 2011
Hello, atm I have this solution:
optn->angl->pol()
222+333i -> pol(222,333) = answer + degrees
angl->rec()
10ohm 45degrees -> rec(10,45) = answer + i number
Hope this helps.
Posted on Jan 24, 2012
    New Friend:
For algebra fx 2 writing complex numbers in polar form is so easy ... remember x+jy = r*e(j*theta) for example if we have r=5 , theta = 10 degree write ---> 5e(10*pi*j/180) multiply by (pi/180) to convert from degree to radian
Posted on Dec 02, 2012
Posted on May 12, 2011
  • shenningfei May 17, 2011
    same question need to ask
How do I add or subtract numbers in polar form or rectengular form
If one or both numbers are in polar form, convert it/them to rectangular. Once both numbers are in rectangular form, simply add the two components separately: Add the two x components together, and add the two y components together.
If you're asking how to do this on a particular calculator, please specify the make and model.
Oct 15, 2013 | Office Equipment & Supplies
Polar to rectangular conversion working incorrectly
At first, Rect and Polar are a display-format instructions, not a conversion functions. Polar instruction displays complex value in rectangular form a + bi. The complex value can have any complex form. However, an r*exp(i*theta) causes an eror in Degree angle mode according to the TI avowal. See captured images below
Sep 06, 2012 | Texas Instruments TI-84 Plus Calculator
Set the calculator to polar form, then simply enter the radius, press the comma key, then enter the angle (in whatever angular mode you've specified).
Full details are in Chapter 2 of the manual you can download from here.
Oct 25, 2011 | Office Equipment & Supplies
How to get angle value by pressing what key in rect to polar conversion
Press Shift, then press + key, input x coordinate, then press Shift and ) key and finally enter y coordinate and press =. You should now get solution (in solution r is radius and theta is angle).
Aug 13, 2011 | Casio FX-115ES Scientific Calculator
How do I convert between the rectangular and polar form of a number with imaginary values? i.e. I want to take the number a+bi and convert it to polar D<(angle) and vice versa.
Use the >Rec and >Pol commands. They're in the Complex number menu, accessible through 2nd [CPLX] MORE.
[CPLX] is the shifted function of the 9 key.
Dec 10, 2010 | Texas Instruments TI-86 Calculator
Where is the i button on the TI 86?
There isn't one. If you're entering a complex number in rectangular form, separate the real and imaginary parts with a comma (left of the 4). If you're entering a complex number in polar form, separate the magnitude and the angle with the angle symbol (2nd comma).
Sep 14, 2010 | Texas Instruments TI-86 Calculator
How to convert polar to rectangular form
Press [MODE] and select [1:COMP]
Press [SHIFT][MODE] and select [3:Deg]. You can also use rad if the angle you are given is in radians.
To start the conversion
Press [SHIFT][-] (Rec) screen displays Rec(
Key in the radius r , ex: 3 screen displays Rec(3
Press [SHIFT][)] (,) to enter comma separator Rec(3,
Key in the angle in degrees, ex: 57.3; screen displays Rec(3,57.3
Press ) to close parentheses; screen displays Rec(3, 57.3)
Press [=]
Screen displays
Rec(3, 57.3)
X=1.620720961
Y=2.524532346
X and Y are the values of the coordinates.
If angle is in radians, [SHIFT] [MODE][4:Rad] the command
Rec(3, Pi) gives X=-3, Y=0
Hope it helps
Oct 18, 2009 | Casio FX-115ES Scientific Calculator
How to change from phasor/polar form to rectangular form?
Hit [Mode] then arrow down until you can choose Rect, then hit [Enter] then [2nd][Quit].
Aug 30, 2009 | Texas Instruments TI-84 Plus Calculator
Polar/rectangular
For a TI-86
Converting rectangular to polar
Press "2ND" and then "MORE" for the MODE screen
Highlight PolarC and press "ENTER"
Quit that screen.
Now ready to go.
A example of converting 5+j6
Enter "(5,6)" in the calculator and press "ENTER"
Should get (7.81024967591*angle*50.1944289077)
Converting polar to rectangular
Highlight RectC and press "ENTER"
Quit that screen.
Now ready to go.
A example of converting 5*angle*35
Enter "(5*angle*35)
Should get (4.09576022145,2.86788218176)
Note
*angle* is the symbol when you press "2ND" then ","
Note 2
To round the an decimal places press "2ND" then "MORE" for the MODE screen and on the line that says float, choose a number on that line for the number of decimal places you would like to have.
More can be found at
http://docs.google.com/gview?a=v&q=cache:nAC57BtC6IIJ:myweb.wit.edu/khabaria/ELEC195_files/ti86cplx.pdf+ti-86+convert+to+polar&hl=en&gl=us
Dec 02, 2008 | Texas Instruments TI-86 Calculator
Casio Algebra FX 2.0 Calculator Logo
665 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
