My touchpad is very touchie It makes my curos all over the screen.
    Sergeant:
  • 349 Answers
Well i had the same problem when i first used my laptop,i found that i was touching the touchpad not only with the pointing finger but also with the knuckle of my little finger at the same time,this made the pointer dash around all over the place,i am now able to use it without this problem ,but i rather use a proper mouse.
hope this is of help
Terry
Posted on Mar 24, 2008
SOURCE:
Toshiba touchpad frozen!
Check for a switch for the touch pad.
Jun 15, 2017 | Toshiba Satellite(R) L655-S5115 Laptop...
How do i turn the touchpad off or on? It is so touchy that I want to disable it and use the mouse only.
go into your control panel look for the mouse icon click that and you will find a scroll menu next to devices click on that and choose other device
Jan 27, 2011 | Gateway MT3705 Notebook
Touchpad is not working correctly. It is touchy. Seems to be not working correctly in the middle of the touchpad. If I use the top or bottom it works fair. When I use it, it is difficult to control the...
Sounds like wear on the contacts, if you can try applying a little pressure to the centre of the pad, and it works better, this is the issue. As a first resort, you could try and download the touchpad driver and re-install it, howver, this is a common fault with the touchpad. You may need to have it replaced or possibly cleaned
Jan 02, 2011 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
I have an HP G72 and the touch pad frequently locks up...help me fix this the FN and F9 combination didn't help.
tricky huh!!! you simply have to quickly double-tap the Touchpad light :) to lock it or unlock it :) hope it works for you :)
Nov 10, 2010 | HP Compaq nc6000 Notebook
My touchpad is too touchy. screen keeps jumping around
common problem with new systems,you should be able to configure the settings somewhere.
make sure your not in a high density of signals cybercafe etc
Sep 06, 2010 | HP Computers & Internet
The touchpad pointer is becoming increasingly erratic. For example it will not point easily where i am trying to locate;it jumps at random around the screen; it highlights without this function being...
Try going into control panel & find the mouse section. See if you can adjust the sensitivty down. You may have a program built in from acer to adjust this too. I reccomend turning off the tap feature on the mouse pad. When they get old they get real touchy. If turning the sensitivity down doesn't work, you can try & see if there's an updated driver or re-install the old one. If all else fails,it's time to head to ebay to find the touch pad.
Mar 17, 2010 | Acer Aspire 5720 Notebook
Touchy Touchpad on Acer 5735 - How can I disable?
hold down the power button untill you hear the cooling fan stop working and all the led light are turn off
Jun 24, 2009 | Acer Aspire One PC Notebook
Touch pad is too touchy
Check in the control panel and get in the mouse program, usally there is the program of your touchpad.
Feb 12, 2009 | HP Pavilion ze4300 Notebook
Dell latitude c610 touch pad left button problem
Will your laptop work properly with an external mouse? If so, check your touchpad settings in "Control Panel" by selecting "Mouse". Here you can reassign your Buttons. Try setting your Right Button function to "Double Click". If the "Double Click" function works on your Right Button then chances are you have a problem with your Touchpad Assembly which means it will have to be replaced. Dell refers to it as a "Palmrest" which they will replace if still under warranty.
Sep 20, 2008 | Dell Latitude C610 Notebook
Open Questions:
[email protected]#[email protected]#%$@#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 [email protected]#[email protected]#%[email protected]#%$##Avast technical support phone number 1*888*499*5520 fvhdshf
Oct 15, 2019 | Computers & Internet
AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]AvAsT toll toll pHoNe {@}{\1888499-552O]
AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o] AVAST toll toll pHoNe {@}{\1888499-552o]
Computers & Internet Logo
37 people viewed this question
Ekse
Alun Cox
