Question about Kitchen Ranges
When Ideling engine surges you have to keep choke pulled out about quarter of a inch. uder load (blades rotateing) engine run fine. Ipulled carb off looks clean inside.
  • 438 Answers
You may still have a fault with your carburetor, having to chock it somewhat indicates you are not getting a rich enough fuel mixture, obtain a carburetor rebuild kit and clean the carburetor paying attention to the small galleries blowing them out with solvent and air pressure, also insure the gasket between the intake and the carburetor is not sucking in air, you will get a new one with your carb kit
Posted on Apr 28, 2010
Why does troybilt generator engine keeps shutting off when throttle is moved from choke to run position?
Give it a shot of starting fluid. If it runs initially, then most likely the jets on the carbureator are clogged. You should remove the carb and clean/rebuild it.
Sep 05, 2014 | Briggs Stratton Portable Generator 305cc...
Stalls When engaging the blade clutch
Check that the blade brake is disengaging. Slip belt off blade spindles and check that they spin freely. Check underside of deck for clogged grass, ropes, wire, etc.
May 07, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Engine surges won't run with out choke and then it stalls
If the engine surges and won't run without choke it is starving for fuel. Best place to start is the fuel filter. After the fuel filter, pull the fuel line off of the carburetor and place a container under the fuel line to catch the fuel. Crank the engine over and watch for the amount of fuel being pumped through the line. There should be a good stream of fuel with each pulse from the pump. Chances are the pump diaphragm is getting weak and it cannot keep enough fuel in the carb to run proper. Check those items and let me know if it helps, Daniel.
Sep 29, 2011 | John Deere 24HP VTwin Hydrostatic 48"...
Ipulled out a318 with a2 barrell carb installed 383 4 barell I have the factory 5/16 fuel line and new factory pump on heavy acceloration from stop it tries to die then takes off and acelorates fine do I...
Sounds like the accelerator pump circuit in the carb is not squirting fuel in when you depress the accelerator. That is why you get the lag in acceleration before it decides to launch. When you open the carb you should get a steady stream of fuel from the accelerator pump. With the engine not running look down the carb throat and open the throttle blades and visually check to see that there is a stream of fuel when doing so. If not time to rebuild the carb, or just get another accelerator pump for
the carb.
Jan 21, 2011 | 1983 Dodge Pickup
After about 30 minutes engine will start surging, by partly pulling the choke out it will run better. The carb has been recently rebuilt as well as new filter and fuel line to carb. Tried different fuel...
Typically a surge is caused by a lean condition. I'd say the float is set to low and this is causing the engine to lean out & when you apply the choke it richens it back up.and the surge stops.
Oct 12, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Governor keeps surging fast and then slow
Check to see if the engine runs smooth will slowly pulling choke out. if it runs better without surging, then its a carb problem.
Also may have an air leak in carb gaskets
Nov 20, 2009 | Craftsman Garden
1986 vett
Your automatic choke is probably sticking. Spray it out with 2+2 Carb and Choke Cleaner. Do this when the car is cold so you don't start a fire. While the car is running see what position the choke butterfly is in when the engine is hot. If it is partially closed you may have a bad spring in the choke mechanism or it may need an adjustment.
Oct 10, 2009 | 1986 Chevrolet Corvette
2002 suzuki LS 650 running lean at higher speeds, (off idle)
this prob happens allways in carburated engines that the car or motorcycle is running lean or rich . because the air - fuel mixture ratio is not right . so you should open the carburator and remove the air filter you will find two screws in the lower front section of your caeburator. you can adjust them by a screw driver until your car is smooth
May 31, 2009 | 1996 Suzuki LS 650 Savage
1996 VW T4 2 litre Petrol Transpoter, fuel mixture problems
usually black smoke is a good indication of a blown head gasket check the oil to see if it look milky will look kinda brownish like chocolate milk or cocoa
Apr 11, 2009 | 1996 Volkswagen Golf
1991 Toyota 4x4, 4 cyl. engine. Surges when coolant level is low, even though it has not yet heated up.
your carb has a coolant heated choke system if i am correct as car warms up the coolant warms the choke spring. keep full of coolant to keep from other damage
Aug 20, 2008 | 2004 Toyota Corolla
Kitchen Ranges Logo
22 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
