Question about Tag Heuer Link Automatic Chronometer WJF5112.BA0570 Wrist Watch
I recently received a Tag Heuer Link Calbre 5 Automatic watch as a gift. However, it needs 1-2 links removed. I took it to a local jeweler and they said it can't be sized because it they weren't ablwe to locate the pins on the links that needed to be removed. Normally, most watches have visible pins on the links of the watch. How can I remove the links necessary on my watch for sizing? Thank you - Mark
  • 299 Answers
Here is how its done. First remove one end of the clasp (this is much easier on the adjustment side - just depress the pin and remove). Now you can separate the two halves of the first link (actually this is a half-link). Simply grab each half and pull. You may have to do some twisting - do it carefully so that you don't bend the pin. You may have to do some prying - if so, you can use a thin piece of plastic so you don't scratch the link and only pry along the pin so that you don't bend it. Once removed, you can now remove the first full link. Remove it in the same way. Now replace the end half-link and re-attach the clasp. Removing a link from the other side is a little more difficult. The clasp lock is held on with a long pin (slot on one end and screw on the other. One must be held in place while you turn the other. You may need another pair of hands to help you.
If you feel uncomfortable about any of the above, take it to a jeweler - a Tag AD is not necessary but probably best although any jeweler can remove a link if they understand how they are put together. Tell them the link is composed of a right and left half that snap together and they should then see and understand what they need to do.
Posted on Apr 28, 2010
Tip
TAG HEUER automatic watch with turning bezel (GMT) manual.
Follow this link and download original manual for TAG HEUER automatic watch with/without turning bezel and GMT function: http://www.tagheuer.com/the-collection/link/men/automatic-watch/index.lbl?w=WJ201A.BA0591
on Feb 09, 2010 | Watches
Links are broken in the bracelet.
Thank you for contacting FixYa.
Most watch companies do not warranty bands, but I would suggest contacting Tag Hauer at this link:
http://csec.tagheuer.com/csec/index.lbl
Best regards. Jewel
If you have extra links from being shortened, that may be of use too. Try a local jeweler for that repair.
Oct 21, 2010 | Tag Heuer 6000 Quartz WH1351.BD0680 Wrist...
My tag heuer link automatic stopped working what could be wrong with it
Assuming the watch wont start when worn then its time to get a specialist watchmaker to investigate.A premier watch as you have will need regular servicing at 3-5 year intervals.try www.rolexrepairs.co.uk they will provide a free estimate and operate a fully insured postal service.
Aug 16, 2010 | Tag Heuer Link Automatic Chronometer...
The second hand runs extreamly fast
Either the watch is faulty, in which case you need to return it to the store which you bought it, Tag Heuer are very good at fixing their watches. If you bought it elsewhere, check that it is genuine, before sending it anywhere, because if not a genuine Tag Heuer, you may not get it back. I'm guessing its a Quartz model, which are difficult to repair but simple and cheap to replace, which is what they will do (Tag/Jewellers) if its an Automatic model, then it will be repaired quite quickly, as very simple to do. Any problems, luxury sauce dot com, contact me via there.
Apr 23, 2010 | Tag Heuer WAH1112.BT0714 Formula 1 watch
TAG Heuer Carrera Calibre 16
Hi
This is a warranty issue, the watch should not lose time like this. Take it back to the supplier ASAP
Cheers
Dave
Jun 21, 2009 | Tag Heuer Link Automatic Chronometer...
Second hand on my watch now goes in 5 second intervals
Check the instruction manual if you have one. Tag-Heuer watches move in 5 second intervals to let you know the battery needs replacing. A neat feature. Now you know that you have a real Tag!
Dec 30, 2008 | Tag Heuer Link Automatic Chronometer...
How to remove links on a tag heuer cj1110.ba0576 watch
tag needs a special tool, try a jeweler should only cost 10-15 bucks!
May 10, 2008 | Tag Heuer cj1110.ba0576 Wristwatch
Tag Heuer 200meter Professional series
This is to let you know that the battery needs to be replaced.make sure that you use a watchmaker that can test and replace any worn case parts so that your watch will retain it's original design water resistance.
Donald McPherson
Certified Watchmaker AWCI
www.finewatchmaking.com
Oct 21, 2007 | Tag Heuer Link Automatic Chronometer...
My watch dosen't fit
Have a look at bracelet clasp exetnder from RTL Watches
Jul 28, 2007 | Tag Heuer Link CJF2114
Tag Heuer Link Automatic Chronometer WJF5112.BA0570 Wrist Watch Logo
886 people viewed this question
Top Tag Heuer Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
